[WTS] Geniune Pivot Raizin product
XDMoNSterZ
65
www.xdmonsterz.blogspot.com
PIVOT Raizin volt stabilizer, comes with options: with or without Super Earth spark plug earth tune-up system. Including all installation hardware and manual, made in Japan.
- Increases torque at low and middle speeds.
- Stabilizes idling and improves engine kink-over.
- Improves engine response.
- Increases headlight brightness.
- Improves fuel economy.
- Improves battery life.
- Improves bass sound.
Pivot RAIZIN VS-1
rm150/unit
Pivot RAIZIN VS-E
rm240/set
Type S can be easily wired by a one-touch connection to the interior fuse box (ignition). It is also possible to switch the power between +B (normal power) and IG+ to match your car model setup. Moreover, peace of mind comes in knowing that the unit is equipped with a delay circuit to avoid trouble caused by power bursts during battery recharging when using IG+ ON.
Pivot's exclusive newly designed condenser, which includes honeycomb shapes in various places, has superior frequency response characteristics that help to bring about incredible noise reduction and results in more stabilized voltage, as well as, achieves both optimum high frequency wave responsivity and improvement in electrical capacitance.
-Torque and Response and Power
-Improved Fuel Efficiency And Engine Kick Over
-Stabilized Iddling
-The Hushed Sound Of An Engine
Pivot Raizin VS-S
rm280/unit
greatly improved due to a more stable ignition which is brought about by the double effect of a strengthened earthing system and the noise filter circuitry that quickly suppresses noise when the ignition coil fires.
-Improve Torque and Response and Power
-Increase mileage
-Stabilized Iddling
Pivot RAIZIN Spark Earth
rm180/unit
The additional earth wire on our Composite Earth Cable has a conductor circumference 2.5 times the normal wire. This improves the firing speed by reducing voltage loss and increasing conductivity of high frequency waves released by the ignition coil. Moreover, by facilitating ionization during combustion, it improves gas mileage and engine torque. (Patent pending)
In a normal wire, the current density in a section of a conductor in response to frequencies are 10kHz=98%, 100kHz=40%, 500kHz=8%, 1MHz=0.4% with the higher the frequency the more the current concentrates in the outside wall of the conductor resulting in poor conductivity. However, our composite design with a widened outside conductor wall provides superior conductivity for high range frequencies.
Due to differences in electrical design, the increase in performance level will differ by car model.
Pivot Ignition Earth Cable
Rm210/Unit
Voltage Stability brings Improved Performance
-Engine Torque
-Audio Quality
-Mileage
-Light Illinance
Checking Voltage gives Protection from Performance Loss
-Lower Voltage means Lower Quality Sound / Unstable Operation for all Electronic Devices
-Low Battery Charge
-Battery Life
By simply inserting into the cigarette lighter socket, you can not only improve the performance of electronic devices by supplying a stable source of voltage, but it is also possible to check the current status visa the voltage meter.
*V capa is based on insertion into the cigarette lighter, but if necessary you can still attain superior results with direct connection as well.
VCapa Voltage Meter with Stabilizer
Rm280/Unit
NOTICE OF FAKE RAIZIN
notice for fake pivot stuff
Shipping FOC to KL area
Shipping FOC to peninsular malaysia
Shipping charge Rm5 to east malaysia
brother
87,094
18
5,138
cheras,kl
did u have sell pivot earth cable? please pm me the price thank...
jcvun
235
Hi Bro....do u have only ori pivot grounding cable? or just sell the cable to me without the V.S. Pm me...thank
XDMoNSterZ
65
i got sell the only cable
but currently no stock. will inform u when i got the cable
thanks.
apismahmud
9
hai hafiz here from Subang just wondering .... this product still available or not PIVOT VCapa Volt Meter with Stabilizer is it ok to use together with voltage regulator VS 1 (0193690794) HAFIZ tq
XDMoNSterZ
65
apismahmud
pm sent, thanks for support dude.
Source: Malaysian Digest
A driving license is considered by most as a substantial milestone in life akin to getting a credit card, buying a first home or being hired for a first job.
As Malaysians we are known for our warm behaviour and expressive nature, yet when the subject of Malaysian drivers comes to mind, one can’t help but express a considerable amount of concern on the...
