Tire Price list Zth
I see...Got it on that.....
But if is not low profile tyres.....How to do check or know if is hard or soft?
Read back, I just added/edit more info...:driver:
To above question, it depends, first go by profile, means usually the higher the softer, meaning like 70 and 60 series, with thicker sidewall they have more flex thereby softer.
For 55 to 45 series, depends on tyre model, some may have soft sidewall construction
But for 40 series and below usually will be harder. Even if not hard the air pressure need to be higher. The less air space of ultra low profile tyres will need more air pressure to hold the tyres in place.
70 & 60 series just need 28 to 30 psi, my 45 series using 33 to 35 psi, or like small bicycle tyre they need 45 to 55 psi of pressure.
marv3
496
57
528
Which page to rad back bro VR? this thread about 160 pages leh...Hehehehehe
40 series usually need how much pressure? My current 225/40/18 i put 40psi....Too much ah?:confused::confused:
6UE5t
6,000 RPM
6,756
1,300
Prodrive rims? Those aren't PCD100 x 4. Can't la.
And V12 is soft sidewall, I've driven a car with it in the past and I wasn't too impressed or disappointed. But different size means the impression isn't really accurate.
Assy2 sidewall imho was hard. Not as hard as the RSR, but hard nonetheless.
And I'm becoming increasingly annoyed with the slow response from the tyres everytime I accelerate. It's bad enough the CVT is rubber-band-ish and now it's further held back by these tyres. Ish.
Oh I thought your car PCD is also 5x114.3, never mind then.
That V12 you tried the first version or already this latest Evo 2?
Hmm if the F1 sidewall is hard to you then ok lor, coz F1 is still considered comfortable too.
---------- Post added at 12:55 PM ---------- 6 hour anti-bump limit - Previous post was at 12:49 PM ----------
Tire pressure is depending on the car and your preference also, not really by the profile. Just start from the recommended sticker in the door then adjust from there either up or down incrementally until you feel you got the right balance between comfort and handling. I personally usually pump around 34-36 psi.
Post#2400 page 160 loh, sure current post, not a few pages back........hhahhaha:biggrin:
Like brother 6UE5t mentioned use according to what best pressure you are comfortable with. For 40 series it should be between 34 to 40psi.
marv3
496
57
528
:biggrin::biggrin::biggrin: My bad....Didnt thoroughly read through....
Thanks VR taikor....:biggrin:
Rahman77R
77
13
508
RE-S001 are max performance tyres like RE-050, RE-S03 and 04 pole position, but whereas RE-070 are extreme tyres, same as RE-11 or Yoko AD-08, so they are of different class.
Which Nitto model you change to? For Extreme have to be NT-05R or NT-01, Max are NT-05 and the rest like Invo, NT555 and Neogen are just normal UHP tyres only
Bought Nitto Invo. Big regret on buying those. Not buying anymore Toyo, Falken and any other tires with soft sidewall find them unstable.
Don't see that many shops selling Bridgestone Potenza RE070, so I've got no choice but to go with Bridgestone Potenza S001. Already asked quite a number of shops for Bridgestone Potenza RE003 but all told me no stock for 225/40R 18" size.
Nitto Invo thread pattern looks special only but is normal UHP tyres only.
Toyo T1-R sidewall is too soft, I had problem with them in my VR last time also.
For you Toyo means R888R already, Falken will be RT-615K, other model won't suit you.....lol
cschin83
Feb 5, 2013
25
16
503
find out hankook tyre offer from
https://www.facebook.com/tyreprice/
13"
165/60R13 HANKOOK H308 KINERGY EX @ RM 120
165/65R13 HANKOOK H308 KINERGY EX @ RM 117
175/70R13 HANKOOK H308 KINERGY EX @ RM 105
14"
165/55R14 HANKOOK K424 OPTIMO ME02 @ RM 121
165/60R14 HANKOOK H308 KINERGY EX @ RM 120
185/60R14 HANKOOK H308 KINERGY EX @ RM 121
165/65R14 HANKOOK H308 KINERGY EX @ RM 121
175/65R14 HANKOOK H308 KINERGY EX @ RM 121
185/65R14 HANKOOK H308 KINERGY EX @ RM 145
185/70R14 HANKOOK H308 KINERGY EX @ RM 161
195/70R14 HANKOOK H308 KINERGY EX @ RM 190
15"
31/10.5R15 HANKOOK RT03 DTNAPRO MT @ RM 371
31/10.5R15 HANKOOK RF10 DYNAPRO AT @ RM 353
165/50R15 HANKOOK H424 VENTUS V8RS @ RM 168
175/50R15 HANKOOK K425 KINERGY ECO @ RM 176
195/50R15 HANKOOK H457 VENTUS V2 CONCEPT 2 @ RM 147
195/50R15 HANKOOK K120 VENTUS V12 EVO2 @ RM 176
205/50R15 HANKOOK H457 VENTUS V2 CONCEPT 2 @ RM 201
185/55R15 HANKOOK H308 KINERGY EX @ RM 150
195/55R15 HANKOOK H308 KINERGY EX @ RM 152
195/55R15 HANKOOK H457 VENTUS V2 CONCEPT 2 @ RM 152
195/55R15 HANKOOK K120 VENTUS V12 EVO2 @ RM 183
185/60R15 HANKOOK H308 KINERGY EX @ RM 160
195/60R15 HANKOOK H308 KINERGY EX @ RM 168
175/65R15 HANKOOK H308 KINERGY EX @ RM 152
185/65R15 HANKOOK H308 KINERGY EX @ RM 168
195/65R15 HANKOOK H308 KINERGY EX @ RM 176
205/65R15 HANKOOK H308 KINERGY EX @ RM 184
215/65R15 HANKOOK K424 OPTIMO ME02 @ RM 241
205/70R15 HANKOOK RA18 VANTRA LT @ RM 216
265/70R15 HANKOOK RH12 DYNAPRO HT @ RM 349
235/75R15 HANKOOK RF10 DYNAPRO AT @ RM 352
195R15 HANKOOK RA18 VANTRA LT @ RM 255
16"
205/45R16 HANKOOK H457 VENTUS V2 CONCEPT 2 @ RM 221
205/45R16 HANKOOK K120 VENTUS V12 EVO2 @ RM 266
195/50R16 HANKOOK H308 KINERGY EX @ RM 200
195/50R16 HANKOOK K415 OPTIMO @ RM 241
205/50R16 HANKOOK H457 VENTUS V2 CONCEPT 2 @ RM 226
225/50R16 HANKOOK H452 VENTUS S1 NOBLE2 @ RM 347
225/50R16 HANKOOK H457 VENTUS V2 CONCEPT 2 @ RM 314
225/50R16 HANKOOK K120 VENTUS V12 EVO2 @ RM 381
185/55R16 HANKOOK H457 VENTUS V2 CONCEPT 2 @ RM 181
205/55R16 HANKOOK H452 VENTUS S1 NOBLE2 @ RM 274
205/55R16 HANKOOK H457 VENTUS V2 CONCEPT 2 @ RM 218
205/55R16 HANKOOK K115 VENTUS PRIME 2 @ RM 304
205/55R16 HANKOOK K120 VENTUS V12 EVO2 @ RM 302
215/55R16 HANKOOK H452 VENTUS S1 NOBLE2 @ RM 303
215/55R16 HANKOOK H457 VENTUS V2 CONCEPT 2 @ RM 276
225/55R16 HANKOOK H452 VENTUS S1 NOBLE2 @ RM 338
225/55R16 HANKOOK H457 VENTUS V2 CONCEPT 2 @ RM 319
205/60R16 HANKOOK K424 OPTIMO ME02 @ RM 271
215/60R16 HANKOOK K424 OPTIMO ME02 @ RM 279
215/60R16 HANKOOK H436 KINERGY GT @ RM 279
235/60R16 HANKOOK K424 OPTIMO ME02 @ RM 373
235/60R16 HANKOOK RH12 DYNAPRO HT @ RM 372
215/65R16 HANKOOK K415 OPTIMO @ RM 297
215/65R16 HANKOOK RA18 VANTRA LT @ RM 284
215/65R16 HANKOOK RH12 DYNAPRO HT @ RM 363
255/65R16 HANKOOK RA25 DYNAPRO HL @ RM 463
215/70R16 HANKOOK RA18 VANTRA LT @ RM 365
245/70R16 HANKOOK RF10 DYNAPRO AT @ RM 349
245/70R16 HANKOOK RH12 DYNAPRO HT @ RM 349
255/70R16 HANKOOK RH12 DYNAPRO HT @ RM 360
265/70R16 HANKOOK RF10 DYNAPRO AT @ RM 387
265/70R16 HANKOOK RH12 DYNAPRO HT @ RM 370
245/75R16 HANKOOK RF10 DYNAPRO AT @ RM 408
235/85R16 HANKOOK RH12 DYNAPRO HT @ RM 459
17"
245/40R17 HANKOOK H452 VENTUS S1 NOBLE2 @ RM 420
245/40R17 HANKOOK K120 VENTUS V12 EVO2 @ RM 433
205/45R17 HANKOOK H452 VENTUS S1 NOBLE2 @ RM 280
205/45R17 HANKOOK H457 VENTUS V2 CONCEPT 2 @ RM 218
205/45R17 HANKOOK K120 VENTUS V12 EVO2 @ RM 308
215/45R17 HANKOOK H452 VENTUS S1 NOBLE2 @ RM 295
215/45R17 HANKOOK H457 VENTUS V2 CONCEPT 2 @ RM 223
215/45R17 HANKOOK K120 VENTUS V12 EVO2 @ RM 324
225/45R17 HANKOOK H452 VENTUS S1 NOBLE2 @ RM 312
225/45R17 HANKOOK H457 VENTUS V2 CONCEPT 2 @ RM 280
225/45R17 HANKOOK K115 VENTUS PRIME 2 @ RM 370
225/45R17 HANKOOK K120 VENTUS V12 EVO2 @ RM 344
235/45R17 HANKOOK H452 VENTUS S1 NOBLE2 @ RM 339
235/45R17 HANKOOK H457 VENTUS V2 CONCEPT 2 @ RM 307
235/45R17 HANKOOK K120 VENTUS V12 EVO2 @ RM 373
245/45R17 HANKOOK H452 VENTUS S1 NOBLE2 @ RM 452
245/45R17 HANKOOK H457 VENTUS V2 CONCEPT 2 @ RM 386
245/45R17 HANKOOK K120 VENTUS V12 EVO2 @ RM 497
205/50R17 HANKOOK H452 VENTUS S1 NOBLE2 @ RM 321
205/50R17 HANKOOK H457 VENTUS V2 CONCEPT 2 @ RM 291
205/50R17 HANKOOK K120 VENTUS V12 EVO2 @ RM 353
215/50R17 HANKOOK H452 VENTUS S1 NOBLE2 @ RM 332
215/50R17 HANKOOK H457 VENTUS V2 CONCEPT 2 @ RM 281
215/50R17 HANKOOK K115 VENTUS PRIME 2 @ RM 390
215/50R17 HANKOOK K120 VENTUS V12 EVO2 @ RM 365
225/50R17 HANKOOK H452 VENTUS S1 NOBLE2 @ RM 341
225/50R17 HANKOOK H457 VENTUS V2 CONCEPT 2 @ RM 297
225/50R17 HANKOOK K120 VENTUS V12 EVO2 @ RM 375
235/50R17 HANKOOK H452 VENTUS S1 NOBLE2 @ RM 414
215/55R17 HANKOOK H452 VENTUS S1 NOBLE2 @ RM 324
215/55R17 HANKOOK K415 OPTIMO @ RM 317
215/55R17 HANKOOK H436 KINERGY GT @ RM 317
225/55R17 HANKOOK H452 VENTUS S1 NOBLE2 @ RM 374
235/55R17 HANKOOK H452 VENTUS S1 NOBLE2 @ RM 399
235/55R17 HANKOOK RA23 DYNAPRO HP @ RM 490
225/60R17 HANKOOK H426 OPTIMO @ RM 452
225/65R17 HANKOOK RH12 DYNAPRO HT @ RM 373
265/65R17 HANKOOK RF10 DYNAPRO AT @ RM 535
265/65R17 HANKOOK RH12 DYNAPRO HT @ RM 399
265/70R17 HANKOOK RF10 DYNAPRO AT @ RM 692
18"
255/35R18 HANKOOK H452 VENTUS S1 NOBLE2 @ RM 581
255/35R18 HANKOOK K120 VENTUS V12 EVO2 @ RM 638
265/35R18 HANKOOK H452 VENTUS S1 NOBLE2 @ RM 590
265/35R18 HANKOOK K120 VENTUS V12 EVO2 @ RM 649
275/35R18 HANKOOK H452 VENTUS S1 NOBLE2 @ RM 649
275/35R18 HANKOOK K120 VENTUS V12 EVO2 @ RM 714
285/35R18 HANKOOK H452 VENTUS S1 NOBLE2 @ RM 718
285/35R18 HANKOOK K120 VENTUS V12 EVO2 @ RM 789
215/40R18 HANKOOK K115 VENTUS PRIME 2 @ RM 429
225/40R18 HANKOOK H452 VENTUS S1 NOBLE2 @ RM 305
225/40R18 HANKOOK H457 VENTUS V2 CONCEPT 2 @ RM 279
225/40R18 HANKOOK K120 VENTUS V12 EVO2 @ RM 335
235/40R18 HANKOOK H452 VENTUS S1 NOBLE2 @ RM 363
235/40R18 HANKOOK K120 VENTUS V12 EVO2 @ RM 399
245/40R18 HANKOOK H452 VENTUS S1 NOBLE2 @ RM 419
245/40R18 HANKOOK K120 VENTUS V12 EVO2 @ RM 461
255/40R18 HANKOOK H452 VENTUS S1 NOBLE2 @ RM 482
255/40R18 HANKOOK K120 VENTUS V12 EVO2 @ RM 531
225/45R18 HANKOOK H452 VENTUS S1 NOBLE2 @ RM 323
225/45R18 HANKOOK K120 VENTUS V12 EVO2 @ RM 355
235/45R18 HANKOOK H452 VENTUS S1 NOBLE2 @ RM 412
235/45R18 HANKOOK K115 VENTUS PRIME 2 @ RM 452
245/45R18 HANKOOK H452 VENTUS S1 NOBLE2 @ RM 444
245/45R18 HANKOOK K120 VENTUS V12 EVO2 @ RM 488
255/45R18 HANKOOK H452 VENTUS S1 NOBLE2 @ RM 459
255/45R18 HANKOOK K120 VENTUS V12 EVO2 @ RM 505
225/50R18 HANKOOK H452 VENTUS S1 NOBLE2 @ RM 411
235/50R18 HANKOOK H452 VENTUS S1 NOBLE2 @ RM 430
235/50R18 HANKOOK K120 VENTUS V12 EVO2 @ RM 472
245/50R18 HANKOOK H452 VENTUS S1 NOBLE2 @ RM 499
235/55R18 HANKOOK H426 OPTIMO @ RM 493
235/60R18 HANKOOK RA33 DYNAPRO HP2 @ RM 593
19"
235/55R19 HANKOOK K115 VENTUS PRIME 2 @ RM 584
cschin83
Feb 5, 2013
25
16
503
updated from lowyat forum
find out Michelin tyre offer from
13"
155/65R13 MICHELIN XM2 @ RM 177
165/65R13 MICHELIN XM2 @ RM 183
175/70R13 MICHELIN XM2 @ RM 195
14"
165/55R14 MICHELIN PRECEDA PP2 @ RM 222
175/65R14 MICHELIN XM2 @ RM 210
185/60R14 MICHELIN XM2 @ RM 213
185/65R14 MICHELIN XM2 @ RM 229
185/70R14 MICHELIN XM2 @ RM 240
185/80R14 MICHELIN AGILIS @ RM 294
195/60R14 MICHELIN XM2 @ RM 248
195/70R14 MICHELIN XM2 @ RM 283
195/80R14 MICHELIN AGILIS @ RM 315
15"
175/65R15 MICHELIN XM2 @ RM 230
185/55R15 MICHELIN XM2 @ RM 232
185/55R15 MICHELIN PS3 @ RM 237
185/60R15 MICHELIN XM2 @ RM 223
185/65R15 MICHELIN XM2 @ RM 231
195/50R15 MICHELIN PS3 @ RM 251
195/55R15 MICHELIN XM2 @ RM 255
195/55R15 MICHELIN PS3 @ RM 259
