bro...where the mit service center you go...want to order something..thanks..
the service center i go to is very new and not big, here in Butterworth, Penang. because it is new, so, not many customers, they are free to help me check the part number, and check this check that.. hahaha...
any service centre will do, as long as they have time to take the trouble to entertain you. it is easier if you can give them part number.. i found a few in the internet. here it goes..
ALL PART NUMBER REQUEST GO HERE - evolutionm.net
All Part Number Request Go Here
Hi guys,
this will be the thread to request differnet parts #s. please do not go OT in this thread because all off- topic posts will be deleted and the users will be warned.
thanks
Snir
EDIT: timzcat
Here are all of the part numbers to this point. Please check here first!
For people supplying part numbers, please try to format it as number description as below. It will make my life a lot easier when updating the list.
Thanks
Body/Interior/Exterior
MR633538 Upper Steering column cover
MR572609 Board, trunk room floor
MR444269 Trim, Trunk room RR end (Grey)
MB547806 Clip, Engine Room Cover
MD569372 air intake rivet
MR288876 hood vent rivet
MR975089 coin box
MN126274 Insulator, Hood
MZ598263 CD Changer Install kit
MR626799 cd changer panel only, no rails (black)
MU480007 licence plate grommet (square)
MN168249 Gear Shift Lever Retainer (part of the gearshift level)
MR286178 Replacement trunk lock
MR633547 panel with the shifter and ashtray and the cigarette lighter
MN161463 RS ~04/07/31 trunk lid
MN161464 RS 04/08~ trunk lid (no spoiler)
MN150620 RS 04/08~ trunk lid (spoiler)
MN161462 MR trunk lid (spoiler)
MN161463 MR trunk lid (no spoiler)
MR574731 front Mitsubishi symbol
MR975477 intake/trunk carpeting fastener
MB547806 front undertray fastener
MB918617 ashtray light
MR412407 RS trunk bar
MN101890 MR bilsteins Fronts
MN101899 MR bilsteins Rears
MR647677 the piece that holds the ashtray and the cig lighter
MR970228 black RS door handles Front Right
MR970227 black RS door handles Front Left
MR970268 black RS door handles Rear Right
MR970267 black RS door handles Rear Left
MR250558 Radio delete panel
MR627152 interior door handle Front Left
MR627153 interior door handle Front Right
MN161534 rear side marker light
MR648031 rear interior door panel (which side?)
MR973540 antenna Base
MR583214 antenna Nut
MR587268 stock radio (evo?)
MR506482 headlight height adjustment switch
MN126920HB 3rd stoplight cover (You have to get the whole light assy.)
MZ380295EX vortex generator
MR962799 03 Evo's clock
MR512557 plastic housing arount the clock and hazard switch
MR954150 Right (Passenger Side) Front Fender
MN161172 Right (Passenger Side) Complete Entire Light (Including Housing, HID) (this is the entire assy.)
MR954176 Right (Passenger Side) Front Wheel well Plastic Dirt covering
MN161277 Hood
MS240129 Bolts for gas tank and rear trunk tie bar
MR572500 Clips for the rear trunk liner
MN151260HA MR Mats (both sides?)
MN126980 Front bumper undertray
MN161109XA Black front bumper cover
MN101464 MR Front springs (same part # as GSR/RS)
4140A007 MR Rear springs
MR538851 Fog Light relay
MN126784HC Lower lip of front clip (comes pre-painted)
MN126771 intercooler grille
MN126979 Left Undertrays w/ brake cooling ducts
MN126980 Right Undertrays w/ brake cooling ducts
MR379950 Center Undertrays w/ brake cooling ducts
MN126784 HC (Pre-painted) EVO8 FRONT AIRDAM LIP
MN126981 PANEL UNDERCOVER FRONT
MN126979 PANEL UNDERCOVER FRONT CENTER
MZ530857 Mud Flap Kit Carbon (Evolution)
MZ530855 Mud Flap Kit - Red (Ralliart)
MR109421 diamond trunk badge for a 1999 Galant.
