[WTS] SPY Card Type Vehicle Immobilizer / Anti-Hijacker
Overview
Transponder immobilizer with anti hijack function
Retail market price: RM599
Buy now for only RM299
The anti-hijack function works in such a way that your vehicle will not be driven far away from the spot where you are forced out from your vehicle.
To make it more difficult for the thief to reconnect the interrupted circuits, the wires from the control box are black in color hence it is difficult for the thief to identify the wires that break the circuit.
This immobilizer system is a new generation anti-theft system with the most advanced technology.
It not only prevents theft but also prevent carjacking. This system could install on any vehicle
while won't destroy the original electrical system. It is very difficult for a theft to find an alarm
system had been installed in the vehicle as the driver no need to make any operation but only take
the key into the range of communication. But be sure the key should be within rang of 3-5 meters.
This system can also work very well with a car alarm with engine start function.
Operation
If the smart key is within range of 3~5 meters, the system will be activated automatically, a
melody sound emits from the system an LED flashing from the key to confirm the
communication is successfully. If the key is out of range 5 meters, when engine started for 5~7 seconds,
the system will alarm max. 10 seconds continuously, furthermore, the sound's
speed is faster and faster in last 5 seconds to warn the driver that the engine will die off, but
the system won't die off if the car is stopped moving during alarming, if your car moves again, it will die off
immediately, because this system is built-in an advanced accelerometer sensor.
Easy to use, just keep the sensor card provided with you and your vehicle will be immobilized.
Overview
Operation