195/60R15 MICHELIN XM2 @ RM 259
195/65R15 MICHELIN XM2 @ RM 267
195/80R15 MICHELIN AGILIS @ RM 352
205/60R15 MICHELIN XM2 @ RM 289
205/65R15 MICHELIN XM2 @ RM 296
205/70R15 MICHELIN XM2 @ RM 306
205/70R15 MICHELIN LATITUDE TOUR HP @ RM 341
215/65R15 MICHELIN XM2 @ RM 353
215/70R15 MICHELIN LATITUDE CROSS @ RM 407
215/70R15 MICHELIN AGILIS @ RM 389
225/70R15 MICHELIN LATITUDE CROSS @ RM 503
255/70R15 MICHELIN LATITUDE CROSS @ RM 476
265/70R15 MICHELIN LTX @ RM 505
16"
7.00 R 16 MICHELIN AGILIS @ RM 596
7.00 R 16 MICHELIN HIGH WAY RADIAL @ RM 336
7.50 R 16 MICHELIN AGILIS @ RM 675
7.50 R 16 MICHELIN AGILIS @ RM 753
7.50 R 16 MICHELIN HIGH WAY RADIAL @ RM 407
8.25 R 16 MICHELIN AGILIS @ RM 975
185/55R16 MICHELIN XM2 @ RM 258
195/75R16 MICHELIN AGILIS @ RM 404
205/45ZR16 MICHELIN PS3 @ RM 511
205/50ZR16 MICHELIN PS3 @ RM 428
205/55R16 MICHELIN XM2 @ RM 396
205/55R16 MICHELIN PRIMACY 3ST @ RM 395
205/55ZR16 MICHELIN PS3 @ RM 408
205/60R16 MICHELIN XM2 @ RM 388
205/60R16 MICHELIN PRIMACY 3ST @ RM 415
205/65R16 MICHELIN PRIMACY 3ST @ RM 430
215/55R16 MICHELIN PRIMACY 3ST @ RM 438
215/55ZR16 MICHELIN PS3 @ RM 537
215/60R16 MICHELIN XM2 @ RM 378
215/60R16 MICHELIN PRIMACY 3ST @ RM 397
215/65R16 MICHELIN XM2 @ RM 421
215/65 R16 MICHELIN PRIMACY SUV @ RM 400
215/75R16 MICHELIN AGILIS @ RM 459
225/50ZR16 MICHELIN PS3 @ RM 458
225/55R16 MICHELIN PRIMACY 3ST @ RM 518
225/55ZR16 MICHELIN PS3 @ RM 597
225/60R16 MICHELIN PRIMACY 3ST @ RM 511
235/60R16 MICHELIN PRIMACY 3ST @ RM 492
245/70R16 MICHELIN LATITUDE CROSS @ RM 580
245/70 R16 MICHELIN PRIMACY SUV @ RM 444
265/70R16 MICHELIN LATITUDE CROSS @ RM 592
265/70 R16 MICHELIN PRIMACY SUV @ RM 497
275/70R16 MICHELIN LATITUDE CROSS @ RM 755
17"
205/45R17 MICHELIN PS3 @ RM 451
205/50ZR17 MICHELIN PS3 @ RM 470
215/45R17 MICHELIN PRIMACY 3ST @ RM 417
215/45R17 MICHELIN PS3 @ RM 467
215/50R17 MICHELIN PRIMACY 3ST @ RM 568
215/50ZR17 MICHELIN PS3 @ RM 544
215/55R17 MICHELIN PRIMACY 3ST @ RM 528
215/55ZR17 MICHELIN PS3 @ RM 565
215/60R17 MICHELIN PRIMACY 3ST @ RM 537
225/45R17 MICHELIN PRIMACY 3ST @ RM 466
225/45ZR17 MICHELIN PS3 @ RM 580
225/50R17 MICHELIN PRIMACY 3ST @ RM 523
225/50R17 MICHELIN PRIMACY 3ST @ RM 1150
225/50ZR17 MICHELIN PS3 @ RM 619
225/55R17 MICHELIN PRIMACY 3ST @ RM 551
225/55R17 MICHELIN PRIMACY 3ST @ RM 1160
225/55R17 MICHELIN LATITUDE TOUR HP @ RM 785
225/65 R17 MICHELIN PRIMACY SUV @ RM 531
235/45ZR17 MICHELIN PS3 @ RM 636
235/50R17 MICHELIN PRIMACY 3ST @ RM 619
235/55R17 MICHELIN PRIMACY 3ST @ RM 594
235/55R17 MICHELIN LATITUDE TOUR HP @ RM 826
235/65 R17 MICHELIN PRIMACY SUV @ RM 587
245/40ZR17 MICHELIN PS3 @ RM 821
245/40R17 MICHELIN PRIMACY HP @ RM 667
245/45R17 MICHELIN PRIMACY 3ST @ RM 667
245/45ZR17 MICHELIN PS3 @ RM 775
255/40ZR17 MICHELIN PS2 @ RM 964
265/65R17 MICHELIN CROSS TERRAIN @ RM 731
265/65 R17 MICHELIN PRIMACY SUV @ RM 617
275/55R17 MICHELIN LATITUDE TOUR HP @ RM 1037
275/65R17 MICHELIN LATITUDE CROSS @ RM 838
18"
225/40ZR18 MICHELIN PS3 @ RM 861
225/40ZR18 MICHELIN PS2 @ RM 1026
225/40ZR18 MICHELIN PS2 @ RM 1246
225/45R18 MICHELIN PRIMACY 3ST @ RM 1154
225/45ZR18 MICHELIN PS3 @ RM 723
225/45ZR18 MICHELIN PSS @ RM 1052
225/50R18 MICHELIN PRIMACY LC @ RM 713
225/55R18 MICHELIN PRIMACY 3ST @ RM 567
225/80R17.5 MICHELIN AGILIS @ RM 865
235/40ZR18 MICHELIN PS3 @ RM 851
235/40ZR18 MICHELIN PS2 @ RM 1074
235/45R18 MICHELIN PS3 @ RM 793
235/50R18 MICHELIN PRIMACY 3ST @ RM 624
235/55R18 MICHELIN LATITUDE TOUR HP @ RM 925
235/60R18 MICHELIN LATITUDE TOUR HP @ RM 865
245/40R18 MICHELIN PRIMACY 3ST @ RM 1218
245/40ZR18 MICHELIN PS3 @ RM 958
245/40ZR18 MICHELIN PSS @ RM 1193
245/45R18 MICHELIN PRIMACY 3ST @ RM 771
245/45ZR18 MICHELIN PSS @ RM 1251
245/50R18 MICHELIN PRIMACY 3ST @ RM 873
255/35ZR18 MICHELIN PS3 @ RM 1042
255/35ZR18 MICHELIN PS2 @ RM 1549
255/45R18 MICHELIN PRIMACY 3ST @ RM 713
255/55R18 MICHELIN LATITUDE SPORT 3 @ RM 1457
255/55R18 MICHELIN LATITUDE SPORT 3 @ RM 1774
255/55R18 MICHELIN LATITUDE TOUR HP @ RM 1201
255/60R18 MICHELIN LATITUDE TOUR HP @ RM 971
265/35ZR18 MICHELIN PS3 @ RM 1071
265/40ZR18 MICHELIN PS2 @ RM 1290
265/40ZR18 MICHELIN PSS @ RM 1363
265/60R18 MICHELIN LATITUDE TOUR HP @ RM 799
265/60 R18 MICHELIN PRIMACY SUV @ RM 752
275/35ZR18 MICHELIN PS3 @ RM 1097
275/35ZR18 MICHELIN PS2 @ RM 1485
275/60R18 MICHELIN LATITUDE TOUR HP @ RM 1114
285/30ZR18 MICHELIN PS2 @ RM 1780
285/35ZR18 MICHELIN PSS @ RM 1568
285/60R18 MICHELIN LATITUDE TOUR HP @ RM 1181
295/30ZR18 MICHELIN PS2 @ RM 1900
19"
225/35ZR19 MICHELIN PSS @ RM 1408
225/40ZR19 MICHELIN PSS @ RM 1146
235/35ZR19 MICHELIN PS CUP + @ RM 1587
235/35ZR19 MICHELIN PS CUP 2 @ RM 1562
235/35ZR19 MICHELIN PS2 @ RM 1402
235/35ZR19 MICHELIN PSS @ RM 1416
235/40ZR19 MICHELIN PS CUP 2 @ RM 1599
235/40ZR19 MICHELIN PSS @ RM 1242
235/55R19 MICHELIN LATITUDE TOUR HP @ RM 1304
245/35ZR19 MICHELIN PS CUP 2 @ RM 1626
245/35ZR19 MICHELIN PSS @ RM 1418
245/40ZR19 MICHELIN PS3 @ RM 1065
245/40ZR19 MICHELIN PSS @ RM 1210
245/45R19 MICHELIN PRIMACY 3ST @ RM 875
245/45R19 MICHELIN PRIMACY 3ST @ RM 1323
255/35ZR19 MICHELIN PS CUP 2 @ RM 1647
255/35ZR19 MICHELIN PSS @ RM 1554
255/40ZR19 MICHELIN PSS @ RM 1567
255/45ZR19 MICHELIN PSS @ RM 1580
255/50R19 MICHELIN LATITUDE SPORT 3 @ RM 1511
255/55R19 MICHELIN LATITUDE TOUR HP @ RM 1256
265/30ZR19 MICHELIN PSS @ RM 1580
265/35ZR19 MICHELIN PS CUP 2 @ RM 1663
265/35ZR19 MICHELIN PSS @ RM 1647
265/50R19 MICHELIN LATITUDE SPORT 3 @ RM 1624
275/30ZR19 MICHELIN PSS @ RM 1641
275/35ZR19 MICHELIN PS CUP 2 @ RM 1716
275/35ZR19 MICHELIN PSS @ RM 1803
275/40R19 MICHELIN PRIMACY 3ST @ RM 1359
275/45R19 MICHELIN LATITUDE SPORT 3 @ RM 1614
275/45R19 MICHELIN LATITUDE TOUR HP @ RM 1581
285/35ZR19 MICHELIN PS CUP 2 @ RM 1728
285/35ZR19 MICHELIN PSS @ RM 1832
285/40ZR19 MICHELIN PSS @ RM 1592
285/45R19 MICHELIN LATITUDE SPORT 3 @ RM 1618
295/30ZR19 MICHELIN PS2 @ RM 1958
295/30ZR19 MICHELIN PSS @ RM 1754
305/30ZR19 MICHELIN PS CUP 2 @ RM 2075
305/30ZR19 MICHELIN PS2 @ RM 2038
325/30ZR19 MICHELIN PS CUP 2 @ RM 2086
20"
235/35ZR20 MICHELIN PSS @ RM 1486
245/35ZR20 MICHELIN PS CUP 2 @ RM 1695
245/35ZR20 MICHELIN PSS @ RM 1647
245/40R20 MICHELIN PILOT PRIMACY @ RM 1772
245/45R20 MICHELIN LATITUDE SPORT @ RM 1656
255/40ZR20 MICHELIN PSS @ RM 1618
255/50R20 MICHELIN LATITUDE TOUR HP @ RM 1676
265/35ZR20 MICHELIN PS CUP 2 @ RM 1703
265/45R20 MICHELIN LATITUDE SPORT 3 @ RM 1679
275/40R20 MICHELIN LATITUDE TOUR HP @ RM 1859
275/45ZR20 MICHELIN PS2 @ RM 1655
275/45R20 MICHELIN LATITUDE SPORT @ RM 1888
285/25ZR20 MICHELIN PSS @ RM 1953
295/25ZR20 MICHELIN PSS @ RM 2192
295/30ZR20 MICHELIN PS CUP 2 @ RM 2107
295/30ZR20 MICHELIN PSS @ RM 2019
295/35ZR20 MICHELIN PSS @ RM 2113
295/40R20 MICHELIN LATITUDE SPORT 3 @ RM 2090
305/30ZR20 MICHELIN PS CUP 2 @ RM 2146
315/35R20 MICHELIN LATITUDE SPORT 3 @ RM 1852
325/25ZR20 MICHELIN PSS @ RM 2217
325/30ZR20 MICHELIN PS CUP 2 @ RM 2161
21"
265/40R21 MICHELIN LATITUDE SPORT 3 @ RM 2153
295/35R21 MICHELIN LATITUDE SPORT 3 @ RM 2176
325/30ZR21 MICHELIN PS CUP 2 @ RM 2240
cschin83
Feb 5, 2013
25
16
503
155/70R12
Falken SN828-RM110 (GST+V+B+A incl) mytayar.com@Klang Valley (Feb 16)
Falken SN828-RM85 Weng Heng Bukit Kemuning (Jan-15)
Goodyear GPS2-RM100 Weng Heng Bukit Kemuning (Oct-15)
Viking City Tech 5-RM98 (GST+V+B+A incl) mytayar.com@Klang Valley (Feb 16)
155/65R13
MICHELIN XM2@RM 177 Incl-GST+A+B+V+Nit.Gas+Rotation (FIVE S STAR PUCHONG)
155/70R13
Achilles PLATINUM 7@RM 123 Incl-GST+A+B+V+Nit.Gas+Rotation (FIVE S STAR PUCHONG)
165/60R13
Achilles 122@RM 137 Incl-GST+A+B+V+Nit.Gas+Rotation (FIVE S STAR PUCHONG)
Falken ZE326-RM110 Weng Heng Bukit Kemuning (Jan-15)
Goodyear Duraplus-Rm 130 Weng Heng Bukit Kemuning (Sept-15)
Goodyear DuraPlus-RM143 (GST+V+B+A incl) mytayar.com@Seremban (Feb 16)
HANKOOK H308 KINERGY EX@RM 120 Incl-GST+A+B+V+Nit.Gas+Rotation (FIVE S STAR PUCHONG)
Silverstone Powerblitz 1800-RM100 Weng Heng Bukit Kemuning (Feb-15)
Silverstone Powerblitz 1800-RM118 (GST+V+B+A incl) mytayar.com@Klang Valley (Feb 16)
Yokohama AE01-RM140 Weng Heng Bukit Kemuning (Feb-15)
165/65R13
Achilles PLATINUM 7@RM 141 Incl-GST+A+B+V+Nit.Gas+Rotation (FIVE S STAR PUCHONG)
HANKOOK H308 KINERGY EX@RM 117 Incl-GST+A+B+V+Nit.Gas+Rotation (FIVE S STAR PUCHONG)
MICHELIN XM2@RM 183 Incl-GST+A+B+V+Nit.Gas+Rotation (FIVE S STAR PUCHONG)
175/60R13
Achilles PLATINUM 7@RM 142 Incl-GST+A+B+V+Nit.Gas+Rotation (FIVE S STAR PUCHONG)
175/70R13
Achiles Platinum- RM100 Weng Heng Bukit Kemuning (Sept-15)
Achilles 122@RM 126 Incl-GST+A+B+V+Nit.Gas+Rotation (FIVE S STAR PUCHONG)
Achilles PLATINUM@RM 126 Incl-GST+A+B+V+Nit.Gas+Rotation (FIVE S STAR PUCHONG)
Falken SN828-RM90 Weng Heng Bukit Kemuning (Jan-15)
HANKOOK H308 KINERGY EX@RM 105 Incl-GST+A+B+V+Nit.Gas+Rotation (FIVE S STAR PUCHONG)
Hankook Kinergy Ex (H308)-RM119 (GST+V+B+A incl) mytayar.com@Klang Valley (Feb 16)
Michelin XM2-RM165 Weng Heng Bukit Kemuning (Jan-15)
MICHELIN XM2@RM 195 Incl-GST+A+B+V+Nit.Gas+Rotation (FIVE S STAR PUCHONG)
Silverstone Synergy M3-RM116 (GST+V+B+A incl) mytayar.com@JB (Feb 16)
Silverstone Synergy M3-RM95 Weng Heng Bukit Kemuning (Jan-16)
Viking City Tech 5-RM120 (GST+B incl) mytayar.com@Ipoh (Feb 16)
185/60R13
Achilles 122@RM 166 Incl-GST+A+B+V+Nit.Gas+Rotation (FIVE S STAR PUCHONG)
185/70R13
Achilles PLATINUM@RM 183 Incl-GST+A+B+V+Nit.Gas+Rotation (FIVE S STAR PUCHONG)
165/50R14
Achilles ATR-K ECONOMIST@RM 157 Incl-GST+A+B+V+Nit.Gas+Rotation (FIVE S STAR PUCHONG)
165/55R14
Achilles ATR-K ECONOMIST@RM 154 Incl-GST+A+B+V+Nit.Gas+Rotation (FIVE S STAR PUCHONG)
Achilles ATR-K SPORT@RM 179 Incl-GST+A+B+V+Nit.Gas+Rotation (FIVE S STAR PUCHONG)
Falken ZE326-RM110 Weng Heng Bukit Kemuning (Sept-15)
HANKOOK K424 OPTIMO ME02@RM 121 Incl-GST+A+B+V+Nit.Gas+Rotation (FIVE S STAR PUCHONG)
Hankook Optimo ME02 (K424)-RM130 Weng Heng Bukit Kemuning (Dec-15)
Hankook Optimo ME02 (K424)-RM160 (GST+V+B+A incl) mytayar.com@JB (Feb 16)
Kumho Ecsta SPT KU31-RM158 (GST+V+B+A incl) mytayar.com@Klang Valley (Feb 16)
MICHELIN PRECEDA PP2@RM 222 Incl-GST+A+B+V+Nit.Gas+Rotation (FIVE S STAR PUCHONG)
Silverstone Powerblitz 1800-RM119 (GST+V+B+A incl) mytayar.com@Klang Valley (Feb 16)
Yokohama Blue Earth AE01-RM145 Weng Heng Bukit Kemuning (Jan-15)
165/60R14
Goodyear Eagle NCT 5-RM181 (GST+V+B+A incl) mytayar.com@Seremban (Feb 16)
Hankook Kinergy Ex (H308)-RM130 Weng Heng Bukit Kemuning (Jan-15)
Hankook Kinergy Ex (H308)-RM145 (GST+V+B+A incl) mytayar.com@Klang Valley (Feb 16)
165/65R14
HANKOOK H308 KINERGY EX@RM 121 Incl-GST+A+B+V+Nit.Gas+Rotation (FIVE S STAR PUCHONG)
175/65R14
Achilles 122@RM 145 Incl-GST+A+B+V+Nit.Gas+Rotation (FIVE S STAR PUCHONG)
Achilles PLATINUM@RM 145 Incl-GST+A+B+V+Nit.Gas+Rotation (FIVE S STAR PUCHONG)
Continental CC5-RM135 Weng Heng Bukit Kemuning (May-15)
Continental CC5-RM145 (exclude GST, include balancing+nitrogen) Enkai Automobile Taman Perindustrian Nilam, Kajang (Jun 15)
Continental CC5-RM145 (valve+balancing) Hup Seng Puchong Utama (May 15).
