Tuning with E85(Ethanol) nets big power
APTuning
but in Msia why E85 ? , we do not have snow or cold weather, we should be running e98 :P
Try get it e98 and compare with e85 on your tuning.
The black satria Jmf use e85 not e98.you can smell...ask that guy.:biggrin:
be careful with the grade ethanol there are 3 types 97.9%,98.9% and 99.9%.
97 and 98(same as Methanol Industrial) have a lot of water mixed, miss firing on high boost and high rev engine.the wrong choice will cause the engine breaks
jo1
392
25
3,028
I have used the mixture of Ethanol and Gasoline (E85-E90) also neat ethanol E99.99 for my drag car. The most important thing is your fuel system setup. It required around 20%-30% more depend on the blend. Set up the fuel system correctly and you will get the benefit of using it. Boost it to the Moon.
APTuning
angkelfake
44
3,008
when I went down to the SDB, I smell two cars use Etahnol, black saria JMF intake, Motec Silver Honda EG.
We can supply for you and someone for tuning research for race.Pls let me know how many barrel you need.
Small injectors stock engine, you give more pressure on your regulator.
If you are running aftermarket ECU,add 20-25% rich AFR on Idle compare with Gasoline
Example Gasoline 14.7 afr on idle,Ethanol must 13.0-12.5 afr.But depends on your Compression rasio
Also recomended to change bigger Injectors 1000cc or 1500cc.
Single Walbro pump are good enough for street race 500hp motors.
interesting... we've been doing research on producing e85 here in m'sia with 2 different agencies... the 1st phase (producing) has just been completed last year, and most probably we're gonna continue our r&d on the application..
say if this r&d of ours do continue, can u help out in the modification parts?
been thinking of using a stock standard gen2, a NA modified engine (maybe vtec) and an upgraded turbocharged engine (maybe an evo 3 or sr20det or rb25)
---------- Post added at 12:11 AM ---------- 6 hour anti-bump limit - Previous post was at 12:08 AM ----------
oh yea.. and another thing is... the ecu... do we have to swap it? or do certain remapping or so?
APTuning
All Engine can use E85 and make a better power and good torque.Yes have to remapping or swap to standalone ECU.Bigger Injectors.
bro APTuning....since u have experience in tuning ethanol e85 can u comments about different of a/f ratio compared to normal pure petrol.....
like as example if running pure petrol a/f ratio around 14:1 then how about the a/f of same engine and configuration when on e85?
e85 also allows more aggressive ignition timing rite??? :adore:
ahmedshaikhani
114
56
528
Pls look the table.
but the difference CR for ignition timimg.
High Octane more aggressive .
Please clear my confusion you mean to say with RON 97 AFR of a boosted car on idle should be 14:1 or 15:1 depending upon engine to engine and on boost AFR should be between 11:1 or 11.5:1. When we opt for E85 so the AFR on idle should be 13:1 or 13.5:1 and with boost it should be around 10:1 or near ? Am I right ?
The Marketplace Top Posts
Our third and final installment of the MMER 2011 event with less circuit but more pit action as well as podium appearances of the winning team drivers. The emotional win for Petronas Syntium Team was well documented by our resident photographer, Andy Goh...