MR631941 Left a-pillar
MR631943 Right a-pillar
8011A017 MR Sticker
MR795453 02 lancer 0Z switch blank cover
MR573539 02 lancer 0Z Plastic Tabs that go in door handles (left)
MR573544 02 lancer 0Z Plastic Tabs that go in door handles (right)
MR627179 02 lancer 0Z Plastic Trim Ring for Passenger Side Rear Door Handle
MR497518 02 lancer 0Z Air Intake Ram Air Piece
MR233903 USDM cigarette lighter
MR506482 USDM headlamp tilt angle switch
MR627178 02 lancer 0Z Plastic Trim Ring for Driver Side Rear Door Handle
MN161109RA Rally Red Bumper Cover
MN126784RA Rally Red front airdam lip
Metal mounting tabs that secure the mesh grills to the bumper:
MB325298 10 pieces needed
MR447202 2 pieces needed
MN161109WA White bumper cover
MN126784WA White air dam
MS820976 fog light housing
the e-brake handle/assembly (not the cable, just the knob and rubber boot).
MR628249 w/ a build date from 1Dec02-3Dec03
MN102750HA w/ a build date from 1Jan04-3Jul04
MN102750HB w/ a build date from 1Aug04-Present
MN126723WA Front bumper cover section (small painted piece, white):
MU488006 Front bumper clips
MN150450 Right Rear Door Shell
MR647677 Console panel around Shifter (grey)
MN151264HA Radio and Climate control Panel
MR500935, MR500932, MR568314 Climate control labels
MR644580 04 RS Front Left A-pillar panel (no tweeter)
MZ690125 & MZ690130 Front blades:
MR538217 Rear blade:
MR417280 Dead Pedal
MR206570 Dead pedal Cap
MR646881 Ash tray door
MR973541 Antenna Mast
MR973540 Antenna Base
MR583214 Antenna Nut (2 needed)
MU488006 Upper bumper clips cooling area
MR626743 Defroster garnish (panel up by windshield across dash)
MR647724 Front license plate bracket
MR627159 Left front kick panel (next to dead pedal)
MR633500 Right front kick panel
MR538216 '05 MR Rear Wiper , without the motor (This is the arm only)
MR973541 '05 MR Antenna
6370A205 '05 MR Trunk Key Lock
MR654028 '05 MR Passenger door Key Lock (Includes handle)
MN126530 '05 MR Hood Mesh only
MU488006 Clips into the bumper cover for cooling shroud
MR200300 Clips into the radiator support for cooling shroud
MR513027 Recirc door assembly for HVAC
MR548949 Roodf skin No sunroof
MR548950 Roof skin W/ sunroof
MR633889 Armrest lid (suede) with hinge
Drivetrain/Chassis/Suspension
MR232147 Gear link bushing
MF247868 (1) MF140210 (3) MF140206 (6) Cam cover bolts
MD050316 Oil drain plug
MD569372 M/T plug
MZ690116 oil filter
MR552951 air filter
MR407376 Front pad kit (hardware sold separately)
MR407391 rear pad kit " "
MD979313 water pump
MN158794 alternator belt
MD186785 spark plug grommets
MD340535 valve cover gasket
MD152772 pcv valve
MN132206 clutch disc
MR980846 pressure plate
MR145619 T/O bearing
MD746617 clutch slave cylinder
MR491945 clutch master cylinder
MN149074 crankshaft pulley
MR370723 front brake rotors
MN153010 oxygen sennsor frt
MR578532 rear oxygen sensor
MD327107 cam position sensor
MR578117 knock sensor
MD363552 ignition coil
MD343245 plug wires set
MD374841 spark plugs
MR984375 timing belt adjuster
MD369999 timing belt pulley
MN153356 BODY ASSY,AIR CLEANER (Stock Airbox)
MR578399 SENSOR,AIR CLEANER (MAF SENSOR)
MN153284 Diverter Valve
MR475929 Left caliper
MR475930 Right caliper
MD160689 1G Air bypass valve (for anyone using Buschur upper IC)
MN143213 stock boost solenoid located under the airbox
MD372536 cam seals
MN158794 Alternator and other drive belt
MN153284 MR bypass valves
MR450703 donut gasket for the downpipe
MR481252 radiator cap
MR597271 downpipe bolts
MR597273 downpipe Springs
MR497545 studs on the cat
MR571083 downpipe -> cat (nuts that go on the studs on the cat)
MF241309 cat -> cat-back bolts + nuts
1545A001 MR BOV
MD345681 Rocker cover center cover
MD000312 transmission drain plug gasket
MF660036 transmission fill plug gasket
MD000312 transfer case drain plug gasket
MD000312 transfer case fill plug gasket
MB001294 rear diff. drain plug gasket
MF660036 rear diff. fill plug gasket
MR580533 teflon shifter cables MR
MN107670 teflon shifter cables GSR/RS
MN143079 timing belt cover lower front
MN153353 Air Cleaner box cover (top)
MD613573 MR Specific Compressor housing
MD613524 MR Specific Turbine housing
MD613567 GSR/RS Specific Compressor housing
MD613521 GSR/RS Specific Turbine housing
MN155744 Cyl Head
MN143619 Intake Camshaft
MN143620 Exhaust Camshaft
MN137746 Intake Manifold
MN156302 Exhaust Manifold
MN135583 Down Pipe
MR968097 Mid Pipe
MN153192 Rear Section
MD356000 MR oil filter
MZ690116 oil filter (normal?)