Goodyear DuraPlus-RM165 (GST+B incl) mytayar.com@Ipoh (Feb 16)
Goodyear Eagle NCT 5-RM149 (GST+V+B+A incl) mytayar.com@Seremban (Feb 16)
Goodyear NCT5-RM130 Weng Heng Bukit Kemuning (Sept-15)
Hankook Kinergy Ex (H308)-RM135 (GST+V+B+A incl) mytayar.com@Klang Valley (Feb 16)
Kumho KH15-RM130 Weng Heng Bukit Kemuning (Apr-15)
Michelin XM2-RM190 Hup Shun SS3 (Jan 16)
MICHELIN XM2@RM 210 Incl-GST+A+B+V+Nit.Gas+Rotation (FIVE S STAR PUCHONG)
Toyo NanoEnergy 3-RM180 (GST+V+B+A incl) mytayar.com@JB (Feb 16)
185/60R14
Achilles 122@RM 146 Incl-GST+A+B+V+Nit.Gas+Rotation (FIVE S STAR PUCHONG)
Achilles PLATINUM@RM 146 Incl-GST+A+B+V+Nit.Gas+Rotation (FIVE S STAR PUCHONG)
Dunlop SP Sports J5-RM130 Weng Heng Bukit Kemuning (Dec 15)
Dunlop SP Sports J5-RM140 (GST+B incl) mytayar.com@Ipoh (Feb 16)
Goodyear Assurance Duraplus-RM164 (GST+V+B+A incl) mytayar.com@Seremban (Feb 16)
GT Radial Champiro ECO-RM169.6 (GST+V+B+A incl) mytayar.com@Klang Valley (Feb 16)
Hankook Kinergy Ex (H308)-RM138 (GST+V+B+A incl) mytayar.com@Klang Valley (Feb 16)
MICHELIN XM2@RM 213 Incl-GST+A+B+V+Nit.Gas+Rotation (FIVE S STAR PUCHONG)
Toyo NanoEnergy 3-RM 135 Weng Heng Bukit Kemuning (Sept-15)
Yokohama BluEarth AE01- RM165 Hup Seng (Puchong Utama) (Jan 2015)
185/65R14
Achilles PLATINUM@RM 155 Incl-GST+A+B+V+Nit.Gas+Rotation (FIVE S STAR PUCHONG)
Continental Comfort Contact 5-RM210 (GST+V+B+A incl) mytayar.com@Klang Valley (Feb 16)
Dunlop J5-RM 150 Weng Heng Bukit Kemuning (Jan-16)
HANKOOK H308 KINERGY EX@RM 145 Incl-GST+A+B+V+Nit.Gas+Rotation (FIVE S STAR PUCHONG)
Leao Lion Sport UHP-RM145 (GST+V+B+A incl) mytayar.com@Klang Valley (Feb 16)
MICHELIN XM2@RM 229 Incl-GST+A+B+V+Nit.Gas+Rotation (FIVE S STAR PUCHONG)
Neuton NT3000-RM155 Weng Heng Bukit Kemuning (May-15)
Toyo NanoEnergy 3-RM155 Weng Heng Bukit Kemuning (Jan-16)
Toyo NanoEnergy 3-RM196 (GST+V+B+A incl) mytayar.com@JB (Feb 16)
185/70R14
Achilles PLATINUM@RM 178 Incl-GST+A+B+V+Nit.Gas+Rotation (FIVE S STAR PUCHONG)
HANKOOK H308 KINERGY EX@RM 161 Incl-GST+A+B+V+Nit.Gas+Rotation (FIVE S STAR PUCHONG)
Hankook Kinergy Ex (H308)-RM160 Weng Heng Bukit Kemuning (Jan-16)
Hankook Kinergy Ex (H308)-RM181 (GST+V+B+A incl) mytayar.com@Klang Valley (Feb 16)
Michelin Energy XM2-RM238 (GST+V+B+A incl) mytayar.com@JB (Feb 16)
MICHELIN XM2@RM 240 Incl-GST+A+B+V+Nit.Gas+Rotation (FIVE S STAR PUCHONG)
Silverstone Kruizer 1 NS500-RM169 (GST+B incl) mytayar.com@Ipoh (Feb 16)
Yokohama AE01-RM 165 Weng Heng Bukit Kemuning (Jan-16)
185/80R14
Achilles Econovan@RM 208 Incl-GST+A+B+V+Nit.Gas+Rotation (FIVE S STAR PUCHONG)
MICHELIN AGILIS@RM 294 Incl-GST+A+B+V+Nit.Gas+Rotation (FIVE S STAR PUCHONG)
185/R14
Achilles LTR-80@RM 219 Incl-GST+A+B+V+Nit.Gas+Rotation (FIVE S STAR PUCHONG)
195/60R14
MICHELIN XM2@RM 248 Incl-GST+A+B+V+Nit.Gas+Rotation (FIVE S STAR PUCHONG)
195/70R14
Achilles PLATINUM@RM 191 Incl-GST+A+B+V+Nit.Gas+Rotation (FIVE S STAR PUCHONG)
HANKOOK H308 KINERGY EX@RM 190 Incl-GST+A+B+V+Nit.Gas+Rotation (FIVE S STAR PUCHONG)
MICHELIN XM2@RM 283 Incl-GST+A+B+V+Nit.Gas+Rotation (FIVE S STAR PUCHONG)
195/80R14
MICHELIN AGILIS@RM 315 Incl-GST+A+B+V+Nit.Gas+Rotation (FIVE S STAR PUCHONG)
195/R14
Achilles LTR-80@RM 259 Incl-GST+A+B+V+Nit.Gas+Rotation (FIVE S STAR PUCHONG)
205/75R14
Achilles 9595@RM 284 Incl-GST+A+B+V+Nit.Gas+Rotation (FIVE S STAR PUCHONG)
31/10.5R15
Achilles Desert Hawk A/T@RM 441 Incl-GST+A+B+V+Nit.Gas+Rotation (FIVE S STAR PUCHONG)
Achilles Desert Hawk M/T@RM 465 Incl-GST+A+B+V+Nit.Gas+Rotation (FIVE S STAR PUCHONG)
Achilles Desert Hawk M/T@RM 480 Incl-GST+A+B+V+Nit.Gas+Rotation (FIVE S STAR PUCHONG)
Achilles Desert Hawk X-MT@RM 490 Incl-GST+A+B+V+Nit.Gas+Rotation (FIVE S STAR PUCHONG)
Achilles Desert Hawk X-MT@RM 501 Incl-GST+A+B+V+Nit.Gas+Rotation (FIVE S STAR PUCHONG)
HANKOOK RF10 DYNAPRO AT@RM 353 Incl-GST+A+B+V+Nit.Gas+Rotation (FIVE S STAR PUCHONG)
HANKOOK RT03 DTNAPRO MT@RM 371 Incl-GST+A+B+V+Nit.Gas+Rotation (FIVE S STAR PUCHONG)
32/11.5R15
Achilles Desert Hawk X-MT@RM 575 Incl-GST+A+B+V+Nit.Gas+Rotation (FIVE S STAR PUCHONG)
Achilles Desert Hawk X-MT@RM 597 Incl-GST+A+B+V+Nit.Gas+Rotation (FIVE S STAR PUCHONG)
33/12.5R15
Achilles Desert Hawk X-MT@RM 608 Incl-GST+A+B+V+Nit.Gas+Rotation (FIVE S STAR PUCHONG)
Achilles Desert Hawk X-MT@RM 626 Incl-GST+A+B+V+Nit.Gas+Rotation (FIVE S STAR PUCHONG)
165/45R15
Achilles ATR-K ECONOMIST@RM 176 Incl-GST+A+B+V+Nit.Gas+Rotation (FIVE S STAR PUCHONG)
165/50R15
Achilles ATR-K ECONOMIST@RM 161 Incl-GST+A+B+V+Nit.Gas+Rotation (FIVE S STAR PUCHONG)
Achilles ATR-K SPORT@RM 184 Incl-GST+A+B+V+Nit.Gas+Rotation (FIVE S STAR PUCHONG)
HANKOOK H424 VENTUS V8RS@RM 168 Incl-GST+A+B+V+Nit.Gas+Rotation (FIVE S STAR PUCHONG)
165/55R15
175/50R15
HANKOOK K425 KINERGY ECO@RM 176 Incl-GST+A+B+V+Nit.Gas+Rotation (FIVE S STAR PUCHONG)
175/60R15
Achilles 122@RM 175 Incl-GST+A+B+V+Nit.Gas+Rotation (FIVE S STAR PUCHONG)
175/65R15
Achilles 122@RM 180 Incl-GST+A+B+V+Nit.Gas+Rotation (FIVE S STAR PUCHONG)
Continental CC5- RM190 Soon Heng Tyre & Car Services, Tanjung Malim (Oct 15)
HANKOOK H308 KINERGY EX@RM 152 Incl-GST+A+B+V+Nit.Gas+Rotation (FIVE S STAR PUCHONG)
Hankook Kinergy Ex (H308)-RM155 Weng Heng Bukit Kemuning (Jan-16)
Hankook Kinergy Ex (H308)-RM171 (GST+V+B+A incl) mytayar.com@Klang Valley (Feb 16)
MICHELIN XM2@RM 230 Incl-GST+A+B+V+Nit.Gas+Rotation (FIVE S STAR PUCHONG)
Toyo NanoEnergy 3-RM198 (GST+V+B+A incl) mytayar.com@JB (Feb 16)
185/50R15
185/55R15
Achilles ATR Sport-RM155 Weng Heng Bukit Kemuning (Apr-15)
Achilles ATR Sport-RM165 PTS, Danau Kota (Feb 15)
Achilles ATR SPRORT@RM 192 Incl-GST+A+B+V+Nit.Gas+Rotation (FIVE S STAR PUCHONG)
Continental CC5-RM190 Tek Ming (Feb 15)
Goodyear Eagle NCT 5-RM170 (GST+V+B+A incl) mytayar.com@Seremban (Feb 16)
Goodyear NCT5-RM150 Weng Heng Bukit Kemuning (Dec-15)
HANKOOK H308 KINERGY EX@RM 150 Incl-GST+A+B+V+Nit.Gas+Rotation (FIVE S STAR PUCHONG)
Hankook Kinergy Ex (H308)-RM170 (GST+V+B+A incl) mytayar.com@Klang Valley (Feb 16)
Michelin Pilot Sport 3-RM242 (GST+V+B+A incl) mytayar.com@JB (Feb 16)
Michelin PS3-RM220 Weng Heng Bukit Kemuning (Apr-15)
MICHELIN PS3@RM 237 Incl-GST+A+B+V+Nit.Gas+Rotation (FIVE S STAR PUCHONG)
MICHELIN XM2@RM 232 Incl-GST+A+B+V+Nit.Gas+Rotation (FIVE S STAR PUCHONG)
Silverstone Synergy M5-RM140 Weng Heng Bukit Kemuning (Sept-15)
Silverstone Synergy M5-RM145 Tek Ming (Feb 15)
Silverstone Synergy M5-RM155 (GST+B incl) mytayar.com@Ipoh (Feb 16)
Toyo DRB-RM180 Tek Ming (Feb 15)
Toyo Proxes T1R-RM210 Hin Leong Klang (May 15)
185/60R15
Achilles 122@RM 184 Incl-GST+A+B+V+Nit.Gas+Rotation (FIVE S STAR PUCHONG)
Continental Comfort Contact 5-RM175 Weng Heng Bukit Kemuning (Dec-15)
Continental Comfort Contact 5-RM215 (GST+V+B+A incl) mytayar.com@Klang Valley (Feb 16)
Goodyear Assurance Triplemax-RM199 (GST+B incl) mytayar.com@Ipoh (Feb 16)
HANKOOK H308 KINERGY EX@RM 160 Incl-GST+A+B+V+Nit.Gas+Rotation (FIVE S STAR PUCHONG)
MICHELIN XM2@RM 223 Incl-GST+A+B+V+Nit.Gas+Rotation (FIVE S STAR PUCHONG)
Toyo NanoEnergy 3-RM170 Weng Heng Bukit Kemuning (Dec-15)
Toyo NanoEnergy 3-RM215 (GST+V+B+A incl) mytayar.com@JB (Feb 16)
185/65R15
Achilles 122@RM 190 Incl-GST+A+B+V+Nit.Gas+Rotation (FIVE S STAR PUCHONG)
Achilles PLATINUM@RM 187 Incl-GST+A+B+V+Nit.Gas+Rotation (FIVE S STAR PUCHONG)
Continental Comfort Contact 5-RM180 Weng Heng Bukit Kemuning (Dec-15)
Continental Comfort Contact 5-RM220 (GST+V+B+A incl) mytayar.com@Klang Valley (Feb 16)
HANKOOK H308 KINERGY EX@RM 168 Incl-GST+A+B+V+Nit.Gas+Rotation (FIVE S STAR PUCHONG)
Michelin Energy XM2-RM205 Weng Heng Bukit Kemuning (Dec-15)
Michelin Energy XM2-RM220-(GST non-inlcusive, B incl)-Touch Autocar Care Puchong (Dec-15)
MICHELIN XM2@RM 231 Incl-GST+A+B+V+Nit.Gas+Rotation (FIVE S STAR PUCHONG)
Silverstone Synergy M5-RM167 (GST+B incl) mytayar.com@Ipoh (Feb 16)
Toyo Nano3-RM170 Weng Heng Bukit Kemuning (Jan-16)
195/50R15
Achilles 123@RM 324 Incl-GST+A+B+V+Nit.Gas+Rotation (FIVE S STAR PUCHONG)
Achilles ATR Sport-RM 135 Weng Heng Bukit Kemuning (May-15)
Achilles ATR SPRORT@RM 172 Incl-GST+A+B+V+Nit.Gas+Rotation (FIVE S STAR PUCHONG)
Bridgestone Ecopia EP200-RM150 Weng Heng Bukit Kemuning (Jan-15)
Falken ZE912-RM130 Weng Heng Bukit Kemuning (Mar-15)
GT Radial SX2-RM305 Acabta Autotech (Jun-15)
HANKOOK H457 VENTUS V2 CONCEPT 2@RM 147 Incl-GST+A+B+V+Nit.Gas+Rotation (FIVE S STAR PUCHONG)
Hankook Ventus 2 Concept2 (H457)-RM145 Weng Heng Bukit Kemuning (Feb 16)
Hankook Ventus 2 Concept2 (H457)-RM169 (GST+V+B+A incl) mytayar.com@JB (Feb 16)
Kumho Ecsta KU23-RM158 (GST+B incl) mytayar.com@Klang Valley (Feb 16)
Kumho V720-RM280 Weng Heng Bukit Kemuning (Sept-15)
Kumho V720-RM290 Acanta Autotech (Jun-15)
Michelin PS3-RM220 Hin Leong Klang (Jan-16)
