Wtb: Rsm
Ayobjuri
24
1,503
USJ
Hi All.
Want to eliminate speed cut. asking my frenz he suggest to use apexi rsm..
Want to know la.. which model better & easy to use.
Oso pliss share ur experience about tat.
DentPSF
775
or juz go buy Speed Limited Defender (SLD) also very cheap only.....
TRD.AE92
780
40
Try my way... confirmed cheapest!!!
Step to do:
1. Find the speed signal at socket of ECU
2. Just cut off the speed signal wire....
3. Happy driving!
ehdrian
I Don't Care!
3,310
280
1,683
yaya..pivot speed meter is quite cheap..rm200++ can get ade..
AE101-Wong
4,448
113
Step to do:
3. Happy driving!
lolzz...
will have check light after 120km/h la...
and the wiring color is purple..u can try it urself..
if there's no speed signal for ECU, ur FC will be damn high..
not recogmment to do this la bro...
Ayobjuri
24
1,503
USJ
yaya..pivot speed meter is quite cheap..rm200++ can get ade..[/QU
Bro,
Which Brand of pivot speed meter..
apexi rsm very expensive lor..
using this item means original speedo meter will not functionlah. is it?
how bout rpm?
levin818
1,260
321
3,183
Shah Alam
Apexi RSM (old type) can do the following:
Rev count
Speed count
Speed cut remove
Distance count (only available for final model)
Techo function
0-100, 0-200, 0-400 count
Rev warning (preset your limit)
Speed warning (preset your limit)
Another 2 output's function unknown (not stated in the spec sheet). It could be a signal output terminals for triggering external stuff when rev/speed warning was activated.
If this is true, you can wire it to external high bright LED and make it function as a shift light.
RSM will not interfere the function of the original meter.
Simply cutting off the speed signal to the ECU will make the ECU running in limp mode after 120km/h.
You might be loosing up to 10hp, or even 50hp! :biggrin: :biggrin:
ExceL
1,726
162
Ampang/KL
Rev count
Speed count
Speed cut remove
Techo function
:biggrin: :biggrin:
Ho.. which model will that be?.. ada lobang ka?:biggrin:
TRD.AE92
780
40
AD_EG
6,328
231
Ipoh
this model?
me still learning le please forgive my n00bness
I prefer this model anytime...good price and its still function-able :biggrin:
RSM blue so expensive
if you only looking to remove speedcut...then you can get pivot speedmeter V ...BUT for me its not worth it...its super smalll !!! can barely see the numbers.
the old model RSM is worth it....larger display,easier to view..same functions
TRD.AE92
780
40
this model?
yes... that model... But actually i got limited edition color too (if not mistaken gold color)
Market price for this around RM250 to RM 350 only. RSM blue screen market price is around RM 450 - RM500. Both function are about to same only...
My car has been vandalised with spray paint just this morning. and its barely 1 month old!! :bawling: I wonder if anyone out here can advise on the correct method to remove the paint without respraying the whole car? it has never been waxed nor polished before, just the fresh coat of paint right out from the factory.
