fitting a 235/40/18 into 18x9.5 rim
davidcnz
808
102
Malaysia
as title above...will it be overstretch ? please give me some advise on it ...
recommended tyre for this setup ?
really appreciated your help on this ! :D
9.5' is just over 24cm wide so using 235 tires is a bit narrow and stretched already. For 9.5' should use at least 255 tires. For 235 tires, should just use 8-8.5' rims.
davidcnz
808
102
Malaysia
thank you bro ...that's mean its going to be a stretch setup...anyhow , do u have any recommended tyre that it's good for stretch with good traction in dry n wet ?
AlucarD
1,079
115
5,163
hi there, you have a set of really nice rims 18 x 9.5 and should give it a proper set of tires that will make sure that the car runs properly.
Tyres are never designed for stretching so to me there is no proper tyre that is good for stretch and if you must stretch it get the cheapest tyre as the tyre may not last that well. Cheers
As per bro. 6UE5t mention 235/40 best fit is 8 -8.5", however 9.5" is max size to fit. It will stretch slightly.
Tyres that have good traction in dry and wet, then go for UHP or Max performance tyres but they come with a price...:rolleyes:
TopRpm
295
46
im using 265/35/19 on 9.5jj rims. not stretched.
minimum has to be 225/45 but its stretched.
damnn..my seiifoo is using 9.5jj too...what rims bro? i believe not at ur atos!!! btw i'm using 9.5jj but on 225/40/18..as what others said..its stretched!
blitz
42
14
5,008
I just fitted 245/40/18 on 9.5JJ rims yesterday and it looks normal so ... yours will only stretch a bit... If you want to stretch it like those hellaflush cars, go for 225/40/18....
davidcnz
808
102
Malaysia
225/40/18 on 9.5jj ..i think the rim will be out alot..hehe..i will stick to 235/40 its better..slightly stretch it's fine ..thank you all for the guideness :D
btw ...is there anything i should precaution while using this type of setup (235/40 on 9.5) ? such as tyre presure n etc
---------- Post added at 11:29 PM ---------- 6 hour anti-bump limit - Previous post was at 11:19 PM ----------
can i have some picture of your setup bro blitz & 4gbanger ?
40 series at least should be 35psi
davidcnz
808
102
Malaysia
in dilemma of choosing this 2 choice of tyre ..michelin ps3 or yoko advan ad08 to be my next set of tyre...18x9.5 with 235/40/18..minor stretched...i dont track my car..it's a daily driven car..which one would be my choice ? in term of side wall , dry n wet grip , comfort ride , noise n etc...
thank you all sifu in advance for the guideness
From your priorities stated, sure is PS3 already.
AD-08 are extreme tyres more for track, extreme dry grip, wet so so only. No comfort and noisy...
ecovent is kind of a device, when ur car is very hot, reach to 40c, it will open to let the hot air blow out....so the car will not be that hot
or so i heard la...
but i havent come across this device for cars...
anyone can share? if it's good, then i'll install it as well since the weather now is crazy!!