MICHELIN PS3@RM 251 Incl-GST+A+B+V+Nit.Gas+Rotation (FIVE S STAR PUCHONG)
Nitto NT555-RM185 Weng Heng Bukit Kemuning (Apr-15)
Toyo NanoEnergy 3-RM140-(GST non-inlcusive, B incl)-Hin Leong Jn Kapar, Klang (Nov 15)
Viking ProTech 5-RM160 (GST+B incl) mytayar.com@Ipoh (Feb 16)
195/55R15
Achilles 122@RM 177 Incl-GST+A+B+V+Nit.Gas+Rotation (FIVE S STAR PUCHONG)
Achilles ATR SPRORT@RM 177 Incl-GST+A+B+V+Nit.Gas+Rotation (FIVE S STAR PUCHONG)
Achilles ATR SPRORT 2@RM 180 Incl-GST+A+B+V+Nit.Gas+Rotation (FIVE S STAR PUCHONG)
Bridgestone EP200-RM155 Weng Heng Bukit Kemuning (Apr-15)
Bridgestone Potenza RE003-RM190 Weng Heng Bukit Kemuning (Apr-15)
Dunlop Formula D05-RM140 Weng Heng Bukit Kemuning (Dec-15)
Dunlop Formula D05-RM150 (GST+B incl) mytayar.com@Klang Valley (Feb 16)
Goodyear Eagle NCT 5-RM140 Weng Heng Bukit Kemuning (Feb 16)
Goodyear Eagle NCT 5-RM165 (GST+V+B+A incl) mytayar.com@Seremban (Feb 16)
Goodyear F1 Directional 5-RM245 Weng Heng Bukit Kemuning (Sept-15)
HANKOOK H457 VENTUS V2 CONCEPT 2@RM 152 Incl-GST+A+B+V+Nit.Gas+Rotation (FIVE S STAR PUCHONG)
Hankook V12 Evo 2-RM200 Weng Heng Bukit Kemuning (Sep-15)
Hankook V12 Evo 2-RM245 Acanta Autotech (Sep-15)
Hankook Ventus 2 Concept2 (H457)-RM150 (GST+V+B+A incl) mytayar.com@Klang Valley (Feb 16)
Michelin PS3-RM230 Weng Heng Bukit Kemuning (Apr-15)
MICHELIN PS3@RM 259 Incl-GST+A+B+V+Nit.Gas+Rotation (FIVE S STAR PUCHONG)
Michelin XM2-RM220 Weng Heng Bukit Kemuning (Apr-15)
MICHELIN XM2@RM 255 Incl-GST+A+B+V+Nit.Gas+Rotation (FIVE S STAR PUCHONG)
Yokohama S-Drive-RM230 Weng Heng Bukit Kemuning (Sept-15)
195/60R15
Achilles 122@RM 189 Incl-GST+A+B+V+Nit.Gas+Rotation (FIVE S STAR PUCHONG)
Achilles ATR SPRORT@RM 198 Incl-GST+A+B+V+Nit.Gas+Rotation (FIVE S STAR PUCHONG)
Achilles PLATINUM@RM 189 Incl-GST+A+B+V+Nit.Gas+Rotation (FIVE S STAR PUCHONG)
Continental CC5-RM 175 Weng Heng Bukit Kemuning (May-15)
Goodyear Assurance Triple Max-RM185 Weng Heng Bukit Kemuning (Jan-15)
Hankook Kinergy Ex (H308)-RM165 Weng Heng Bukit Kemuning (Feb 16)
Hankook Kinergy Ex (H308)-RM193 (GST+V+B+A incl) mytayar.com@JB (Feb 16)
Michelin XM2-RM230 Weng Heng Bukit Kemuning (Oct-15)
MICHELIN XM2@RM 259 Incl-GST+A+B+V+Nit.Gas+Rotation (FIVE S STAR PUCHONG)
Silverstone Kruizer 1 NS500-RM178 (GST+B incl) mytayar.com@Ipoh (Feb 16)
Silverstone Synergy M5-RM165 (GST+V+B+A incl) mytayar.com@Klang Valley (Feb 16)
195/65R15
Achilles PLATINUM@RM 202 Incl-GST+A+B+V+Nit.Gas+Rotation (FIVE S STAR PUCHONG)
Continental Comfort Contact 5-RM200 Weng Heng Bukit Kemuning (Jan-16)
Continental Comfort Contact 5-RM240 (GST+V+B+A incl) mytayar.com@Klang Valley (Feb 16)
HANKOOK H308 KINERGY EX@RM 176 Incl-GST+A+B+V+Nit.Gas+Rotation (FIVE S STAR PUCHONG)
MICHELIN XM2@RM 267 Incl-GST+A+B+V+Nit.Gas+Rotation (FIVE S STAR PUCHONG)
Toyo NanoEnergy 3-RM238 (GST+V+B+A incl) mytayar.com@JB (Feb 16)
195/80R15
MICHELIN AGILIS@RM 352 Incl-GST+A+B+V+Nit.Gas+Rotation (FIVE S STAR PUCHONG)
195/R15
Achilles 9595@RM 290 Incl-GST+A+B+V+Nit.Gas+Rotation (FIVE S STAR PUCHONG)
Achilles 9595@RM 305 Incl-GST+A+B+V+Nit.Gas+Rotation (FIVE S STAR PUCHONG)
Achilles LTR-80@RM 289 Incl-GST+A+B+V+Nit.Gas+Rotation (FIVE S STAR PUCHONG)
HANKOOK RA18 VANTRA LT@RM 255 Incl-GST+A+B+V+Nit.Gas+Rotation (FIVE S STAR PUCHONG)
205/50R15
HANKOOK H457 VENTUS V2 CONCEPT 2@RM 201 Incl-GST+A+B+V+Nit.Gas+Rotation (FIVE S STAR PUCHONG)
205/60R15
Achilles PLATINUM@RM 224 Incl-GST+A+B+V+Nit.Gas+Rotation (FIVE S STAR PUCHONG)
Michelin Energy XM2-RM280 (GST+V+B+A incl) mytayar.com@Klang Valley (Feb 16)
Michelin XM2-RM 255 Weng Heng Bukit Kemuning (Jan-16)
MICHELIN XM2@RM 289 Incl-GST+A+B+V+Nit.Gas+Rotation (FIVE S STAR PUCHONG)
Silverstone Synergy M5-RM183 (GST+B incl) mytayar.com@Ipoh (Feb 16)
205/65R15
Achilles PLATINUM@RM 220 Incl-GST+A+B+V+Nit.Gas+Rotation (FIVE S STAR PUCHONG)
Firestone TZ700-RM228 (GST+V+B+A incl) mytayar.com@Klang Valley (Feb 16)
HANKOOK H308 KINERGY EX@RM 184 Incl-GST+A+B+V+Nit.Gas+Rotation (FIVE S STAR PUCHONG)
Michelin XM2-RM260 Weng Heng Bukit Kemuning (Jan-16)
MICHELIN XM2@RM 296 Incl-GST+A+B+V+Nit.Gas+Rotation (FIVE S STAR PUCHONG)
Toyo NanoEnergy 3-RM200 Weng Heng Bukit Kemuning (Jan-16)
Toyo NanoEnergy 3-RM235 (GST+V+B+A incl) mytayar.com@JB (Feb 16)
Yokohama ADVAN dB V551 (Japan)-RM285 (Feb-15) price for taking 4 tyres, incl valve, B+A
205/70R15
Achilles MULTIVAAN@RM 281 Incl-GST+A+B+V+Nit.Gas+Rotation (FIVE S STAR PUCHONG)
HANKOOK RA18 VANTRA LT@RM 216 Incl-GST+A+B+V+Nit.Gas+Rotation (FIVE S STAR PUCHONG)
MICHELIN LATITUDE TOUR HP@RM 341 Incl-GST+A+B+V+Nit.Gas+Rotation (FIVE S STAR PUCHONG)
MICHELIN XM2@RM 306 Incl-GST+A+B+V+Nit.Gas+Rotation (FIVE S STAR PUCHONG)
205/75R15
Achilles 9595@RM 281 Incl-GST+A+B+V+Nit.Gas+Rotation (FIVE S STAR PUCHONG)
215/65R15
HANKOOK K424 OPTIMO ME02@RM 241 Incl-GST+A+B+V+Nit.Gas+Rotation (FIVE S STAR PUCHONG)
MICHELIN XM2@RM 353 Incl-GST+A+B+V+Nit.Gas+Rotation (FIVE S STAR PUCHONG)
215/70R15
MICHELIN AGILIS@RM 389 Incl-GST+A+B+V+Nit.Gas+Rotation (FIVE S STAR PUCHONG)
MICHELIN LATITUDE CROSS@RM 407 Incl-GST+A+B+V+Nit.Gas+Rotation (FIVE S STAR PUCHONG)
225/70R15
MICHELIN LATITUDE CROSS@RM 503 Incl-GST+A+B+V+Nit.Gas+Rotation (FIVE S STAR PUCHONG)
235/70R15
Achilles Desert Hawk A/T@RM 383 Incl-GST+A+B+V+Nit.Gas+Rotation (FIVE S STAR PUCHONG)
Achilles Desert Hawk A/T@RM 404 Incl-GST+A+B+V+Nit.Gas+Rotation (FIVE S STAR PUCHONG)
235/75R15
Achilles Desert Hawk A/T@RM 336 Incl-GST+A+B+V+Nit.Gas+Rotation (FIVE S STAR PUCHONG)
Achilles Desert Hawk A/T@RM 367 Incl-GST+A+B+V+Nit.Gas+Rotation (FIVE S STAR PUCHONG)
HANKOOK RF10 DYNAPRO AT@RM 352 Incl-GST+A+B+V+Nit.Gas+Rotation (FIVE S STAR PUCHONG)
255/70R15
Bridgestone AT697-RM325 Weng Heng Bukit Kemuning (Apr-15)
Bridgestone Dueler H/T 840-RM415 (GST+V+B+A incl) mytayar.com@Klang Valley (Feb 16)
MICHELIN LATITUDE CROSS@RM 476 Incl-GST+A+B+V+Nit.Gas+Rotation (FIVE S STAR PUCHONG)
265/70R15
HANKOOK RH12 DYNAPRO HT@RM 349 Incl-GST+A+B+V+Nit.Gas+Rotation (FIVE S STAR PUCHONG)
Michelin LTX-RM440 Weng Heng Bukit Kemuning (Apr-15)
MICHELIN LTX@RM 505 Incl-GST+A+B+V+Nit.Gas+Rotation (FIVE S STAR PUCHONG)
Silverstone Estiva X5-RM315 Weng Heng Bukit Kemuning (Jan-16)
Silverstone Estiva X5-RM341 (GST+B incl) mytayar.com@Ipoh (Feb 16)
Yokohama G012 A/T-RM380 Weng Heng Bukit Kemuning (Mar-15)
7/100R16
MICHELIN AGILIS@RM 596 Incl-GST+A+B+V+Nit.Gas+Rotation (FIVE S STAR PUCHONG)
MICHELIN HIGH WAY RADIAL@RM 336 Incl-GST+A+B+V+Nit.Gas+Rotation (FIVE S STAR PUCHONG)
7.5/100R16
Achilles HD12@RM 595 Incl-GST+A+B+V+Nit.Gas+Rotation (FIVE S STAR PUCHONG)
MICHELIN AGILIS@RM 675 Incl-GST+A+B+V+Nit.Gas+Rotation (FIVE S STAR PUCHONG)
MICHELIN AGILIS@RM 753 Incl-GST+A+B+V+Nit.Gas+Rotation (FIVE S STAR PUCHONG)
MICHELIN HIGH WAY RADIAL@RM 407 Incl-GST+A+B+V+Nit.Gas+Rotation (FIVE S STAR PUCHONG)
8.25/100R16
MICHELIN AGILIS@RM 975 Incl-GST+A+B+V+Nit.Gas+Rotation (FIVE S STAR PUCHONG)
165/45R16
Achilles ATR-K ECONOMIST@RM 213 Incl-GST+A+B+V+Nit.Gas+Rotation (FIVE S STAR PUCHONG)
185/55R16
Achilles 2233@RM 208 Incl-GST+A+B+V+Nit.Gas+Rotation (FIVE S STAR PUCHONG)
Continental CPC2-RM190 Weng Heng Bukit Kemuning (May-15)
Goodyear Excellence-RM238 (GST+V+B+A incl) mytayar.com@Klang Valley (Feb 16)
HANKOOK H457 VENTUS V2 CONCEPT 2@RM 181 Incl-GST+A+B+V+Nit.Gas+Rotation (FIVE S STAR PUCHONG)
Hankook Ventus 2 Concept2 (H457)-RM185 Weng Heng Bukit Kemuning (Feb 16)
Hankook Ventus 2 Concept2 (H457)-RM208 (GST+V+B+A incl) mytayar.com@JB (Feb 16)
MICHELIN XM2@RM 258 Incl-GST+A+B+V+Nit.Gas+Rotation (FIVE S STAR PUCHONG)
195/45R16
Achilles ATR SPRORT@RM 226 Incl-GST+A+B+V+Nit.Gas+Rotation (FIVE S STAR PUCHONG)
195/50R16
Achilles ATR SPRORT@RM 224 Incl-GST+A+B+V+Nit.Gas+Rotation (FIVE S STAR PUCHONG)
Achilles ATR SPRORT 2@RM 229 Incl-GST+A+B+V+Nit.Gas+Rotation (FIVE S STAR PUCHONG)
Continental MC5-RM 250 Weng Heng Bukit Kemuning (Oct-15)
Goodyear Assurance Triplemax-RM208 (GST+V+B+A incl) mytayar.com@Seremban (Feb 16)
HANKOOK H308 KINERGY EX@RM 200 Incl-GST+A+B+V+Nit.Gas+Rotation (FIVE S STAR PUCHONG)
HANKOOK K415 OPTIMO@RM 241 Incl-GST+A+B+V+Nit.Gas+Rotation (FIVE S STAR PUCHONG)
Hankook Kinergy Ex (H308)-RM200 Weng Heng Bukit Kemuning (Jan-16)
Hankook Kinergy Ex (H308)-RM230 (GST+V+B+A incl) mytayar.com@JB (Feb 16)
195/55R16
Achilles ATR SPRORT@RM 228 Incl-GST+A+B+V+Nit.Gas+Rotation (FIVE S STAR PUCHONG)
195/65R16
Achilles MULTIVAAN@RM 254 Incl-GST+A+B+V+Nit.Gas+Rotation (FIVE S STAR PUCHONG)
195/75R16
MICHELIN AGILIS@RM 404 Incl-GST+A+B+V+Nit.Gas+Rotation (FIVE S STAR PUCHONG)
205/45R16
Achilles 2233@RM 216 Incl-GST+A+B+V+Nit.Gas+Rotation (FIVE S STAR PUCHONG)
Achilles ATR SPRORT@RM 216 Incl-GST+A+B+V+Nit.Gas+Rotation (FIVE S STAR PUCHONG)
