Machine shop / custom made parts / engineering works
Car Shops and Services
AvanT
Custom fabricator & CNC machining
360
113
1,543
Need a custom made ADAPTER / FLANGE / PART / SPACER for your ride?
Computer designed & CNC cut.
Fabricate using mild steel, stainless steel, aluminum, titanium.
Argon, CO2, stick welding available.
[email protected] / 012-283-3635
PROJECT: TD05 Wastegate adapter (Airtrek turbo)
PROJECT: Engine porting & seal upgrade (RX7 FD)
PROJECT: Racing fuel tank (Perodua Myvi)
PROJECT: TD05 turbo & wastegate adapter (Satria GSR)
AvanT
360
113
1,543
PROJECT: Exhaust manifold (Honda CRZ HYBRID bolt on-turbo)
PROJECT: Slotted disc (Honda Civic)
PROJECT: Slotted disc (Perodua Myvi)
PROJECT: Undersized crank pulley (Perodua Myvi)
PROJECT: Custom brake caliper bracket (Toyota Harrier)
PROJECT: Custom brake caliper bracket (Nissan Skyline)
^pomen_GTR^
7,000 RPM
7,509
1,690
The Mines
how much for undersized alternator pulley? (mitsubishi/proton alternator)
AvanT
360
113
1,543
PROJECT: Oil/fuel cap ring (Universal)
PROJECT: Exhaust manifold (BMW 328i twin turbo)
PROJECT: Undersized main pulley (Mitsubishi/Proton)
dgsllk
Nov 3, 2012
12
Hi bro, my existing EK has 4 lugs knuckle, do you convert it to 5 lugs? I hear many ppl said it can be done at machinary shop?
Also, I am thinking to use a Nissan 4 pot caliper, do you custom make the caliper braket to my stock knuckle?
Hope to hear from you.
Thank you.
AvanT
360
113
1,543
Thank you.
Hi bro,
Yes, we've done many cars with 4x100 or 4x114.3 conversion to 5-holes.
Yes, can be done, will need your knuckle, discs, and calipers for 1-week to complete the caliper bracket job.
dgsllk
Nov 3, 2012
12
Hi bro,
Bro, can PM the quote on the 2 works, and your address + contact number?
Also, my rear brake is a drum-based, is it possible to convert with rotor + caliper? I don't think to get aftermarket EK4/9 rear disc brake that come with knuckle.
Thank you.
AvanT
360
113
1,543
Bro how much for fabrication bracket for caliper on myvi oversize disc?
Hi Kelvin, we're doing a set of caliper bracket for rm300-350. U can see photos of the CNC machined caliper bracket set we did in my post above. Not manual machine cut & welded method, we do 100% on CNC, 90 degree angle, left-right identical.
Ellipse506
164
5
Hi bro. I need to make custom brake brackets to upgrade my calipers. Where are you located and how long will you generally take?
kim78
Jun 10, 2013
10
Hi Bro, newbie here, do you do adapter for engine's mounting (like engine's mounting adapter when you changed the engine)? 1jz-gte vvti..
AvanT
360
113
1,543
Hi Kim, yes we do, u want to make a proper engine mount for JPJ inspection?
kim78
Jun 10, 2013
10
Yes Bro, did it with other mech, but shody job, anyway it has been endorsed already. .but can feel slight vibration, can you quote me the price for those mountings..thinking of changing it to a proper one, mine is 3 units of mounting (4x4).
Thanks in advance Bro..
LEXUS, known for their smooth and silent running vehicles, performance, build quality, luxury and often times heft is headed for the 2012 Pikes Peak International Hill Climb with their IS F Circuit Club Sport Racer (CCS-R) will compete in this year's race towards the heavens...
