silvertop timing belt kit complete set
feipepe
293
13
balakong
hi to everyone sifoo 4age silvertop,
currently my car was transparent around 3 yrs to silvertop hearts 4age.it times need to changes the timing belt kits. i have searching around web. it look that without any info to get the full complete set timing belt kits within malaysia market.
as what i meant full set complete kits here included the TIMING BELT, BELT TENSIONER, IDLER AND OIL SEAL as well.
due to this issue, below are some question or optional need to for those sifoo 4AGE silvertop get advice and spend a useful experience to share everyone silvertop users.
1) how does to get this full set complete timing belt kits for silvertop?
2) is that TIMING BELT, BELT TENSIONER, IDLER AND OIL SEAL for the blacktop version can be similar to used? have any sifoo tried this before? have any modification to do?
3)or changes the top head block to blacktop version for fullfill the timing belt kit? is it just PNP through silvertop block? any ideal?
feipepe
293
13
balakong
hi sifoo IKeong88,
i had been ask the foremen in which help me to make transparent my 4age hearts. but he mention that last time during my transparent he also used blacktop timing belt kits.after i visit and research at other forum, there is dissimiliar timing belt kit with silvertop.
now i just wonder that blacktop timing belt are comfort n suitable used in my silvertop too.
so far now nothing happen.
D7zul
2,697
848
Shah Alam
i think it's the same belt..
BT & SVT only difference is in :
- intake manifold
- MAP for BT & AFM for SVT
- piston
- conrod
- computer box (of coz)
- (any1 wanna add?) :biggrin:
the rest i think is the same..
p/s : english lesson
transparent = lutsinar
transplant = moving a thing to another location
:wink:
feipepe
293
13
balakong
Hehe,mr zul i know my english bad.thanks for advice.
If not mistake,mr zul also used silvertop right?then did u even to change timing belt kits before?what brand timing belt part using?
Remark:timing belt kits as what i mention here only not timing belt. Is included belt tensioner,idler and oil seal parts.
D7zul
2,697
848
Shah Alam
lkeong88
394
121
Cheras
No you cannot use Blacktop belt on silvertop. If I am not mistaken its different by 1 tooth. Last time I went to buy blacktop timing belt set, they gave me silvertop 1 (then I exchange) so I can confirm spare parts shop is selling both.
D7zul
2,697
848
Shah Alam
oh.. like that ..
it's good to know.. that shows that my knowledge is still limited :biggrin:
if i were to put a BT head onto my SVT engine, should i use BT belt or SVT one? :confused:
this is for my future upgrade :wink:
j_l200s
339
74
3,028
yup, SVT extra 1 tooth @ 111 teeth. BT only 110 teeth.
BT uses hydraulic tensioner while SVT uses spring tensioner.
oil seals should be the same.
and what is idler??? i think tensioner = idler?
feipepe
293
13
balakong
Thanks for all sifoo reply,
so that did u all have any recommend spare part for to buy all the part silvertop within area klang valley?except wing hin jln loke yew?
CAn contribute to junior 4age 20v:itsme:
lkeong88
394
121
Cheras
Vanli Auto at Jalan Ipoh is 1 of them
Another is
Fortune Auto Parts Supply, Taman Paramount P.J (03-78771780)
Then there is PH Auto at Sea park
Also this is the contact that Aisin Asia gave me for their dealer in Malaysia, they carry Toyota and Aisin Spare parts:
Teng Sun Auto Supply Sdn Bhd
No. 25-29, Jalan DBP 1,
Dolomite Business Park,
68100 Batu Caves,
Selangor, Malaysia.
Tel: 03-6186 2222
Fax: 03-6188 0390/96/97/98
feipepe
293
13
balakong
Thanks for sifoo ikeong88 contribute so useful detail. May i know r u also silvertop engine owner
feipepe
293
13
balakong
due to i'm using silvertop, let me make a assumption if i changes cam pulley silvertop to adjustable cam pully etc like toda cam adjustable pulley, therefore what type of timing belt can be used? silvertop or blacktop type? or aftermarket type?.
feipepe
293
13
balakong
hihi expert sifoo,
please share because my millage wanna to reach max limit of 70k liao...may be changes timing belt and also changes the adjustable pulley together..plzzzzzzzzz:adore:
bera
823
229
errrr bro...i dont meant to be rude...but you are taking the wrong route by changing the pulley just to use bt timing belt on your st...timing belt for both st and bt readily available...in fact i just bought one last week (bought @jalan ipoh)...and the guy at the shop gave both st and bt timing belt for me to tengok tengok first...it is not as hard as you think...
just now...bought the hydraulic tensioner...the shop i go earlier ask for a sample first so went to another shop...and walla they got stock...maybe you have to jalan jalan at spare part shop abit...but i'm using bt so i cant share the part no with you...for obvious reason...
feipepe
293
13
balakong
bro bera,
thanks for ur advice, just wanna to know u meant jln ipoh spare part shop. did u have full address detail.
bera
823
229
dont know the exact add...damn where is the resit when i need it (will update once i found the resit)... but do a search on google maps "ah hong motor"...its jalan sentul off jalan ipoh...
if you from mahameru highway from putra world trade center heading towards bulatan pahang...turn left at grand pacific hotel (underpass)...then first traffic light turn right..you can see one maybank branch on your right...the shop is on your right around 200 - 300 m from the junction...it is in the same row with a motorcycle shop...only two shop there...but better go there with a friend...it a bitch to park your car there...
hope this help...and price wise...i paid rm 130 for mine...if you feel expensive...then dont go there...hehehe...
bera
823
229
you can try it...as long as correct spec (correct tooth)...this one i think have better durability...but it wont be as cheap as the oem toyota...how much is this anyway...??
I managed to capture this picture in a Golf 1.4 TSI earlier today and thought I would share it with the readers of Zerotohundred. More interesting is the fact that I'm in the process of testing and reviewing three different Volkswagen models; all of which employ the same 1.4 TSI twincharged powerplant. Stay tuned for more pictures, and reviews soon!