Continental Max Contact MC5-RM295 (GST+V+B+A incl) mytayar.com@Klang Valley (Feb 16)
Continental MC5- RM305 Soon Heng Tyre & Car Services, Tanjung Malim (Oct 15)
HANKOOK H457 VENTUS V2 CONCEPT 2@RM 221 Incl-GST+A+B+V+Nit.Gas+Rotation (FIVE S STAR PUCHONG)
Hankook Ventus 2 Concept2 (H457)-RM220 Weng Heng Bukit Kemuning (Feb 16)
Hankook Ventus 2 Concept2 (H457)-RM254 (GST+V+B+A incl) mytayar.com@JB (Feb 16)
MICHELIN PS3@RM 511 Incl-GST+A+B+V+Nit.Gas+Rotation (FIVE S STAR PUCHONG)
Yokohama AR01-RM235 Weng Heng Bukit Kemuning (Apr-15)
205/50R16
Achilles ATR Sport- RM185 Weng Heng Bukit Kemuning (Mar-15)
Achilles ATR SPRORT@RM 236 Incl-GST+A+B+V+Nit.Gas+Rotation (FIVE S STAR PUCHONG)
Continental MC5- RM295 Soon Heng Tyre & Car Services, Tanjung Malim (Oct 15)
HANKOOK H457 VENTUS V2 CONCEPT 2@RM 226 Incl-GST+A+B+V+Nit.Gas+Rotation (FIVE S STAR PUCHONG)
Hankook Ventus 2 Concept2 (H457)-RM260 (GST+V+B+A incl) mytayar.com@JB (Feb 16)
Keter KT177- RM165 Weng Heng Bukit Kemuning (Jan-16)
Leao Lion Sport UHP-RM188 (GST+V+B+A incl) mytayar.com@Klang Valley (Feb 16)
MICHELIN PS3@RM 428 Incl-GST+A+B+V+Nit.Gas+Rotation (FIVE S STAR PUCHONG)
Silverstone Kruizer 1 NS700-RM253 (GST+B incl) mytayar.com@Ipoh (Feb 16)
Viking ProTech 5- RM220 Soon Heng Tyre & Car Services, Tanjung Malim (Oct 15)
Yokohama A-Drive R1-RM270 Weng Heng Bukit Kemuning (Jan-15)
Yokohama s.drive-RM330 Weng Heng Bukit Kemuning (Apr-15)
205/55R16
Achilles ATR SPRORT@RM 243 Incl-GST+A+B+V+Nit.Gas+Rotation (FIVE S STAR PUCHONG)
Achilles ATR SPRORT 2@RM 249 Incl-GST+A+B+V+Nit.Gas+Rotation (FIVE S STAR PUCHONG)
Bridgestone Ecopia EP200-RM265 Seng Hong Tyre & Battery Klang (Aug-15 purchased)
Bridgestone Ecopia EP200-RM265 Weng Heng Bukit Kemuning (Sept-15)
Bridgestone Ecopia EP200-RM270 Leong Seng Tyre Klang (opposite Hin Leong Aug-15 surveyed)
Bridgestone Potenza RE003-RM295 Seng Hong Tyre & Battery Klang (Aug-15 surveyed)
Bridgestone Potenza RE003-RM300 Leong Seng Tyre Klang (opposite Hin Leong Aug-15 surveyed)
Bridgestone Turanza GR100-RM290 Weng Heng Bukit Kemuning (Apr-15)
Bridgestone Turanza GR100-RM294.75 Hin Leong Klang (Only installation and balancing) (September 2015) ​
Bridgestone Turanza GR100-RM335 DriveIn (incl alignment and balancing), Sri Petaling (March 2015)​
Continental CPC2-RM285 Soon Heng Tyre & Car Services, Tanjung Malim (Oct 15)
Continental CPC2-RM295 Chin Heng Tyre, Klang (Feb 2015)
Dunlop Formula D05-RM230 Hup Seng (Puchong Utama) (May 2015)
Dunlop Formula D05-RM230 Weng Heng Bukit Kemuning (Jan-16)
Dunlop Formula D05- RM245 Soon Heng Tyre & Car Services, Tanjung Malim (Oct 15)
Falken ZE912-RM200 Weng Heng Bukit Kemuning (Jan-15)
HANKOOK H452 VENTUS S1 NOBLE2@RM 274 Incl-GST+A+B+V+Nit.Gas+Rotation (FIVE S STAR PUCHONG)
HANKOOK H457 VENTUS V2 CONCEPT 2@RM 218 Incl-GST+A+B+V+Nit.Gas+Rotation (FIVE S STAR PUCHONG)
HANKOOK K115 VENTUS PRIME 2@RM 304 Incl-GST+A+B+V+Nit.Gas+Rotation (FIVE S STAR PUCHONG)
Hankook Ventus 2 Concept2 (H457)-RM215 Weng Heng Bukit Kemuning (Feb 16)
Hankook Ventus 2 Concept2 (H457)-RM251 (GST+V+B+A incl) mytayar.com@JB (Feb 16)
Michelin Primacy 3ST-RM 350 Weng Heng Bukit Kemuning (incl balancing)(Mar 2015)
Michelin Primacy 3ST-RM 360 Ching Auto (Jan 2015)
MICHELIN PRIMACY 3ST@RM 395 Incl-GST+A+B+V+Nit.Gas+Rotation (FIVE S STAR PUCHONG)
Michelin PS3-RM340 Leong Seng Tyre Klang (opposite Hin Leong Aug-15 surveyed)
Michelin PS3-RM350 JS Auto Services Glenmarie (Aug-15 surveyed)
Michelin PS3-RM350 Weng Heng Bukit Kemuning (30 Jan 2015)
MICHELIN PS3@RM 408 Incl-GST+A+B+V+Nit.Gas+Rotation (FIVE S STAR PUCHONG)
Michelin XM2-RM310 Leong Seng Tyre Klang (opposite Hin Leong Aug-15 surveyed)
Michelin XM2-RM320 Weng Heng Bukit Kemuning (July-15)
MICHELIN XM2@RM 396 Incl-GST+A+B+V+Nit.Gas+Rotation (FIVE S STAR PUCHONG)
Nexen N8000-RM 265 Weng Heng Bukit Kemuning (Jan-15)
Silverstone Atlantis V7-RM236 (GST+B incl) mytayar.com@Ipoh (Feb 16)
Viking ProTech 5-RM235 (GST+V+B+A incl) mytayar.com@Klang Valley (Feb 16)
Viking ProTech 5- RM225 Soon Heng Tyre & Car Services, Tanjung Malim (Oct 15)
Yokohama BluEarth AE01-RM270 Hup Seng (Puchong Utama) (May 2015)
Yokohama C Drive 2-RM270 Weng Heng Bukit Kemuning (Jan-15)
205/60R16
HANKOOK K424 OPTIMO ME02@RM 271 Incl-GST+A+B+V+Nit.Gas+Rotation (FIVE S STAR PUCHONG)
MICHELIN PRIMACY 3ST@RM 415 Incl-GST+A+B+V+Nit.Gas+Rotation (FIVE S STAR PUCHONG)
MICHELIN XM2@RM 388 Incl-GST+A+B+V+Nit.Gas+Rotation (FIVE S STAR PUCHONG)
205/65R16
Achilles MULTIVAAN@RM 261 Incl-GST+A+B+V+Nit.Gas+Rotation (FIVE S STAR PUCHONG)
MICHELIN PRIMACY 3ST@RM 430 Incl-GST+A+B+V+Nit.Gas+Rotation (FIVE S STAR PUCHONG)
215/55R16
Achilles ATR SPRORT@RM 272 Incl-GST+A+B+V+Nit.Gas+Rotation (FIVE S STAR PUCHONG)
HANKOOK H452 VENTUS S1 NOBLE2@RM 303 Incl-GST+A+B+V+Nit.Gas+Rotation (FIVE S STAR PUCHONG)
HANKOOK H457 VENTUS V2 CONCEPT 2@RM 276 Incl-GST+A+B+V+Nit.Gas+Rotation (FIVE S STAR PUCHONG)
MICHELIN PRIMACY 3ST@RM 438 Incl-GST+A+B+V+Nit.Gas+Rotation (FIVE S STAR PUCHONG)
MICHELIN PS3@RM 537 Incl-GST+A+B+V+Nit.Gas+Rotation (FIVE S STAR PUCHONG)
215/60R16
Achilles 2233@RM 290 Incl-GST+A+B+V+Nit.Gas+Rotation (FIVE S STAR PUCHONG)
Achilles ATR SPRORT@RM 290 Incl-GST+A+B+V+Nit.Gas+Rotation (FIVE S STAR PUCHONG)
Achilles ATR SPRORT@RM 302 Incl-GST+A+B+V+Nit.Gas+Rotation (FIVE S STAR PUCHONG)
Continental ContiPremium Contact 2-RM280 Weng Heng Bukit Kemuning (Aug-15)
HANKOOK H436 KINERGY GT@RM 279 Incl-GST+A+B+V+Nit.Gas+Rotation (FIVE S STAR PUCHONG)
HANKOOK K424 OPTIMO ME02@RM 279 Incl-GST+A+B+V+Nit.Gas+Rotation (FIVE S STAR PUCHONG)
Michelin Primacy 3ST-RM335 Weng Heng Bukit Kemuning (Mar-15)
Michelin Primacy 3ST-RM338 Hin Leong Klang (Mar-15)
MICHELIN PRIMACY 3ST@RM 397 Incl-GST+A+B+V+Nit.Gas+Rotation (FIVE S STAR PUCHONG)
Michelin XM2-RM320 Weng Heng Bukit Kemuning (Aug-15)
MICHELIN XM2@RM 378 Incl-GST+A+B+V+Nit.Gas+Rotation (FIVE S STAR PUCHONG)
Silverstone Kruizer 1 NS500-RM246 (GST+B incl) mytayar.com@Ipoh (Feb 16)
Toyo NanoEnergy 3-RM285 Weng Heng Bukit Kemuning (Feb 16)
Toyo NanoEnergy 3-RM353 (GST+V+B+A incl) mytayar.com@JB (Feb 16)
Viking ProTech 5-RM285 (GST+V+B+A incl) mytayar.com@Klang Valley (Feb 16)
Yokohama C-Drive 2-RM300 Weng Heng Bukit Kemuning (Aug-15)
215/65R16
Achilles Desert Hawk H/T@RM 332 Incl-GST+A+B+V+Nit.Gas+Rotation (FIVE S STAR PUCHONG)
HANKOOK K415 OPTIMO@RM 297 Incl-GST+A+B+V+Nit.Gas+Rotation (FIVE S STAR PUCHONG)
HANKOOK RA18 VANTRA LT@RM 284 Incl-GST+A+B+V+Nit.Gas+Rotation (FIVE S STAR PUCHONG)
HANKOOK RH12 DYNAPRO HT@RM 363 Incl-GST+A+B+V+Nit.Gas+Rotation (FIVE S STAR PUCHONG)
MICHELIN PRIMACY SUV@RM 400 Incl-GST+A+B+V+Nit.Gas+Rotation (FIVE S STAR PUCHONG)
MICHELIN XM2@RM 421 Incl-GST+A+B+V+Nit.Gas+Rotation (FIVE S STAR PUCHONG)
215/70R16
Achilles Desert Hawk A/T@RM 330 Incl-GST+A+B+V+Nit.Gas+Rotation (FIVE S STAR PUCHONG)
Achilles Desert Hawk H/T@RM 322 Incl-GST+A+B+V+Nit.Gas+Rotation (FIVE S STAR PUCHONG)
Achilles Desert Hawk H/T@RM 371 Incl-GST+A+B+V+Nit.Gas+Rotation (FIVE S STAR PUCHONG)
HANKOOK RA18 VANTRA LT@RM 365 Incl-GST+A+B+V+Nit.Gas+Rotation (FIVE S STAR PUCHONG)
215/75R16
MICHELIN AGILIS@RM 459 Incl-GST+A+B+V+Nit.Gas+Rotation (FIVE S STAR PUCHONG)
215/85R16
Achilles Desert Hawk A/P@RM 408 Incl-GST+A+B+V+Nit.Gas+Rotation (FIVE S STAR PUCHONG)
225/50R16
Achilles ATR SPRORT@RM 306 Incl-GST+A+B+V+Nit.Gas+Rotation (FIVE S STAR PUCHONG)
HANKOOK H452 VENTUS S1 NOBLE2@RM 347 Incl-GST+A+B+V+Nit.Gas+Rotation (FIVE S STAR PUCHONG)
HANKOOK H457 VENTUS V2 CONCEPT 2@RM 314 Incl-GST+A+B+V+Nit.Gas+Rotation (FIVE S STAR PUCHONG)
MICHELIN PS3@RM 458 Incl-GST+A+B+V+Nit.Gas+Rotation (FIVE S STAR PUCHONG)
225/55R16
Achilles ATR SPRORT@RM 305 Incl-GST+A+B+V+Nit.Gas+Rotation (FIVE S STAR PUCHONG)
Achilles ATR SPRORT 2@RM 310 Incl-GST+A+B+V+Nit.Gas+Rotation (FIVE S STAR PUCHONG)
HANKOOK H452 VENTUS S1 NOBLE2@RM 338 Incl-GST+A+B+V+Nit.Gas+Rotation (FIVE S STAR PUCHONG)
HANKOOK H457 VENTUS V2 CONCEPT 2@RM 319 Incl-GST+A+B+V+Nit.Gas+Rotation (FIVE S STAR PUCHONG)
MICHELIN PRIMACY 3ST@RM 518 Incl-GST+A+B+V+Nit.Gas+Rotation (FIVE S STAR PUCHONG)
MICHELIN PS3@RM 597 Incl-GST+A+B+V+Nit.Gas+Rotation (FIVE S STAR PUCHONG)
225/60R16
MICHELIN PRIMACY 3ST@RM 511 Incl-GST+A+B+V+Nit.Gas+Rotation (FIVE S STAR PUCHONG)
225/70R16
Achilles Desert Hawk H/T@RM 370 Incl-GST+A+B+V+Nit.Gas+Rotation (FIVE S STAR PUCHONG)
Achilles Desert Hawk H/T@RM 395 Incl-GST+A+B+V+Nit.Gas+Rotation (FIVE S STAR PUCHONG)
225/75R16
Achilles Desert Hawk A/P@RM 462 Incl-GST+A+B+V+Nit.Gas+Rotation (FIVE S STAR PUCHONG)
235/60R16
HANKOOK K424 OPTIMO ME02@RM 373 Incl-GST+A+B+V+Nit.Gas+Rotation (FIVE S STAR PUCHONG)
HANKOOK RH12 DYNAPRO HT@RM 372 Incl-GST+A+B+V+Nit.Gas+Rotation (FIVE S STAR PUCHONG)
