[wts] liqui moly engine oil
Car Culture
jaesern
15
9
1,503
Item(s): ENGINE OIL
1. LIQUI MOLY SYNTHOIL HIGH TECH 5W40 (Fully Synthetic Oil) 4L - RM228 / 5L - RM268
Energy-conserving oil for today’s engines. Reduces oil and fuel consumption. Optimum lubrication even under extreme operating conditions. With thermally-stable wide-range viscosity. Immediate lubrication during cold starts and optimum oil pressure at all engine speeds. Lubrication is also reliably maintained at extreme temperatures. Optimum engine performance. Improved protection against wear and extended service life for the engine. Tested on catalytic converters and turbochargers.
- long service life for the engine due to very high level of protection against wear
- miscible and compatible with commercially-available engine oils.
- rapid oil delivery at low temperatures
- very high lubrication reliability at high and low temperatures
- very high shear and ageing stability
- outstanding engine cleanliness
- smooth engine running
- saves petrol and reduces pollutant emission
- optimum oil pressure at all engine speeds
- tested with catalytic converters and proven performance with turbochargers
- extremely low evaporation losses
SPECIFICATIONS & APPROVALS
API SM/CF
ACEA A3-04/B4-04
MB 229.3
BMW Longlife-98
VW 502 00/505 00
Porsche A40
___________________________________________________________________________
2. LIQUI MOLY MOS2 LEICHTLAUF 10W40 (Semi Synthetic Oil) 4L - RM130
The MoS2 anti-friction lubricant forms a high load-bearing film of lubricant on all friction and sliding surfaces. The MoS2-lubricant film reduces the resistance to friction and allows engines to run -- so they conserve more energy even under extreme conditions. MoS2 Energy Conserving guarantees: significantly less fuel and oil consumption. Significant wear reduction, fewer breakdowns and emergency lubrication properties. Stable to ageing and stable viscosity. Good cold-start behaviour and high operational reliability. Prevents sludge formation. Tested on catalytic converters and turbochargers.
- suitable for petrol and diesel engines with and without exhaust-gas turbocharging and with and without charge air cooling
- rapid oil delivery at low temperatures, good cold-start behavior
- very high protection against wear, limp-home properties due to MoS2
- good ageing and viscosity stability
- tested for catalytic converter compatibility
API SL/CF
ACEA A3-04/B4-04
3. LIQUI MOLY MOS2 LEICHTLAUF 10W30 (Semi Synthetic Oil) 4L - RM125
MoS2 Low-Friction SAE 10W-30 is a modern, all-year-round and low-friction engine oil formulated from selected mineral and synthetic base oils. The high additive content which includes the solid lubricant molybdenum disulphide (MoS2) guarantees optimum lubricating action under extreme running conditions and with long periods between oil changes.
API SL/CF
ACEA A3-04/B4-04
4. CERATEC (Oil Additives) 300ML - RM169
CERATEC is a high-tech ceramic wear protection product for all motor oils. CERATEC reduces friction and wear due to ceramic compounds that withstand extremely high chemical and thermal loads. Prevents direct metal-to-metal contact, thus increasing the engine service life. The low-friction effect reduces fuel consumption in gasoline and diesel engines. Sufficient for 5 liters of motor oil.
- Mixable with all commercially available motor oils
- Stable even under high thermal and dynamic permanent loads
- No deposits and absolutely compatible with all commonly used filter systems
- Resists extremely high and low temperatures
- Reduces fuel consumption
- Increases engine service life
- Increases smooth operation
- Stable under extreme pressures
- Chemically inert
- Higher performance gain due to reduced friction
- Does not increase the phosphorous and sulfur content of the motor oil
- Tested with catalytic converters and diesel particle filter
Dealing method: COD ONLY!
Location of seller: Along LDP from Tesco Puchong to Tesco Mutiara Damansara (Puchong, Sunway, Subang Jaya, Petaling Jaya, Kota Damansara)
Contact method: O126699365
Reason for sale: TRADER
Notice: New Price Effective Immediately on 19th June 2012 (Tue) 12am
Anyway around kl or selangor doing custom* engine parts like customer intake manifold and crankshafts?
