1.6 CamPro Persona hard to start
punk
360
76
Negeri Sembilan
punk, can go to persona thread also...
i think his problem is same as described in saga thread.
I have no idea what is that guy talking. Wtf.
Cannot brain.
Jus read slowly and u will understand.
Since u cannot start during first attempt, do not return to Lock position.
If u return to LOCK position and u turn back to ON, then more fuel in pumping in.
The wuekekekeke sound is the starter turning sound.:rofl:
stupidcar
5,000 RPM
5,567
850
Yea yea. Haha, stupid engineering.
Persona LYN I don't like it.
ckdenion
Aug 21, 2013
20
503
kena 2 times is because i 'forced' the car to drive more even though petrol indicator blinking...
other than that didnt kena before...i do know that most (not all?) saga campro also have this issue...:confused:
stupidcar
5,000 RPM
5,567
850
Walao bro, blinking means damn freaking low dy.
Seems to be. Now I just close one eye, hopefully its ntg.
Will visit SC when I'm free.
Gotta update TCU, ECU, then change my door rubber seal.
ckdenion
Aug 21, 2013
20
503
yes...somemore after blink i still drive like 40-50km...tat happened long time ago when my car is still <5000km
didnt do that anymore...now always reserve quarter tank of fuel...
im not aware that our TCU got new firmware to update... do let me know after update got wad improvement/changes...hehe
stupidcar
5,000 RPM
5,567
850
Should have since it's a brain too. Haha unless Proton go cold on Persona. :bawling:
Ok. Just found out my old thread. New Century Marathoner DIN55R battery.
Crank still long but not as bad. But still bad. :rofl:
I tot u are going to end your sentence with "but still ok"..heheh
I dont have any cranking problem with my 08 BLM.
Maybe "The force is with me".
Last time do heard Campro with hard starting problem which are solved by retuning the ECU.
Dunno if adding VS and grounding will help a bit.
Why dont u give it a try and if it does not work u sell it to me at 1/2 price?:biggrin:
driftkingII
2,124
278
5,183
Bandar Utama
Persona Elegance 1.6, not even fully 2 years yet, still under warranty although service outside.
Spark plug just changed, don't seem to be the problem. Battery normal voltage.
The thing is, my car is hard to start. Crank fastest also 2 second only it will start.
A few times, I cranked more than 2 sec it started at 500rpm, 'choked' then died.
Everytime before I crank, I will let the pump 'charge' itself. There is this sound that it makes.
"Yiiiiiiii" at the back seats.
Just now I cranked then I felt that it is hard to start, then I switch to acc again,
then I started the pump again, can hear watery sound, in this case I guess it's fuel, going through.
So any other CamProlers facing the same issue? SupraFanatics confirmed with me 1.3 BLM is hard to crank too, he said his mechanic said it's normal.
But isn't it crazy how hard it is to start a car? I started my GF's Myvi & Father's Innova,
started without hesitation.
The way it cranks for so long makes me feel that the engine is hurting itself.
Too bad not many friend using CamPros. All Myvis. -_- So I can't try.
This is worrying.
something like mine, but what they say in LYN true eh?
https://forum.lowyat.net/index.php?showtopic=2961179&st=980&p=63388829&#entry63388829
have u all tried it?
stupidcar
5,000 RPM
5,567
850
15,390
All you gotta do is, slam your forehead on the steering wheel, twist the key to START again. This time, hold on to START. It should sound like "Wuekekekekekekekekekekekekekekekekekekekekekekekekekekekekekekekekekekekekekekekeke..." Finally, "babababab beebababadopop bee bab bab ba da pop" and it start.
Scatman john!
Honestly I think this guy is trolling the newbie. The Protons probably don't have high powered starters and the issue is probably further compounded by a weak battery. Upgrade to a higher powered starter or a fast starter (ignition coil) and keep your battery healthy and I think you'll be fine. My old Wira was running a Perdana starter I think. Or was it a Evo one? Can't remember. Started very easily everytime until the battery died. But if you do opt for a different starter, if you can afford it don't buy half cut. Buy new. If you can't afford new, buy a properly recon one. But that's like the lucky draw, either you get it or you don't.
30,002
I read your whole topic again. Actually hard to start or hard to crank? Because you talk about weak battery and starter. Weak battery and starter the crank will be slow, but if crank is fast nothing to do with either.
To start a car, air/fuel going in and current going to spark plug.
Car start and die in the morning, usually auto choke problem, especially like it was mentioned engine low rpm and some choking before dying off. My Tiggo and Hyundai rpm is slightly above 1k, and drops below 1k, after they have warmed up. My VR a bit cranky, since FICD not working that well, sometimes cold rpm can be at 2k, then drop gradually....
However all 3 cars starting is good, mostly one crank is all it takes...
stupidcar
5,000 RPM
5,567
850
Sometimes one crank gao dim wo. Like this morning.
i have a blm and my sis has a neo cps.
the cps engine crank and start easily.
the campro was previously hard to start,it needed a longer crank than the cps.
after sending to sc long time a go and they did something with the ecu.its still longer than the cps but not by much.
my 1.8 waja is hard to start when the engine is hot.it needs a longer crank than it needed when cold.maybe the ecu needs tuning as i havent done that for a while plus the battery was disconnected for one whole week when my mech replace some seals in the gb.his computer is unable to tune the ecu.just reset to stock setting.
stupidcar
5,000 RPM
5,567
850
Isn't it easier to start when engine is hot? :confused:
thats why...
cold start like in the morning:kret...vroom
hot start : kret,kret,kret,kret,kret,kret...vroom
puzzling...
if its only left for few minute then its fine.if let say i am having lunch and then want to start back...long crank.
30,002
Some ECU cannot be tuned, reset then yes......
---------- Post added at 01:59 PM ---------- 6 hour anti-bump limit - Previous post was at 01:57 PM ----------
Not really, it depends on your engine. Start when cold can be easy too, as got cold start choke. If your engine runs lean, it is harder to start when hot, the air/fuel mixture vaporizes, so harder to start.....
A Post Every 5 Mins
In this guide I will show you guys how to DIY some ground cables for your car. You can choose to buy ready made sets from shop but it's more fun if you can make them yourselves save you the extra bucks and get to know your car more.
What you need?
1. Cables
The cable is the important part. You need to buy pure copper cables as higher copper % better conductivity. The Sizing is up to you and you also need to take into consideration is the cable easy to work on. On my case, I didn't buy...
