Why my MIVEC so SLOW??
mika_mivec
139
Kedah
change to gsr block,use 87mm piston,ca18 conrod,s.plug iridium,injector.oso do extractor.my 2 cent:biggrin:
wirahybrid
72
1,508
wirahybrid.blogspot.com
mikanaem, r u sure tht ur mivec bukak or nt (meaning ur secondary cam profile was not activated)?? cuz sum of my frens had the same prob, mivec tak bukak n wen they got it fixed, it was smooth sailing there on out. have tht checked first b4 u start doin any heavy mods...:nurse:
gsr block wit 87mm piston??? the ori bore is 81mm. if rebore till 87mm the block sure koyak dy. max also 83mm - tx3 piston.... unless someone has done this:confused::confused::confused::confused: 82mm oversize is gud enuf dy.
mikanaem, if u wanna change block, then i wud suggest gettin the 4g93 GDI block wit its stock stroker kit cuz i heard tht u cn get a cr of 11.0++(hope the sifu's out there cn rectify if this is true or false) tht is if u wanna play NA...other thn tht change to bigger injectors, open pod air filter, aftermarket headers, iridium plugs, lightened crank pulley, adjustable cam pulley, walbro fuel pump, fuel regulator, bigger capacity fuel rail n put a mivec sticker on ur windshield:biggrin::biggrin:.. n if u really have the budget, go 4 jun cams, port n polish, acl bearings, bigger tb, standalone ecu n sum semi slick tyres. just my 2 cents
---------- Post added at 04:56 PM ---------- 6 hour anti-bump limit - Previous post was at 04:15 PM ----------
peterj
1,321
258
1,683
Kuching
bro... try 1.8 block to ur 1.6 mivec.. big big different..... remember to get a gud racing clutch to hold the power...... piston i recommend to use back ori mivec high compression piston is enough... when u do this mod, better use higher cc injector(gsr 390cc is enough) and thicker metal gasket (ppl tell me to use 1.2mm or 1.5mm better) then u can feel big different from 1.6...... dun forget to get a adjustable fuel regulator, bigger fuel pump and redo ur piping :burnout: happy modding mivec
Owners of Proton vehicles sporting automatic transmissions can now have optimum performance for their torque-converter equipped gearbox with the specially-formulated ATF-XP3 Automatic Transmission Fluid that was jointly developed by Proton and Petronas for use in Proton vehicles.
Formulated from refined high viscosity index unconventional base...
