Thunder 6500D Mono-Block Class D Amplifier
Its a Used Mtx 4 channel Amplifier with high rating. 75A fuse. U judge ur self wheather is a great amp anot (normally, to see the amp power, see its fuse rating. High mean more power.)
Featuring MTX Audio's Adaptive Class D Technology, Thunder6500D has a low pass crossover, variable from 40Hz to 200Hz. We provide both low level and high level inputs, with MTX Audio's "Smart Engage" function to allow for easy installation. We even include our patent-pending compression circuit to protect your woofers when you've got it turned way up.
Specifications
Power 12.5 VDC
Input
2 Ohm Load
500 w x 1
Low Level
4 Ohm Load
250 w x 1
Hi Level w/ Smart
Crossover(s)
Power 14.4 VDC
Low Pass 40Hz-200Hz -
2 Ohm Load
775 w x 1
Variable
4 Ohm Load
450 w x 1
RCA Output
Low Pass Only
Dimensions
(with ISO Feet)
Other Features
Compression Circuitry
11.5" x 9.75" x 2.1"
Thunder EQ
29.2cm x 24.8cm x 5.3cm
EBC2 Port
For more info on this product please visit http://www.mtx.com/caraudio/archive/thunder6500d.cfm
Specifications
Power 12.5 VDC
Input
2 Ohm Load
500 w x 1
Low Level
4 Ohm Load
250 w x 1
Hi Level w/ Smart
Crossover(s)
Power 14.4 VDC
2 Ohm Load
775 w x 1
Variable
4 Ohm Load
450 w x 1
RCA Output
Low Pass Only
Dimensions
(with ISO Feet)
Other Features
Thunder EQ
EBC2 Port
