Win XP can't read CD-RW discs
satria_95
6,000 RPM
6,746
18
5,138
Malaysia
I've got this cd-rw disc which was formated with Win 98 SE. Now that I'm using Win XP, I can't seem to read the files in the cd-rw discs. It's got an error as below.
This disc contains a "UDF" file system and requires an operating system that supports the ISO-13346 "UDF" file system specification.
I'm using Win XP SP2 and InCD.
If anybody who has faced this problem, has already solved it, kindly assist in to provide the solution to this.
Thank you.
TypicalGuy
1,111
u salah burn lar...
ISO problem
just use ahead nero and burn....use correct format..
dont use UDF or whatever....
use cd copy or data cd...
dont choose other option..
satria_95
6,000 RPM
6,746
18
5,138
Malaysia
TypicalGuy,
Seems like this month is CD problem month for me la. hahahaha
Anyway, I tried InCD, and this and that, still no use. However, all also cannot except when I use cdroller software. but since it's trial version, it doesn't allow me to download the files to my pc.
Anybody got the crack or serial? hehehe
TypicalGuy
1,111
use ahead nero burn ..
dun wan find the crack for you..later kena spyware
fstr
7,000 RPM
7,935
954
3,213
Sahara Desert
kenot read meh? i am using xp also wor can use cdrw play apa lanjiao also can hhrhehehhehehehehee:biggrin:
gloss
1,546
SJ
use Nero software to burn ur cd, dun use window xp burner.... juz try few days ago...
satria_95
6,000 RPM
6,746
18
5,138
Malaysia
Thanks for all the replies, dudes and dudettes. I tried all suggested, still can't. The only working one is still cdroller. hehehe
gloss
1,546
SJ
u sure ur cd-rw is not protected?? hv u use this cd b4 or juz bought?
psyk
415
if from win98se, with that error message by installing udf reader driver it should work.. try reading the cdrw with a win98se machine see if it works.. if yes then sumfinks really wrong with your cdrom ler.. dvd9 oso cannot read.. throw away ler.. kakakaka..
satria_95
6,000 RPM
6,746
18
5,138
Malaysia
psyk,
The dvd 9 problem has been fixed. Changed the unit under warranty. hahaha
gloss,
Yes, I've used the cd-rw disc before but in win 98 SE. Good thing I still have dual boot. I manage to get the files under Win 98 SE, and copied it to a folder on my hard disk. Then I booted in Win XP. Now there's yet another question.
I'm using InCD. After formating, Win XP says that the disc cannot be used. What a crap. Will try other stuff tomorrow la. hehe
psyk
415
got earlier posts asking u to use nero .. u still using incd... indiot la u.. :D
gloss
1,546
SJ
psyk,
dun scold him la.... hehe :biggrin:
he is learning also man... but XP shld be no problem le... mine is ok... i try figure it out again... post later
Photography:
-Ldragon
-Tom
Images: 225+
Pages: 5
Report by: .S.K.A.G.E.E.
Last night was definitely a night to remember,
It was the first time the Expert group had the opportunity to go in reverse direction on the track which proved to be challenging even with skills and experience that some of the Expert drifters had! I might...
