rim 13 to 14 using 195/65 tyres for kancil
papagoines
Orang Tua
2,024
376
1,683
Rawang/Selangor
How do you mod the hub if the PCD is wrong?
beats me.... never seen the process done myself... all i've seen my pomen did was take out the hub and knuckle, send it to engineering shop to change to your desired pcd...
so far i've never seen ppl converting to other pcd ever complaints afterwards
other way of doing it is to use 'pcd converter'... basically a wheel spacer but with different pcd at the rim's end. but i've never seen a well-made converter here in malaysia, always made the rim out of balance... plus most of the time it will accelerate bearing failure....
I think they still drill new holes for new PCD. Have seen some conversion like 4 holes to 5 holes even. 1 original, maybe 2 new holes and 2 half holes.....:confused:
Hub conversion usually for car with bigger central hub, so the rims with smaller central hub will not fit, so they bore the rim hub bigger to fit in...
The PCD converter I have seen also, but will make the offset much further out...Local PCD converter also do not have the central cone, so balancing may go off....
papagoines
Orang Tua
2,024
376
1,683
Rawang/Selangor
guess so... but at least it not bore hole into the rim itself... so modifying the hub itself is more durable then
p/s: wished that i got lots of $$$ to order custom wheel that fits my kancil like this manufacturer in the UK is offering
14" Motorsport Wheels
can custom pcd and even offset as well :smokin:
Yah! custom made won't be cheap.
The 4th one looks like the the one I use before in my 1st Generation Accord. That time this Accord also come with own PCD of 120....:mad: therefore cannot choose much rims.....:bawling:
papagoines
Orang Tua
2,024
376
1,683
Rawang/Selangor
very rare indeed :hmmmm:
twistedichc
2,930
255
683
Ampang Point
this converter should be really nice coz basically we can opt for wider tyre:hmmmm::hmmmm::hmmmm::confused::driver:
papagoines
Orang Tua
2,024
376
1,683
Rawang/Selangor
:adore::hmmmm::shot: shoot me if u guys want but what is offset:confused:
hope this picture help.. it shows kancil with massive negative offset
me think... smaller the offset number, more likely your tire will be protruding outside of your fender :hmmmm:
twistedichc
2,930
255
683
Ampang Point
:adore: this should be great:smokin:, btw have u seen fluorescent green myvi wit ridiculous tyre offset+allignment around ampang these few weeks, my hp is so dinosaur age cannot take picture if not arrr definitely be another episode of initial b.:biggrin:
papagoines
Orang Tua
2,024
376
1,683
Rawang/Selangor
maybe i missed it.....
No need to shoot. As explained by bro. papagoines, at least you have gain some knowledge....:biggrin:
---------- Post added at 06:10 PM ---------- 6 hour anti-bump limit - Previous post was at 06:08 PM ----------
Yup, the smaller the number the further out it comes. When negative offset -ve number even further out....mostly for RWD cars....
twistedichc
2,930
255
683
Ampang Point
:adore: thanx, that means my wallet oso gonna be -offset lorrr.:biggrin:
papagoines
Orang Tua
2,024
376
1,683
Rawang/Selangor
Some japanese brand also got those 8 holes, and sometimes 12 holes as well (100/110/114) and they still hold strong even today
as per taiwan's replica wheels, me think its durability are pretty much the same as any other taiwan made rims of bigger size... have to be more conscious of potholes and such
100/110 pcd 8 holes ready made rims, advisable @ not??:hmmmm:
Yup, 8 holes are okay if they are original. Those re-drilled ones then no.....
Both my 17" rims are 8 holes (100/114.3) One is open style can see the 8 holes, the other has a cover...
Similar threads   Forum
R General Talk
Proton
  Similar Threads
R General Talk
Proton
Has anyone successfully installed the following Apexi products in their
Korean made car...? (Kia and Hyundai)
I'm interested to install. Need to exchange ideas...
- Rev/ Speed Meter GP
- S-AFC II
Would like to know if it is possible to install these 2 products in a
Korean made car, and which performance shop can it be done at.
