Works Mitsubishi 4G18 / Mit Lancer CS3 Cam Gear
xiaoting
145
Johor Bahru
Each Gear is adjustable in 1° increments to a maximum +/- 10°.
Our engraved timing marks are accurate within 1 minute of degree!
With the simpler design our gears end up being light than the stock gears they replace.
Our tooth profile matches the OEM spec exactly for each gear we make.
The outer cog section of our gears is black hard-anodized, to prevent on/wear from the timing belt.
We use black hard coat because of the great contrast it gives against our engraved timing marks.
The 5-bolt locking pattern is plenty secure and we use only stainless steel hardware to ensure durability.
This design provides a lifetime of worry-free adjustment.
Machining for optimum component fit is critical with adjustable cam gears.
Any free play between the inner and the outer sections will cause the hardware to come loose no matter how much is tightened.
Our extra care in the machining process guarantees you our gears will not come loose when you follow the torque specifications in our instructions.
Horsepower gains can vary widely depending on what has been done to the vehicle and how it is used.
Gains from 5 to 20 horsepower can be realized.
Interested please contact us
016-711 0084(Wing)
07-3877009(office)
We are located in Johor Bahru
No.4,Jln Permas Jaya 9/10, Permas Jaya 80150 Masai, Johor.
xiaoting
145
Johor Bahru
016-711 0084(Wing)
xiaoting
145
Johor Bahru
016-711 0084(Wing)
xiaoting
145
Johor Bahru
016-711 0084(Wing)
xiaoting
145
Johor Bahru
016-711 0084(Wing)
07-3877009(office)
xiaoting
145
Johor Bahru
016-711 0084(Wing)
07-3877009(office)
xiaoting
145
Johor Bahru
016-711 0084(Wing)
07-3877009(office)
xiaoting
145
Johor Bahru
016-711 0084(Wing)
07-3877009(office)
xiaoting
145
Johor Bahru
016-711 0084(Wing)
07-3877009(office)
xiaoting
145
Johor Bahru
016-711 0084(Wing)
07-3877009(office)
Unveiling the limited edition Opel Corsa OPC Nürburgring edition. Stunning design, innovative technology, unmatched dynamism, pure emotion and passion. These are the qualities that the models of Opel OPC features. There is a planned production of 500 units. The Corsa OPC Nürburgring has a OPC 1.6 Turbo engine capable of 141 kW/192 hp. Visual highlights are two new exterior colors, redesigned 8x18-inch alloy...
