Why suddenly ABS indicator popped up?
VTEC LoVeR
994
112
543
Kulim
Hi sifu, any idea on this? Means my ABS system faulty or something wrong with my car? Btw, my ride is 2012 Exora Bold CFE... :confused:
cvkit17
2,884
1,354
Faulty ABS. Another method to see if ABS is working or not is to test it. Find a safe road, drive up to 40-50kmh then slam the brake hard. If the pedal and brake vibrate then ABS is working. If the tyre skid that means you are bringing back the car to SC.
My friend's Saga FL had the same problem before.
Did you check the brake oil level? Check to see if the connector at the master cylinder is properly connected. Loosen connectors is common in Protons.
If all is ok, just bring it back to Proton for warranty. If no warranty go to a mech for diagnosis. If not mistaken, ABS will only trigger if you're at 90km/h and above when you jam brake.
YYC
1,833
939
Danz,
You have mentioned in another thread that washing engine bay may cause ABS problem. How is that?
DanzEterna
15,911
3,371
www.primeperdanaclub.com
is the abs module is not covered properly it may cause the abs to malfunction, very common in proton cars.
especially engine washed by roadside car wash, the best is to cover the abs module with aluminum foil properly.
peterj
1,321
258
1,683
Kuching
Abs will kick in at low speed,around 20+- kmh,less than that no abs
VTEC LoVeR
994
112
543
Kulim
Thanks all the advice given.
1. Will check on the brake fluid level and also the connector
2. Try to test the e-brake after work
3. If anything wrong, then is time to 'burn money'...:banghead:
cvkit17
2,884
1,354
no la...kick in when there is uneven rotation if not mistaken. 50kmh can skid already if the floor is wet
2 years only, not covered by warranty?
VTEC LoVeR
994
112
543
Kulim
I'm forgot on the warranty time frame. 2/3 years probably... but still kena labour charge mah...:banghead:
gunnerzz
Jul 3, 2014
2,109
695
Melaka
Its the ABS sensor.
No need to check,same problem with the bold in my family.
Already claim twice.
If not mistaken its the sensor at the front.
its covered by the warranty.
and...in my casr.no labour charge.
VTEC LoVeR
994
112
543
Kulim
Its the ABS sensor.
Thanks for the info bro... can I go to authorized WS to settle this or must have to go to CS?:confused:
---------- Post added at 09:02 PM ---------- 6 hour anti-bump limit - Previous post was at 09:01 PM ----------
Sorry, I mean SC... blur edy...
Before you do, check for loose connections. Sometimes a simple solution will save a lot of time with SC
<a href="http://www.zerotohundred.com/newforums/automotive-news/159107-nismo-s-tune-latio-tiida-body-kit-concept.html"><img border="0" src="http://www.zerotohundred.com/news/may/nismo_latio/banner.jpg" width="250" height="75" alt="Nismo Latio"></a><p><b>Nismo S-Tune Latio</b></p><p>Since the Nissan Latio was launched here yesterday, The Nismo S-Tune Latio will become very relevant to what will fill up the roads very soon. Just like how the Mugen's tricked out City's and TRD's Vioses did...
