Ferrari Purosangue Malaysian Launch - Ital Auto Kuala Lumpur
Needles Tosay
Newspeed
Jun 10, 2020
46
11
24
0-100: 3.3s / 725ps / 716nm / NA V12 6.5-liter mid-front-mounted / 8 speed DCT / 4WD / 310kmh / weight: 2033kg / width 2028mm / height 1589mm / wheelbase 3018mm
- Official launch by Ferrari Ital Auto Malaysia
- Ferrari Ital Auto Malaysia Showroom, Four Seasons Place, Kuala Lumpur.
- First-ever four-door four-seater car from Ferrari.
- 'Purosangue' translates to 'thoroughbred' in Italian.
- Unveiled alongside the Ferrari Roma Spider.
- Pricing starts from RM5,000,000.00 (inclusive of duties and taxes).
Power:
- 725ps / 716nm / 6.5-liter Mid-front-mounted NA V12 engine.
- Redesigned intake, valve timing, and exhaust.
- Improved mechanical and combustion efficiency.
Drive:
- 8-speed DCT with redesigned Manettino settings.
- Mid-front-mounted engine with rear gearbox improves weight distribution.
- 4x4 transmission with 49:51% weight distribution.
Chassis:
- Aluminum Spaceframe chassis.
- Carbon fibre roof for rigidity and lower weight.
- Active suspension system for controlled body roll and handling.
- Ferrari active suspension technology with True Active Spool Valve System.
- New generation front semi-virtual, high wishbone suspension.
- ABS 'evo' controller for optimized performance.
- 4RM-S system for improved yaw management.
Body:
- Carbon-fibre roof for rigidity and lower weight.
- Air curtain for front wheels to prevent turbulent air flows.
- Rear-hinged back doors for ease of ingress and egress.
Interior:
- Dual cockpit dashboard concept from front to rear.
- Driver's cockpit inspired by SF90 Stradale.
- Four separate and independently adjustable heated seats.
- Seats focused on comfort with variable density foams
- Introduction of special Alcantara made from recycled polyester.
- Debut of Burmester® 3D High-End Surround Sound System.
Driver Assists:
- Standard driver assistance features (ADAS)
- HDC (Hill Descent Control) for controlled descents.
- ACC, AEB, LDW, LKA, BSD, RCTA, TSR, DDA, and rear-view parking camera.
Options:
- Full-length electrochromic glass roof.
- Massaging front seats with customizable settings.
- Air quality sensor for improved cabin air.
- Compatibility with Android Auto and Apple CarPlay systems.
Reactions: Izso
Hey guys... Do any other owners encounter the same problem during parking speeds?
The steering vibrates and rattles annoyingly. I brought up the issue with Euromobil but apparently they said it is inherent in B8 models. (what a load of crock!!)
So was just wondering if anybody is having the same problem and is there a solution to this?
Thanks ! :banghead:
