AXT (AUSTRALIA) PERFORMANCE DISC BRAKES & PADS
* Standard Size & Oversize Brake Discs Available
* Suitable For Most Cars
* Made In Australia
* Oversize Cross-drilled and slotted performance brake discs for ultimate braking with more than 30% over standard
* Highest grade cast iron to prevent discs warped
- its max. temperature generated is lower than OE discs
- TUV tested
* Use matching AXT Brake Pads and DOT 5 Brake Fluid for ultimate braking performance
* NB: Part number is per brake disc kit with all brackets and parts to fit
- Efficiency of brake pads deteriorate very fast with high temperatures
- AXT brakes are for street use at max. 300 to 500 degrees
- A lot of other factors contribute to good braking, not just brake pads
AXT PERFORMANCE BRAKE PADS
* High performance brake pads (abestos free) with special formulated compound for
effective braking with minimum fading, long life and minimum dust
* Use matching AXT Performance Brake Discs and DOT 5 Brake Fluid for ultimate braking performance
* Made In Australia
- TUV tested
