Hi Jason. First of all what is your plan on ur mods? How far do you want to go. If your r thinking of cams and pistons, Emanage or SAFC NEO is comparatively good. But of course without a good tuner, it will go to waste. But i am happy with SAFC 2 at the moment. Good pick up and smooth ride. Till the end of the day. The choice is still yours. GReddy(Trust) or Apex'i.
Go for Haltech or Microchip for max mods. :)
92 soch pistons have the same bore as the 93 doch pistons, iirc. u need to rebore 91 block if u wanna fit the 92 pistonsto used a 1.6 piston is cheap but need to sent block to machine shop that cause a bom are you over sizeing it??? i am using 1.6 piston in my gti, ok la lots of diff. but also depand on what mod u doing to the engine........
Hi Waan,
Well, my plan of mods is stick to NA. I just wanna push out more hp from my engine...perhaps 20-25hp more. Don't plan to touch the cams and pistons of my engine at the moment.
Based on your feedback, seems like EManage & SAFC NEO / 2 are equally good, for a NA engine. If I were to do that, of course will get a good tuner to do it. I believe Sunway area has plenty of them. Actually already know where to go n who to find. Joshua from Millennium would be my choice.
Perhaps u guys think if I don't touch the cams n pistons (I mean remain stock cams n pistons of 4g93), it is kinda waste of money to install piggyback / standalone. What do you guys think?
Cheers.
ok. tks bro. but the quality of Gti bumper is still same as satria?
But y is that i have 180 km/hour cut? is this normal to year 99 sgti model?
Thks again.
Regards
Definitely it will be a waste if you are sticking to standard mods. 20 - 25hp just from Emanage? or together with the mods you already did to your ride? Yeah, i believe sunway has good tuners. But i never ever go there.
Well, my pick will be Apex'i > GReddy.
Thks again.
Regards
Of course it's not just by EManage itself... I believe if EManage able to do that, it would be a damn value for money product d... What I meant here is together with my other mods + ECU, that figure of hp improvement sounds more logic n practical, right?
So Apexi SAFC II / I would be good enough right? This SAFC also can remove the 180km/h speed cut?
proton use mmc ecu up to sept 2001, and there is no speedcut on MMC ecu AFAIK becoz i own sept 2001 sgti with APM 0450
siemens ecu only got speed/rev cut
owh ok...but my friend bought a proton putra year 97 with MMC ecu and got speed cut because of japan regulation which is all production car must limit their speed to 180km/h...so i thought might be the same goes to sgti with MMC ecu,maybe proton has removed the speedcut...![]()
Similar threads | |