MICHELIN PRIMACY 3ST@RM 492 Incl-GST+A+B+V+Nit.Gas+Rotation (FIVE S STAR PUCHONG)
235/70R16
Achilles Desert Hawk H/T@RM 405 Incl-GST+A+B+V+Nit.Gas+Rotation (FIVE S STAR PUCHONG)
Achilles Desert Hawk H/T@RM 426 Incl-GST+A+B+V+Nit.Gas+Rotation (FIVE S STAR PUCHONG)
235/85R16
Achilles Desert Hawk A/P@RM 469 Incl-GST+A+B+V+Nit.Gas+Rotation (FIVE S STAR PUCHONG)
HANKOOK RH12 DYNAPRO HT@RM 459 Incl-GST+A+B+V+Nit.Gas+Rotation (FIVE S STAR PUCHONG)
245/70R16
Achilles Desert Hawk A/T@RM 413 Incl-GST+A+B+V+Nit.Gas+Rotation (FIVE S STAR PUCHONG)
Achilles Desert Hawk H/T@RM 443 Incl-GST+A+B+V+Nit.Gas+Rotation (FIVE S STAR PUCHONG)
Achilles Desert Hawk X-MT@RM 484 Incl-GST+A+B+V+Nit.Gas+Rotation (FIVE S STAR PUCHONG)
HANKOOK RF10 DYNAPRO AT@RM 349 Incl-GST+A+B+V+Nit.Gas+Rotation (FIVE S STAR PUCHONG)
MICHELIN LATITUDE CROSS@RM 580 Incl-GST+A+B+V+Nit.Gas+Rotation (FIVE S STAR PUCHONG)
MICHELIN PRIMACY SUV@RM 444 Incl-GST+A+B+V+Nit.Gas+Rotation (FIVE S STAR PUCHONG)
Silverstone Estiva X5-RM310 Weng Heng Bukit Kemuning (Feb 16)
Silverstone Estiva X5-RM385 (GST+V+B+A incl) mytayar.com@JB (Feb 16)
Yokohama G051 H/T-RM360 Weng Heng Bukit Kemuning (Mar-15)
245/75R16
Achilles Desert Hawk A/P@RM 477 Incl-GST+A+B+V+Nit.Gas+Rotation (FIVE S STAR PUCHONG)
Achilles Desert Hawk M/T@RM 527 Incl-GST+A+B+V+Nit.Gas+Rotation (FIVE S STAR PUCHONG)
HANKOOK RF10 DYNAPRO AT@RM 408 Incl-GST+A+B+V+Nit.Gas+Rotation (FIVE S STAR PUCHONG)
255/65R16
HANKOOK RA25 DYNAPRO HL@RM 463 Incl-GST+A+B+V+Nit.Gas+Rotation (FIVE S STAR PUCHONG)
255/70R16
Achilles Desert Hawk H/T@RM 468 Incl-GST+A+B+V+Nit.Gas+Rotation (FIVE S STAR PUCHONG)
Achilles Desert Hawk H/T@RM 514 Incl-GST+A+B+V+Nit.Gas+Rotation (FIVE S STAR PUCHONG)
HANKOOK RH12 DYNAPRO HT@RM 360 Incl-GST+A+B+V+Nit.Gas+Rotation (FIVE S STAR PUCHONG)
265/70R16
Achilles Desert Hawk A/T@RM 438 Incl-GST+A+B+V+Nit.Gas+Rotation (FIVE S STAR PUCHONG)
Achilles Desert Hawk H/T@RM 445 Incl-GST+A+B+V+Nit.Gas+Rotation (FIVE S STAR PUCHONG)
Achilles Desert Hawk H/T@RM 482 Incl-GST+A+B+V+Nit.Gas+Rotation (FIVE S STAR PUCHONG)
Achilles Desert Hawk X-MT@RM 537 Incl-GST+A+B+V+Nit.Gas+Rotation (FIVE S STAR PUCHONG)
HANKOOK RF10 DYNAPRO AT@RM 387 Incl-GST+A+B+V+Nit.Gas+Rotation (FIVE S STAR PUCHONG)
HANKOOK RH12 DYNAPRO HT@RM 370 Incl-GST+A+B+V+Nit.Gas+Rotation (FIVE S STAR PUCHONG)
MICHELIN LATITUDE CROSS@RM 592 Incl-GST+A+B+V+Nit.Gas+Rotation (FIVE S STAR PUCHONG)
MICHELIN PRIMACY SUV@RM 497 Incl-GST+A+B+V+Nit.Gas+Rotation (FIVE S STAR PUCHONG)
265/75R16
Achilles Desert Hawk X-MT@RM 551 Incl-GST+A+B+V+Nit.Gas+Rotation (FIVE S STAR PUCHONG)
275/70R16
Achilles Desert Hawk H/T@RM 454 Incl-GST+A+B+V+Nit.Gas+Rotation (FIVE S STAR PUCHONG)
MICHELIN LATITUDE CROSS@RM 755 Incl-GST+A+B+V+Nit.Gas+Rotation (FIVE S STAR PUCHONG)
165/40R17
Achilles ATR-K ECONOMIST@RM 216 Incl-GST+A+B+V+Nit.Gas+Rotation (FIVE S STAR PUCHONG)
195/40R17
Achilles ATR-K ECONOMIST@RM 226 Incl-GST+A+B+V+Nit.Gas+Rotation (FIVE S STAR PUCHONG)
205/40R17
Achilles 123@RM 383 Incl-GST+A+B+V+Nit.Gas+Rotation (FIVE S STAR PUCHONG)
Achilles ATR SPRORT@RM 246 Incl-GST+A+B+V+Nit.Gas+Rotation (FIVE S STAR PUCHONG)
Bridgestone Potenza Adrenalin RE002-RM350 Hin Leong Klang (Mac-15)
Bridgestone Potenza Adrenalin RE003-RM320 Weng Heng Bukit Kemuning (Mar-15)
205/45R17
Achilles 2233@RM 253 Incl-GST+A+B+V+Nit.Gas+Rotation (FIVE S STAR PUCHONG)
Achilles ATR SPRORT@RM 253 Incl-GST+A+B+V+Nit.Gas+Rotation (FIVE S STAR PUCHONG)
HANKOOK H452 VENTUS S1 NOBLE2@RM 280 Incl-GST+A+B+V+Nit.Gas+Rotation (FIVE S STAR PUCHONG)
Kumho Ecsta SPT KU31-RM288 (GST+V+B+A incl) mytayar.com@Klang Valley (Feb 16)
MICHELIN PS3@RM 451 Incl-GST+A+B+V+Nit.Gas+Rotation (FIVE S STAR PUCHONG)
Yokohama AR01- RM290 Weng Heng Bukit Kemuning (Sept-15)
205/50R17
Achilles ATR SPRORT@RM 261 Incl-GST+A+B+V+Nit.Gas+Rotation (FIVE S STAR PUCHONG)
HANKOOK H452 VENTUS S1 NOBLE2@RM 321 Incl-GST+A+B+V+Nit.Gas+Rotation (FIVE S STAR PUCHONG)
HANKOOK H457 VENTUS V2 CONCEPT 2@RM 291 Incl-GST+A+B+V+Nit.Gas+Rotation (FIVE S STAR PUCHONG)
MICHELIN PS3@RM 470 Incl-GST+A+B+V+Nit.Gas+Rotation (FIVE S STAR PUCHONG)
215/45R17
Achilles 2233@RM 258 Incl-GST+A+B+V+Nit.Gas+Rotation (FIVE S STAR PUCHONG)
Achilles ATR SPRORT@RM 258 Incl-GST+A+B+V+Nit.Gas+Rotation (FIVE S STAR PUCHONG)
Achilles ATR SPRORT 2@RM 269 Incl-GST+A+B+V+Nit.Gas+Rotation (FIVE S STAR PUCHONG)
Bridgestone RE003-RM310 Weng Heng Bukit Kemuning (Sept-15)
Bridgestone RE003-RM340 RS Tyre Ampang Waterfront (Aug-15)
Continental Max Contact MC5-RM330 (GST+V+B+A incl) mytayar.com@Klang Valley (Feb 16)
Continental MC5-RM280 Weng Heng Bukit Kemuning (Feb-15)
Continental MC5-RM320 Soon Heng Tyre & Car Services, Tanjung Malim (Oct 15)
Continental MC5 RM 305 at Hin Leong, Klang (Jan-15)
Dunlop D05-RM248 Soon Heng Tyre & Car Services, Tanjung Malim (Oct 15)
Falken Azenis FK453 (Japan)-RM345 CS Motorsports Kuantan Pahang (June-15)
Firestone (Japan) RM 280 at Hin Leong, Klang (Jan-15)
Goodyear Excellence-RM 220 Weng Heng Bukit Kemuning (Feb-16)
Goodyear Excellence-RM288 (GST+V+B+A incl) mytayar.com@Klang Valley (Feb 16)
HANKOOK H452 VENTUS S1 NOBLE2@RM 295 Incl-GST+A+B+V+Nit.Gas+Rotation (FIVE S STAR PUCHONG)
HANKOOK H457 VENTUS V2 CONCEPT 2@RM 223 Incl-GST+A+B+V+Nit.Gas+Rotation (FIVE S STAR PUCHONG)
Hankook V12 Evo 2-RM 330 Weng Heng Bukit Kemuning (Feb-16)
Hankook V12 Evo 2-RM380 Acanta Aututech (Sep-15)
Hankook Ventus 2 Concept2 (H457)-RM220 Weng Heng Bukit Kemuning (Feb-16)
Hankook Ventus 2 Concept2 (H457)-RM256 (GST+V+B+A incl) mytayar.com@JB (Feb 16)
Michelin Primacy 3ST-Rm365 Weng Heng Bukit Kemuning (Mar-15)
MICHELIN PRIMACY 3ST@RM 417 Incl-GST+A+B+V+Nit.Gas+Rotation (FIVE S STAR PUCHONG)
Michelin PS3-RM390 Weng Heng Bukit Kemuning (Mar-15)
Michelin PS3-RM415 Hin Leong Klang (Jan-16)
MICHELIN PS3@RM 467 Incl-GST+A+B+V+Nit.Gas+Rotation (FIVE S STAR PUCHONG)
Toyo C1S RM 405 at Hin Leong, Klang (Jan-15)
Toyo NanoEnergy 3 RM (M'sia) RM 310 at Hin Leong, Klang (Jan-15)
Toyo T1Sport RM 410 at Hin Leong, Klang (Jan-15)
Toyo TeoPlus (M'sia) RM 390 at Hin Leong, Klang (Jan-15)
Viking Protech 5- RM215 Soon Heng Tyre & Car Services, Tanjung Malim (Oct 15)
Yokohama AE50 BlueEarth RM 305 Weng Heng Bukit Kemuning (Jan-16)
Yokohama AR01 RM 315 at Hin Leong, Klang (Jan-15)
Yokohama S-Drive-RM350 Weng Heng Bukit Kemuning (Jan-15)
215/50R17
Achilles ATR SPRORT@RM 287 Incl-GST+A+B+V+Nit.Gas+Rotation (FIVE S STAR PUCHONG)
Bridgestone GR100-RM395 Bayan Baru Tyres Penang (June 15)
Bridgestone GR100-RM400 Xin Fu Tyre Batu Lanchang Penang (July 15)
Continental MC5-RM375 Weng Heng Bukit Kemuning (Nov 15)
Goodyear Efficientgrip-RM460 Hi Grade Carcare Bayan Lepas Penang (June 15)
HANKOOK H452 VENTUS S1 NOBLE2@RM 332 Incl-GST+A+B+V+Nit.Gas+Rotation (FIVE S STAR PUCHONG)
HANKOOK H457 VENTUS V2 CONCEPT 2@RM 281 Incl-GST+A+B+V+Nit.Gas+Rotation (FIVE S STAR PUCHONG)
HANKOOK K115 VENTUS PRIME 2@RM 390 Incl-GST+A+B+V+Nit.Gas+Rotation (FIVE S STAR PUCHONG)
Hankook V2 Concept2 (H457)-RM 280 Weng Heng Bukit Kemuning (Feb-16)
Hankook Ventus 2 Concept2 (H457)-RM317 (GST+V+B+A incl) mytayar.com@Klang Valley (Feb 16)
Michelin 3ST-RM540 Toyo Bayan Lepas Penang (June 15)
Michelin Primacy 3 ST-RM552 (GST+V+B+A incl) mytayar.com@JB (Feb 16)
MICHELIN PRIMACY 3ST@RM 568 Incl-GST+A+B+V+Nit.Gas+Rotation (FIVE S STAR PUCHONG)
Michelin PS3-RM550 Toyo BAyan Lepas Penang (June 15)
MICHELIN PS3@RM 544 Incl-GST+A+B+V+Nit.Gas+Rotation (FIVE S STAR PUCHONG)
Silverstone Atlantis V7-RM280 (GST+B incl) mytayar.com@Ipoh (Feb 16)
Toyo Nanoenergy 3-RM325 Weng Heng Bukit Kemuning (Feb-16)
Toyo Nanoenergy 3-RM360 Toyo Bayan Lepas Penang (June 15)
Yokohama BluEarth AE50-RM330 Weng Heng Bukit Kemuning (Jan 16)
215/55R17
HANKOOK H436 KINERGY GT@RM 317 Incl-GST+A+B+V+Nit.Gas+Rotation (FIVE S STAR PUCHONG)
HANKOOK H452 VENTUS S1 NOBLE2@RM 324 Incl-GST+A+B+V+Nit.Gas+Rotation (FIVE S STAR PUCHONG)
HANKOOK K415 OPTIMO@RM 317 Incl-GST+A+B+V+Nit.Gas+Rotation (FIVE S STAR PUCHONG)
MICHELIN PRIMACY 3ST@RM 528 Incl-GST+A+B+V+Nit.Gas+Rotation (FIVE S STAR PUCHONG)
MICHELIN PS3@RM 565 Incl-GST+A+B+V+Nit.Gas+Rotation (FIVE S STAR PUCHONG)
215/60R17
MICHELIN PRIMACY 3ST@RM 537 Incl-GST+A+B+V+Nit.Gas+Rotation (FIVE S STAR PUCHONG)
225/45R17
Achilles ATR Sport-RM250 Hin Leong Klang, Jan '16
Achilles ATR SPRORT@RM 304 Incl-GST+A+B+V+Nit.Gas+Rotation (FIVE S STAR PUCHONG)
Bridgestone MY-02-RM275 OS Autocare (Shah Alam, Jul-15)
Bridgestone RE003-RM370 Speed Racing Tyres (Bangi, June '15)
Bridgestone RE003-RM370 Weng Heng Bukit Kemuning (July 15)
Bridgestone RE003-RM390 OS Autocare (Shah Alam, Jul-15)
Bridgestone RE003-RM400 Hin Leong Klang, Jan '16
Continental Max Contact MC5-RM375 Weng Heng Bukit Kemuning (Feb-16)
Continental Max Contact MC5-RM460 (GST+V+B+A incl) mytayar.com@Klang Valley (Feb 16)
