UTR High Performance Drop In Air Filter For Wira/Waja
khguan
4,818
26
Seri Kembangan
fotopic.net
Upgrade the intake system without any modification. Simple plug-n-play drop-in filter to increase horsepower and torque for a better driving experience. Filter element is washable, long lasting and low maintenance.
PRODUCT RANGE:
MFOEM (Metal Flow - Stainless Steel Element)
SFOEM (Super FLow - Microfiber Element)
Suitable for the following models:
- Wira/Satria/Putra Fuel Injection (1.3/1.5/1.6/1.8)
- Waja (1.6/Campro)
- Lancer/Colt
INSTALLATION: FOC
WARRANTY: 1 year
THE EA TEAM
khguan 012-270 8685 | drexchan 019-359 3909 | howiechoo 012-767 1360
CLICK HERE FOR MAP | CLICK HERE FOR MORE PRODUCTS
Alcon06
322
What's the price for 2 of the models, between the 2 of it, which will need more frequent maintenance or does it require re-oiling?
khguan
4,818
26
Seri Kembangan
fotopic.net
maintenance is just simple cleaning during your engine oil service interval... if u like u can actually clean the filter every week.. up to u... the cleaner the filter.. the better the engine breaths.. ;)
UTR filters do not need to be re-oiled... just clean with water can already.
btw pls call for the price. THanx!
khguan
4,818
26
Seri Kembangan
fotopic.net
bring up the post!
---------- Post added at 11:58 AM ---------- 6 hour anti-bump limit - Previous post was at 11:54 AM ----------
bumpbum[p!!
The Marketplace Top Posts
Normally there are 2 source of leaking from them. The rubber surrounding the door loose or damage liao OR most likely the water proof plastic sheet inside the door got holes or not seal properly.
I would suggest to dismantle the door panel and change or reseal the plastic sheet that prevent water from seeping in thru the door ala windows gaps as a first measure to check if water comes from there.
[snapback]61422428[/snapback]​
