Have two used items to be sold as a package,
6 drive Potent Booster, bought new at RM 680 (ONLY for 2013 onwards Madza 6)
Ori Pivot Mega Raizin(purple), bought new at RM 390
Still in good working condition. selling coz getting new toys for thecar
Selling both as package at RM 350
6 drive Potent Booster, an advance throttle re-mapper is a plug n play device (no cutting of wire) that is attached to the electronic throttle to improve the response of your car. Most car with drive-by-wire throttle controller will benefit from using this device. Enjoy immediate improvement when you step on your accelerator with its 9 levels sports mode for increased throttle response, 9 levels racing mode (full throttle 1:1 response) for when you want to let loose. Stuck in a traffic jam? Use the 9 levels economy mode instead for decreased throttle response. You can always go back to your stock mode by using the normal level.* In short, this device unleashes the true potential of your engine.
Please take note that while this device increases the throttle response, it does not add horsepower.
Why Potent Booster?
1. Shortens the response time of the electronic throttle (quicker overtaking, better uphill start, better downshift response)
2. Improves the electronic throttle's sensitivity (don't take our words, try it to believe it!)
3. Plug n play without external power supply (absolutely NO CUTTING of wire & DOES NOT use OBDII socket)*
4. Total of 6 user selectable mode & grand total of 46 adjustable levels (9 levels Racing adjustment for manual & auto, 9 levels Sports level for manual & auto, 9 levels ECO level & 1 stock mode)* (for 6 drive version)
PIVOT Mega RAIZIN Volt Stabilizer (purple)originally comes from Japan, with the functions as following: *
* Increases torque at low and middle speeds.
* Stabilizes idling and improves engine kink-over.
* Improves engine response.
* Increases headlight brightness.
* Improves fuel economy.
* Improves battery life.
* Improves bass sound.
Why Potent Booster?