Continental MC5- RM440 Soon Heng Tyre & Car Services, Tanjung Malim (Oct 15)
Goodyear Excellence-RM290 Weng Heng Bukit Kemuning (Feb-16)
Goodyear Excellence-RM310 Hin Leong Klang, Jan '16
Goodyear Excellence-RM313 (GST+V+B+A incl) mytayar.com@Seremban (Feb 16)
Goodyear F1 Asymmetric 2-RM530 OS Autocare (Shah Alam, Jul-15)
HANKOOK H452 VENTUS S1 NOBLE2@RM 312 Incl-GST+A+B+V+Nit.Gas+Rotation (FIVE S STAR PUCHONG)
HANKOOK H457 VENTUS V2 CONCEPT 2@RM 280 Incl-GST+A+B+V+Nit.Gas+Rotation (FIVE S STAR PUCHONG)
HANKOOK K115 VENTUS PRIME 2@RM 370 Incl-GST+A+B+V+Nit.Gas+Rotation (FIVE S STAR PUCHONG)
Michelin Premacy 3ST-RM400 Hin Leong Klang, Jan '16
MICHELIN PRIMACY 3ST@RM 466 Incl-GST+A+B+V+Nit.Gas+Rotation (FIVE S STAR PUCHONG)
Michelin PS3-RM480 Weng Heng Bukit Kemuning (July-15)
Michelin PS3-RM490 OS Autocare (Shah Alam, Jul-15)
Michelin PS3-RM500 Hin Leong Klang, Jan '16
Michelin PS3-RM540 Pang Tyres and Auto Service Center (Bangi, Jan '15)
MICHELIN PS3@RM 580 Incl-GST+A+B+V+Nit.Gas+Rotation (FIVE S STAR PUCHONG)
Nexen N8000-RM340 Ban Hooi@Klang (Apr-2015)
Toyo C1S (prod yr '14)-RM390 Hin Leong Klang, Jan '16
Toyo Nano 3-RM300 Hin Leong Klang, Jan '16
225/50R17
Achiles Sport-RM260 Weng Heng Bukit Kemuning (Jan-15)
Achilles ATR SPRORT@RM 307 Incl-GST+A+B+V+Nit.Gas+Rotation (FIVE S STAR PUCHONG)
Achilles ATR SPRORT 2@RM 314 Incl-GST+A+B+V+Nit.Gas+Rotation (FIVE S STAR PUCHONG)
Bridgestone Potenza S001-RM1135 (GST+V+B+A incl) mytayar.com@Klang Valley (Feb 16)
Continental MC5-RM480 Wah Hoe Tyre Services Sdn Bhd (Tmn Mayang) (Jan-15)
Continental MC5- RM445 Soon Heng Tyre & Car Services, Tanjung Malim (Oct 15)
Dunlop Direzza DZ102-RM380 Wah Hoe Tyre Services Sdn Bhd (Tmn Mayang) (Jan-15)
Goodyear Excellence-RM345 Weng Heng Bukit Kemuning (Feb-16)
Goodyear Excellence-RM370 Wah Hoe Tyre Services Sdn Bhd (Tmn Mayang) (Jan-15)
Goodyear Excellence-RM372 (GST+V+B+A incl) mytayar.com@Seremban (Feb 16)
HANKOOK H452 VENTUS S1 NOBLE2@RM 341 Incl-GST+A+B+V+Nit.Gas+Rotation (FIVE S STAR PUCHONG)
HANKOOK H457 VENTUS V2 CONCEPT 2@RM 297 Incl-GST+A+B+V+Nit.Gas+Rotation (FIVE S STAR PUCHONG)
Hankook Ventus S1 Noble2-RM335 Weng Heng Bukit Kemuning (Jan-15)
Maxxis Victra I-Pro-Rm380 Weng Heng Bukit Kemuning (Jan-15)
Michelin Primacy 3ST-RM 450 Weng Heng Bukit Kemuning (Jan-15)
Michelin Primacy 3ST-RM450 Wah Hoe Tyre Services Sdn Bhd (Tmn Mayang) (Jan-15)
MICHELIN PRIMACY 3ST@RM 1150 Incl-GST+A+B+V+Nit.Gas+Rotation (FIVE S STAR PUCHONG)
MICHELIN PRIMACY 3ST@RM 523 Incl-GST+A+B+V+Nit.Gas+Rotation (FIVE S STAR PUCHONG)
MICHELIN PS3@RM 619 Incl-GST+A+B+V+Nit.Gas+Rotation (FIVE S STAR PUCHONG)
Neuton NT8000-RM270 Weng Heng Bukit Kemuning (Jan-15)
Nexen N8000-RM355 Weng Heng Bukit Kemuning (Jan-15)
Nexen N8000-RM365 Weng Heng Bukit Kemuning (Mar-15)
Pirelli Cinturato-RM550 Weng Heng Bukit Kemuning (Jan-15)
Toyo Proxes C1S / T1R-RM455 Wah Hoe Tyre Services Sdn Bhd (Tmn Mayang) (Jan-15)
225/55R17
Achilles ATR SPRORT@RM 317 Incl-GST+A+B+V+Nit.Gas+Rotation (FIVE S STAR PUCHONG)
Achilles ATR SPRORT 2@RM 323 Incl-GST+A+B+V+Nit.Gas+Rotation (FIVE S STAR PUCHONG)
HANKOOK H452 VENTUS S1 NOBLE2@RM 374 Incl-GST+A+B+V+Nit.Gas+Rotation (FIVE S STAR PUCHONG)
MICHELIN LATITUDE TOUR HP@RM 785 Incl-GST+A+B+V+Nit.Gas+Rotation (FIVE S STAR PUCHONG)
MICHELIN PRIMACY 3ST@RM 1160 Incl-GST+A+B+V+Nit.Gas+Rotation (FIVE S STAR PUCHONG)
MICHELIN PRIMACY 3ST@RM 551 Incl-GST+A+B+V+Nit.Gas+Rotation (FIVE S STAR PUCHONG)
225/60R17
HANKOOK H426 OPTIMO@RM 452 Incl-GST+A+B+V+Nit.Gas+Rotation (FIVE S STAR PUCHONG)
225/65R17
Achilles Desert Hawk H/T@RM 414 Incl-GST+A+B+V+Nit.Gas+Rotation (FIVE S STAR PUCHONG)
HANKOOK RH12 DYNAPRO HT@RM 373 Incl-GST+A+B+V+Nit.Gas+Rotation (FIVE S STAR PUCHONG)
MICHELIN PRIMACY SUV@RM 531 Incl-GST+A+B+V+Nit.Gas+Rotation (FIVE S STAR PUCHONG)
235/45R17
Achilles 123@RM 423 Incl-GST+A+B+V+Nit.Gas+Rotation (FIVE S STAR PUCHONG)
Achilles ATR SPRORT@RM 311 Incl-GST+A+B+V+Nit.Gas+Rotation (FIVE S STAR PUCHONG)
Achilles ATR SPRORT 2@RM 318 Incl-GST+A+B+V+Nit.Gas+Rotation (FIVE S STAR PUCHONG)
Bridgestone Potenza Adrenaline RE003-RM420 We Auto Pandan Indah (May-15)
Continental MC5- RM550 Soon Heng Tyre & Car Services, Tanjung Malim (Oct 15)
HANKOOK H452 VENTUS S1 NOBLE2@RM 339 Incl-GST+A+B+V+Nit.Gas+Rotation (FIVE S STAR PUCHONG)
HANKOOK H457 VENTUS V2 CONCEPT 2@RM 307 Incl-GST+A+B+V+Nit.Gas+Rotation (FIVE S STAR PUCHONG)
Michelin Pilot Sport 3-RM565 Weng Heng Bukit Kemuning (Feb-16)
Michelin Pilot Sport 3-RM830 (GST+V+B+A incl) mytayar.com@Klang Valley (Feb 16)
MICHELIN PS3@RM 636 Incl-GST+A+B+V+Nit.Gas+Rotation (FIVE S STAR PUCHONG)
235/50R17
HANKOOK H452 VENTUS S1 NOBLE2@RM 414 Incl-GST+A+B+V+Nit.Gas+Rotation (FIVE S STAR PUCHONG)
MICHELIN PRIMACY 3ST@RM 619 Incl-GST+A+B+V+Nit.Gas+Rotation (FIVE S STAR PUCHONG)
235/55R17
HANKOOK H452 VENTUS S1 NOBLE2@RM 399 Incl-GST+A+B+V+Nit.Gas+Rotation (FIVE S STAR PUCHONG)
HANKOOK RA23 DYNAPRO HP@RM 490 Incl-GST+A+B+V+Nit.Gas+Rotation (FIVE S STAR PUCHONG)
MICHELIN LATITUDE TOUR HP@RM 826 Incl-GST+A+B+V+Nit.Gas+Rotation (FIVE S STAR PUCHONG)
MICHELIN PRIMACY 3ST@RM 594 Incl-GST+A+B+V+Nit.Gas+Rotation (FIVE S STAR PUCHONG)
235/60R17
Achilles Desert Hawk H/T@RM 392 Incl-GST+A+B+V+Nit.Gas+Rotation (FIVE S STAR PUCHONG)
235/65R17
Achilles Desert Hawk H/T@RM 391 Incl-GST+A+B+V+Nit.Gas+Rotation (FIVE S STAR PUCHONG)
MICHELIN PRIMACY SUV@RM 587 Incl-GST+A+B+V+Nit.Gas+Rotation (FIVE S STAR PUCHONG)
245/40R17
Achilles ATR SPRORT 2@RM 356 Incl-GST+A+B+V+Nit.Gas+Rotation (FIVE S STAR PUCHONG)
HANKOOK H452 VENTUS S1 NOBLE2@RM 420 Incl-GST+A+B+V+Nit.Gas+Rotation (FIVE S STAR PUCHONG)
MICHELIN PRIMACY HP@RM 667 Incl-GST+A+B+V+Nit.Gas+Rotation (FIVE S STAR PUCHONG)
MICHELIN PS3@RM 821 Incl-GST+A+B+V+Nit.Gas+Rotation (FIVE S STAR PUCHONG)
245/45R17
Achilles ATR SPRORT@RM 349 Incl-GST+A+B+V+Nit.Gas+Rotation (FIVE S STAR PUCHONG)
HANKOOK H452 VENTUS S1 NOBLE2@RM 452 Incl-GST+A+B+V+Nit.Gas+Rotation (FIVE S STAR PUCHONG)
HANKOOK H457 VENTUS V2 CONCEPT 2@RM 386 Incl-GST+A+B+V+Nit.Gas+Rotation (FIVE S STAR PUCHONG)
MICHELIN PRIMACY 3ST@RM 667 Incl-GST+A+B+V+Nit.Gas+Rotation (FIVE S STAR PUCHONG)
MICHELIN PS3@RM 775 Incl-GST+A+B+V+Nit.Gas+Rotation (FIVE S STAR PUCHONG)
245/70R17
Achilles Desert Hawk H/T@RM 411 Incl-GST+A+B+V+Nit.Gas+Rotation (FIVE S STAR PUCHONG)
255/35R17
Achilles 123@RM 466 Incl-GST+A+B+V+Nit.Gas+Rotation (FIVE S STAR PUCHONG)
255/40R17
Achilles ATR SPRORT@RM 357 Incl-GST+A+B+V+Nit.Gas+Rotation (FIVE S STAR PUCHONG)
MICHELIN PS2@RM 964 Incl-GST+A+B+V+Nit.Gas+Rotation (FIVE S STAR PUCHONG)
265/65R17
Achilles Desert Hawk A/T@RM 433 Incl-GST+A+B+V+Nit.Gas+Rotation (FIVE S STAR PUCHONG)
Achilles Desert Hawk H/T@RM 430 Incl-GST+A+B+V+Nit.Gas+Rotation (FIVE S STAR PUCHONG)
Achilles Desert Hawk X-MT@RM 601 Incl-GST+A+B+V+Nit.Gas+Rotation (FIVE S STAR PUCHONG)
HANKOOK RF10 DYNAPRO AT@RM 535 Incl-GST+A+B+V+Nit.Gas+Rotation (FIVE S STAR PUCHONG)
HANKOOK RH12 DYNAPRO HT@RM 399 Incl-GST+A+B+V+Nit.Gas+Rotation (FIVE S STAR PUCHONG)
MICHELIN CROSS TERRAIN@RM 731 Incl-GST+A+B+V+Nit.Gas+Rotation (FIVE S STAR PUCHONG)
MICHELIN PRIMACY SUV@RM 617 Incl-GST+A+B+V+Nit.Gas+Rotation (FIVE S STAR PUCHONG)
265/70R17
Achilles Desert Hawk H/T@RM 464 Incl-GST+A+B+V+Nit.Gas+Rotation (FIVE S STAR PUCHONG)
HANKOOK RF10 DYNAPRO AT@RM 692 Incl-GST+A+B+V+Nit.Gas+Rotation (FIVE S STAR PUCHONG)
275/55R17
MICHELIN LATITUDE TOUR HP@RM 1037 Incl-GST+A+B+V+Nit.Gas+Rotation (FIVE S STAR PUCHONG)
275/60R17
Achilles Desert Hawk H/T@RM 459 Incl-GST+A+B+V+Nit.Gas+Rotation (FIVE S STAR PUCHONG)
275/65R17
MICHELIN LATITUDE CROSS@RM 838 Incl-GST+A+B+V+Nit.Gas+Rotation (FIVE S STAR PUCHONG)
165/40R18
Achilles ATR-K ECONOMIST@RM 232 Incl-GST+A+B+V+Nit.Gas+Rotation (FIVE S STAR PUCHONG)
215/35R18
Achilles ATR SPRORT@RM 309 Incl-GST+A+B+V+Nit.Gas+Rotation (FIVE S STAR PUCHONG)
215/40R18
Achilles ATR SPRORT@RM 360 Incl-GST+A+B+V+Nit.Gas+Rotation (FIVE S STAR PUCHONG)
HANKOOK K115 VENTUS PRIME 2@RM 429 Incl-GST+A+B+V+Nit.Gas+Rotation (FIVE S STAR PUCHONG)
215/45R18
Achilles ATR SPRORT@RM 372 Incl-GST+A+B+V+Nit.Gas+Rotation (FIVE S STAR PUCHONG)
225/35R18
Achilles ATR SPRORT 2@RM 349 Incl-GST+A+B+V+Nit.Gas+Rotation (FIVE S STAR PUCHONG)
225/40R18
Achilles ATR SPRORT@RM 326 Incl-GST+A+B+V+Nit.Gas+Rotation (FIVE S STAR PUCHONG)
Achilles ATR SPRORT 2@RM 333 Incl-GST+A+B+V+Nit.Gas+Rotation (FIVE S STAR PUCHONG)
Bridgestone Potenza RE003-RM580 Hup Shun, Sunway (Nov-15)
Firestone TZ700-RM350 (GST+V+B+A incl) mytayar.com@Klang Valley (Feb 16)
HANKOOK H452 VENTUS S1 NOBLE2@RM 305 Incl-GST+A+B+V+Nit.Gas+Rotation (FIVE S STAR PUCHONG)
HANKOOK H457 VENTUS V2 CONCEPT 2@RM 279 Incl-GST+A+B+V+Nit.Gas+Rotation (FIVE S STAR PUCHONG)
