lolzz...Try my way... confirmed cheapest!!!
Step to do:
1. Find the speed signal at socket of ECU
2. Just cut off the speed signal wire....
3. Happy driving!
yaya..pivot speed meter is quite cheap..rm200++ can get ade..[/QU
Bro,
Which Brand of pivot speed meter..
apexi rsm very expensive lor..
using this item means original speedo meter will not functionlah. is it?
how bout rpm?
Ho.. which model will that be?.. ada lobang ka?Apexi RSM (old type) can do the following:
Rev count
Speed count
Speed cut remove
Distance count (only available for final model)
Techo function
0-100, 0-200, 0-400 count
Rev warning (preset your limit)
Speed warning (preset your limit)
Another 2 output's function unknown (not stated in the spec sheet). It could be a signal output terminals for triggering external stuff when rev/speed warning was activated.
If this is true, you can wire it to external high bright LED and make it function as a shift light.
The old model 1 la... Not blue screen 1...Ho.. which model will that be?.. ada lobang ka?
this model?
me still learning le please forgive my n00bness
yes... that model... But actually i got limited edition color too (if not mistaken gold color)this model?