MN156784 O2 Housing
MR299686 Metal Gasket to Turbine <-- parts to go with the O2 housing
MD132933 4 x Washer
MD062961 3 x Bolt
MR224441 1 x Stud
MD050073 1 x Nut
MB914617 Front wheel hub assembly
MN153285 front mount intercooler
MN126772 Lower metal mounting bracket for the front intercooler grill
MR370729 lower front caliper bolt
MR407072 lower front caliper washer
MS240121 Air box bracket bolts
MS240142 overflow bolts
MD748267 Evo 5 transfer case (inc helical LSD)
MN155760 03-05 head gasket
MR578634 02 lancer 0Z Front Oxygen Sensor
MR507854 02 lancer 0Z Rear Oxygen Sensor
MN143343 hose line for the blow off valve
MR385780 heat shield bolts
MF434103 MAF sensor nuts (4 pieces needed)
MR554814 RH Lower Control Arm Asm.
MR554813 LH Lower Control Arm Asm.
MB914617 Front Wheel Bearing Asm.
MR455707 lug nuts
MB911495 wheel studs (frt or rear)
MR571545 Fuel Pump Housing
MF241251 Pressure Plate Bolts
MR493288 Front Passenger side metal brake line ABS to Flexible line
MR571544 fuel pump
MN106046 gasket
MB129895 in tank filter
MR571592Air Intake Hose
MN156291Air Cleaner Bracket
MF661135 & MF661142 Band Clamps for air intake hose
MD173306 Band Clamps for BOV
MD151672 Mass Air Sensor Gasket
MR498813 ’04 RS Transfer Case
3200A011 '05 RS/MR T-Case
MN119784 (Manifold-Turbine) Stud
MR224441 (Turbine-O2) Stud
MB555284 Clutch Line Banjo bolt
MF660063 Crush Washers for clutch line
MS240077 Spark Plug Cover bolts
MN156738 Oil return tube gasket (at oil pan)
MR450703 O2 housing exhaust donut
MR323654 Exhaust Manifold gasket (head to manifold)
MD062961 O2 housing to Turbo housing bolts
MN158795 Serpentine Belt – no A/C (RS model)
MN153089 Wastegate Actuator
MD743612 o-ring between transfer case and transmission small
MD727944 O-ring netween transfer case and transmission large
MR266706 Oil feed line
MF660064 Crush washers (turbo side)
MS650013 Banjo bolt (turbo side)
MF650102 Banjo bolt (head side)
MF660063 Crush washers (head side)
MD329503Cam sensor housing cover gasket
MR281085 Lower IC pipe to turbo gasket
MD016483Valve keeper
MD119127 EGR Valve gasket
MN155455 Stock valve cover
MB687014 Midpipe to Muffler gasket
MR464630 Oil cooler
MN143213 Stock boost solenoid
MR475618 Brake Pad Shim set
MR323654 Exhaust Manifold to turbo gasket
1540A019 Intake manifold gasket
MD306079 Valve seal Intake
MD307343 Valve Seal Exhaust
MD613507 CHRA (Center section, turbo)
MD604696 Fuel rail feed o-ring
MB554317 Fuel rail return o-ring
MD180361 Throttlebody gasket
MN163343 Oil pan
MR258477 Oil drain tube to turbo gasket
MD132806 Cam cap dowel pin
MN158072 PCV valve hose
MD152772 PCV Valve
MF244879 Turbo support bracket and bolts
MD363254 Head-Coolant housing gasket
All 4 mounts engine and transsee #514
MR491558
MR594455
MR554434
MR554653
Mount bolts see #504
MB569372 Trans. Drain plug
MD701850 Trans. Fill plug
MB001265 Transfer drain plug
MD701850 Transfer fill plug
MB569390 *Rear drain plug
MB001261 *Rear fill plug
* Crush washers included.
__________________
*** PLEASE READ! New Policy regarding Scammers ***
Please read our policy concerning flaming, off topic and belligerent post.
