Toyota recalls GT-86 coupe, Malaysia affected
Amirul
Resident Journalist
Jun 7, 2016
213
112
43
www.zerotohundred.com
Toyota Australia has recalled over 15,000 units of the GT-86 coupe over possible power steering problems, CompleteCar reports.
The units affected are those built between April 2012 and March 2015, and so far, the issue seems to arise on right-hand-drive units fitted with driver's knee airbag.
The statement from CompleteCar:
"The GT86 uses electrically-boosted power steering, and the problem seems to affect only right-hand-drive cars fitted with a drivers' knee airbag. Apparently, the wiring for the power steering is chaffing on the cover for the airbag and potentially shorting out the system."
According to Toyota, if the problem (the power steering wiring shorting on driver's knee airbag system) occurs, there could be an electrical contact which may results in the loss of power steering assist.
Meanwhile, UMW Toyota Motor has acknowledged the fact that GT86 units sold at official Toyota dealers in Malaysia are also entitled to the recall service and will contact owners directly for further arrangements.
All because of P1.....all suffer on cars. I did own one once and that was it......
My friend who own a mitsu engine with its O2 sensor connect to apexi timer get a very low reading on O2 voltage,0.07 to 0.18volt only.last time it was fine can get normal reading.
sensor already change to another unit but still the same scenario.
the O2 sensor is a 2 wire unit.(blue/white)
i measure the voltage direct from the sensor both wire and get 0.1v same as what shown in the timer.Then i measure with a multimeter,the signal wire (+)and the chasis(-) ground then i get 0.45v...
