hello all sifus..
i juz stepped in the world of force induction.. so i'm still quite blur with it..
currently i'm using daihatsu L9 engine with hybrid turbo..
so sometimes i rev gao gao the check engine light will on.. i went to check ecu n found out there is a fault code with o2 sensor.. n the signal showed it's lean.. so i went for dyno tune with safc..
the result of dyno was the fuel is insufficient.. no matter how much fuel tuner add.. still not enough.. so the tuner told me i better change the fuel pump.. tht was alright..
after tht i felt my car was so underpower after add so much fuel..(more than 10% at hi throttle)
so i tried to decrease the fuel.. weird thing is.. the car bcome more powerful.. den i decrease again.. to bcome -ve.. more power..
so now my questions r..
1. wad's wrong with the afc?? is it the wire terbalik pasang?
2. if really insufficient fuel supply is it necessary to change fuel pump? (i'm boosting @ 1.1 bar) or juz add fuel regulator will do?
ur help will be very very appreciate!! thanks!
