[wts]Pennzoil Platinum 100% synthetic 5W40 with polo shirt
AccordRacing
2,282
kepong
www.zhapalang.com.my
Pennzoil Platinum™ 100% Synthetic Ultimate Protection 5W-40 API SM/CF
Picture:
click here
Pennzoil Platinum™ 100% Synthetic provides the Ultimate Protection. It's a unique blend of highly refined synthetic base oil coupled with a proprietary additive package. This special combination creates a superior layer of lubrication defending your hard-working engine and helping to protect it against wear generated by heavy loads, extreme temperatures and severe stop-and-go driving. No conventional motor oil or synthetic blend comes close. New engines keep running new, longer.
  • Pennzoil Platinum™ 100% Synthetic gives Ultimate Protection with:
    [*]Superior* anti-wear protection and consistent engine performance,
    [*]Molecular uniformity of fully synthetic formulation to maintain viscosity, for easier start-ups, even in extreme weather conditions(hot and cold)
    [*]Time-released molecules continuously lubricate, cool and clean, creating a cushion of protective lubrication against extreme high engine temperatures caused by stop-and-go driving and short trips.
    [*]Superior* resistance to shearing under heavy loads to keep your engine running stronger, longer.
    [*]Outperforms conventional and synthetic blend motor oils in the latest American, Japanese, and European automotive tests.
*Note: Superior versus conventional and synthetic blend motor oils.
All Pennzoil motor oils are formulated with time-released molecules, providing a sustained level of superior protection. These anti-wear additives trap and remove the corrosive by-products of engine combustion. After doing their job, more addictive surface to ensure that your engine's moving parts-hundreds of them-are protected from friction, oxidation and extreme temperature.
Promotion:
free 1 exclusive pennzoil/puma collar T-shirt - click here
rm110/4L
Delivery:
-shipping rm5 for KL area
-Lorry transport for peninsular address which is shop/office in major cities/towns - Charge rm5~rm10, pay the transport when item arrive.
-shipping to east malaysia:TBC
AccordRacing
2,282
kepong
one of the best value fully synthetic in the market now
howlingblues
74
pj/ip
howlingblues.multiply.com
Hi AccordRacing,
Pls clarify your statement saying its Toyota official oil.
Do you mean those Black bottle per liter pack "Toyota Fully Synthetic Oil" is actually Pennzoil Platinum?
Or PP packing actually has written its genuine Toyota oil?
AccordRacing
2,282
kepong
as the pennzoil salesman told me, yes, but this penzoil platinum is more higher grade than the "toyota" packing since this is SM grade n toyota is just SL grade.
AccordRacing
2,282
kepong
AccordRacing
2,282
kepong
just read my signature below, if u comfirmed need it, i will arrange it and send it to u.
hello all,
i got the GAB SS series adjustables for my vios. so, i will be spending time tweaking it! however, some queries below:
1. my front spring rate is 6kg and my rear is 4kg. with my damping set to hard, the car is bumpy, but in corners, slight body roll is noted. should i up my spring rate to further reduce body roll, or is slight roll acceptable? I have thought of installing anti-roll bar to the rear, but was advised not to do so as it may distort the suspension from doing its...