MICHELIN PS2@RM 1026 Incl-GST+A+B+V+Nit.Gas+Rotation (FIVE S STAR PUCHONG)
MICHELIN PS2@RM 1246 Incl-GST+A+B+V+Nit.Gas+Rotation (FIVE S STAR PUCHONG)
MICHELIN PS3@RM 861 Incl-GST+A+B+V+Nit.Gas+Rotation (FIVE S STAR PUCHONG)
225/45R18
Achilles ATR SPRORT@RM 337 Incl-GST+A+B+V+Nit.Gas+Rotation (FIVE S STAR PUCHONG)
Achilles ATR SPRORT 2@RM 344 Incl-GST+A+B+V+Nit.Gas+Rotation (FIVE S STAR PUCHONG)
Bridgestone Potenza Adrenaline RE003-RM460 Weng Heng Bukit kemuning (May-15)
Bridgestone Potenza Adrenaline RE003-RM540 We Auto Pandan Indah (May-15)
Dunlop LM704- RM375 Soon Heng Tyre & Car Services, Tanjung Malim (Oct 15)
HANKOOK H452 VENTUS S1 NOBLE2@RM 323 Incl-GST+A+B+V+Nit.Gas+Rotation (FIVE S STAR PUCHONG)
MICHELIN PRIMACY 3ST@RM 1154 Incl-GST+A+B+V+Nit.Gas+Rotation (FIVE S STAR PUCHONG)
Michelin PS3-RM600 Weng Heng Bukit Kemuning (Aug-15)
MICHELIN PS3@RM 723 Incl-GST+A+B+V+Nit.Gas+Rotation (FIVE S STAR PUCHONG)
MICHELIN PSS@RM 1052 Incl-GST+A+B+V+Nit.Gas+Rotation (FIVE S STAR PUCHONG)
Nexen N8000- RM430 Weng Heng Bukit Kemuning (Jan-15)
Viking ProTech 5-RM320 (GST+V+B+A incl) mytayar.com@Klang Valley (Feb 16)
225/50R18
Achilles ATR SPRORT@RM 361 Incl-GST+A+B+V+Nit.Gas+Rotation (FIVE S STAR PUCHONG)
HANKOOK H452 VENTUS S1 NOBLE2@RM 411 Incl-GST+A+B+V+Nit.Gas+Rotation (FIVE S STAR PUCHONG)
MICHELIN PRIMACY LC@RM 713 Incl-GST+A+B+V+Nit.Gas+Rotation (FIVE S STAR PUCHONG)
225/55R18
Achilles ATR SPRORT 2@RM 394 Incl-GST+A+B+V+Nit.Gas+Rotation (FIVE S STAR PUCHONG)
Achilles Desert Hawk H/T@RM 386 Incl-GST+A+B+V+Nit.Gas+Rotation (FIVE S STAR PUCHONG)
MICHELIN PRIMACY 3ST@RM 567 Incl-GST+A+B+V+Nit.Gas+Rotation (FIVE S STAR PUCHONG)
225/80R18
MICHELIN AGILIS@RM 865 Incl-GST+A+B+V+Nit.Gas+Rotation (FIVE S STAR PUCHONG)
235/40R18
Achilles 123@RM 460 Incl-GST+A+B+V+Nit.Gas+Rotation (FIVE S STAR PUCHONG)
Achilles ATR SPRORT 2@RM 348 Incl-GST+A+B+V+Nit.Gas+Rotation (FIVE S STAR PUCHONG)
Dunlop LM704- RM455 Soon Heng Tyre & Car Services, Tanjung Malim (Oct 15)
Firestone TZ700-RM388 (GST+V+B+A incl) mytayar.com@Klang Valley (Feb 16)
HANKOOK H452 VENTUS S1 NOBLE2@RM 363 Incl-GST+A+B+V+Nit.Gas+Rotation (FIVE S STAR PUCHONG)
MICHELIN PS2@RM 1074 Incl-GST+A+B+V+Nit.Gas+Rotation (FIVE S STAR PUCHONG)
MICHELIN PS3@RM 851 Incl-GST+A+B+V+Nit.Gas+Rotation (FIVE S STAR PUCHONG)
Nexen N8000-RM445 Weng Heng Bukit Kemuning (May-15)
235/45R18
Achilles ATR SPRORT 2@RM 398 Incl-GST+A+B+V+Nit.Gas+Rotation (FIVE S STAR PUCHONG)
HANKOOK H452 VENTUS S1 NOBLE2@RM 412 Incl-GST+A+B+V+Nit.Gas+Rotation (FIVE S STAR PUCHONG)
HANKOOK K115 VENTUS PRIME 2@RM 452 Incl-GST+A+B+V+Nit.Gas+Rotation (FIVE S STAR PUCHONG)
MICHELIN PS3@RM 793 Incl-GST+A+B+V+Nit.Gas+Rotation (FIVE S STAR PUCHONG)
235/50R18
Achilles ATR SPRORT 2@RM 452 Incl-GST+A+B+V+Nit.Gas+Rotation (FIVE S STAR PUCHONG)
Achilles Desert Hawk H/T@RM 409 Incl-GST+A+B+V+Nit.Gas+Rotation (FIVE S STAR PUCHONG)
HANKOOK H452 VENTUS S1 NOBLE2@RM 430 Incl-GST+A+B+V+Nit.Gas+Rotation (FIVE S STAR PUCHONG)
MICHELIN PRIMACY 3ST@RM 624 Incl-GST+A+B+V+Nit.Gas+Rotation (FIVE S STAR PUCHONG)
235/55R18
Achilles Desert Hawk H/T@RM 404 Incl-GST+A+B+V+Nit.Gas+Rotation (FIVE S STAR PUCHONG)
HANKOOK H426 OPTIMO@RM 493 Incl-GST+A+B+V+Nit.Gas+Rotation (FIVE S STAR PUCHONG)
MICHELIN LATITUDE TOUR HP@RM 925 Incl-GST+A+B+V+Nit.Gas+Rotation (FIVE S STAR PUCHONG)
235/60R18
Achilles Desert Hawk H/T@RM 388 Incl-GST+A+B+V+Nit.Gas+Rotation (FIVE S STAR PUCHONG)
HANKOOK RA33 DYNAPRO HP2@RM 593 Incl-GST+A+B+V+Nit.Gas+Rotation (FIVE S STAR PUCHONG)
MICHELIN LATITUDE TOUR HP@RM 865 Incl-GST+A+B+V+Nit.Gas+Rotation (FIVE S STAR PUCHONG)
245/40R18
Achilles ATR SPRORT@RM 440 Incl-GST+A+B+V+Nit.Gas+Rotation (FIVE S STAR PUCHONG)
Achilles ATR SPRORT 2@RM 453 Incl-GST+A+B+V+Nit.Gas+Rotation (FIVE S STAR PUCHONG)
Dunlop LM704- RM495 Soon Heng Tyre & Car Services, Tanjung Malim (Oct 15)
HANKOOK H452 VENTUS S1 NOBLE2@RM 419 Incl-GST+A+B+V+Nit.Gas+Rotation (FIVE S STAR PUCHONG)
Michelin Pilot Sport 3-RM845 Weng Heng Bukit Kemuning (Feb-16)
Michelin Pilot Sport 3-RM945 (GST+V+B+A incl) mytayar.com@Klang Valley (Feb 16)
MICHELIN PRIMACY 3ST@RM 1218 Incl-GST+A+B+V+Nit.Gas+Rotation (FIVE S STAR PUCHONG)
MICHELIN PS3@RM 958 Incl-GST+A+B+V+Nit.Gas+Rotation (FIVE S STAR PUCHONG)
MICHELIN PSS@RM 1193 Incl-GST+A+B+V+Nit.Gas+Rotation (FIVE S STAR PUCHONG)
Nexen N8000-RM510 Weng Heng Bukit Kemuning (May-15)
245/45R18
Achilles ATR SPRORT@RM 447 Incl-GST+A+B+V+Nit.Gas+Rotation (FIVE S STAR PUCHONG)
Achilles ATR SPRORT 2@RM 459 Incl-GST+A+B+V+Nit.Gas+Rotation (FIVE S STAR PUCHONG)
HANKOOK H452 VENTUS S1 NOBLE2@RM 444 Incl-GST+A+B+V+Nit.Gas+Rotation (FIVE S STAR PUCHONG)
MICHELIN PRIMACY 3ST@RM 771 Incl-GST+A+B+V+Nit.Gas+Rotation (FIVE S STAR PUCHONG)
MICHELIN PSS@RM 1251 Incl-GST+A+B+V+Nit.Gas+Rotation (FIVE S STAR PUCHONG)
245/50R18
HANKOOK H452 VENTUS S1 NOBLE2@RM 499 Incl-GST+A+B+V+Nit.Gas+Rotation (FIVE S STAR PUCHONG)
MICHELIN PRIMACY 3ST@RM 873 Incl-GST+A+B+V+Nit.Gas+Rotation (FIVE S STAR PUCHONG)
255/35R18
Achilles 123@RM 480 Incl-GST+A+B+V+Nit.Gas+Rotation (FIVE S STAR PUCHONG)
Bridgestone Potenza Adrenalin RE003-RM720 (GST+V+B+A incl) mytayar.com@Klang Valley (Feb 16)
HANKOOK H452 VENTUS S1 NOBLE2@RM 581 Incl-GST+A+B+V+Nit.Gas+Rotation (FIVE S STAR PUCHONG)
MICHELIN PS2@RM 1549 Incl-GST+A+B+V+Nit.Gas+Rotation (FIVE S STAR PUCHONG)
Michelin PS3-RM920 Weng Heng Bukit Kemuning (Feb-16)
MICHELIN PS3@RM 1042 Incl-GST+A+B+V+Nit.Gas+Rotation (FIVE S STAR PUCHONG)
Nexen N8000-RM545 Weng Heng Bukit Kemuning (May-15)
255/40R18
HANKOOK H452 VENTUS S1 NOBLE2@RM 482 Incl-GST+A+B+V+Nit.Gas+Rotation (FIVE S STAR PUCHONG)
255/45R18
HANKOOK H452 VENTUS S1 NOBLE2@RM 459 Incl-GST+A+B+V+Nit.Gas+Rotation (FIVE S STAR PUCHONG)
MICHELIN PRIMACY 3ST@RM 713 Incl-GST+A+B+V+Nit.Gas+Rotation (FIVE S STAR PUCHONG)
255/55R18
Achilles Desert Hawk H/T@RM 474 Incl-GST+A+B+V+Nit.Gas+Rotation (FIVE S STAR PUCHONG)
MICHELIN LATITUDE SPORT 3@RM 1457 Incl-GST+A+B+V+Nit.Gas+Rotation (FIVE S STAR PUCHONG)
MICHELIN LATITUDE SPORT 3@RM 1774 Incl-GST+A+B+V+Nit.Gas+Rotation (FIVE S STAR PUCHONG)
MICHELIN LATITUDE TOUR HP@RM 1201 Incl-GST+A+B+V+Nit.Gas+Rotation (FIVE S STAR PUCHONG)
255/60R18
MICHELIN LATITUDE TOUR HP@RM 971 Incl-GST+A+B+V+Nit.Gas+Rotation (FIVE S STAR PUCHONG)
265/35R18
Achilles 123@RM 554 Incl-GST+A+B+V+Nit.Gas+Rotation (FIVE S STAR PUCHONG)
Achilles ATR SPRORT@RM 481 Incl-GST+A+B+V+Nit.Gas+Rotation (FIVE S STAR PUCHONG)
Achilles ATR SPRORT 2@RM 497 Incl-GST+A+B+V+Nit.Gas+Rotation (FIVE S STAR PUCHONG)
HANKOOK H452 VENTUS S1 NOBLE2@RM 590 Incl-GST+A+B+V+Nit.Gas+Rotation (FIVE S STAR PUCHONG)
MICHELIN PS3@RM 1071 Incl-GST+A+B+V+Nit.Gas+Rotation (FIVE S STAR PUCHONG)
265/40R18
MICHELIN PS2@RM 1290 Incl-GST+A+B+V+Nit.Gas+Rotation (FIVE S STAR PUCHONG)
MICHELIN PSS@RM 1363 Incl-GST+A+B+V+Nit.Gas+Rotation (FIVE S STAR PUCHONG)
265/60R18
Achilles Desert Hawk X-MT@RM 589 Incl-GST+A+B+V+Nit.Gas+Rotation (FIVE S STAR PUCHONG)
MICHELIN LATITUDE TOUR HP@RM 799 Incl-GST+A+B+V+Nit.Gas+Rotation (FIVE S STAR PUCHONG)
MICHELIN PRIMACY SUV@RM 752 Incl-GST+A+B+V+Nit.Gas+Rotation (FIVE S STAR PUCHONG)
275/35R18
Achilles ATR SPRORT@RM 497 Incl-GST+A+B+V+Nit.Gas+Rotation (FIVE S STAR PUCHONG)
HANKOOK H452 VENTUS S1 NOBLE2@RM 649 Incl-GST+A+B+V+Nit.Gas+Rotation (FIVE S STAR PUCHONG)
MICHELIN PS2@RM 1485 Incl-GST+A+B+V+Nit.Gas+Rotation (FIVE S STAR PUCHONG)
MICHELIN PS3@RM 1097 Incl-GST+A+B+V+Nit.Gas+Rotation (FIVE S STAR PUCHONG)
275/40R18
Achilles ATR SPRORT 2@RM 481 Incl-GST+A+B+V+Nit.Gas+Rotation (FIVE S STAR PUCHONG)
275/60R18
MICHELIN LATITUDE TOUR HP@RM 1114 Incl-GST+A+B+V+Nit.Gas+Rotation (FIVE S STAR PUCHONG)
285/30R18
MICHELIN PS2@RM 1780 Incl-GST+A+B+V+Nit.Gas+Rotation (FIVE S STAR PUCHONG)
285/35R18
HANKOOK H452 VENTUS S1 NOBLE2@RM 718 Incl-GST+A+B+V+Nit.Gas+Rotation (FIVE S STAR PUCHONG)
MICHELIN PSS@RM 1568 Incl-GST+A+B+V+Nit.Gas+Rotation (FIVE S STAR PUCHONG)
285/60R18
MICHELIN LATITUDE TOUR HP@RM 1181 Incl-GST+A+B+V+Nit.Gas+Rotation (FIVE S STAR PUCHONG)
295/30R18
MICHELIN PS2@RM 1900 Incl-GST+A+B+V+Nit.Gas+Rotation (FIVE S STAR PUCHONG)
305/30R18
Achilles ATR SPRORT 2@RM 667 Incl-GST+A+B+V+Nit.Gas+Rotation (FIVE S STAR PUCHONG)
215/35R19
Achilles ATR SPRORT 2@RM 409 Incl-GST+A+B+V+Nit.Gas+Rotation (FIVE S STAR PUCHONG)
225/35R19
Achilles ATR SPRORT@RM 433 Incl-GST+A+B+V+Nit.Gas+Rotation (FIVE S STAR PUCHONG)
MICHELIN PSS@RM 1408 Incl-GST+A+B+V+Nit.Gas+Rotation (FIVE S STAR PUCHONG)
225/40R19
Achilles ATR SPRORT@RM 406 Incl-GST+A+B+V+Nit.Gas+Rotation (FIVE S STAR PUCHONG)
MICHELIN PSS@RM 1146 Incl-GST+A+B+V+Nit.Gas+Rotation (FIVE S STAR PUCHONG)
225/45R19
Achilles ATR SPRORT 2@RM 463 Incl-GST+A+B+V+Nit.Gas+Rotation (FIVE S STAR PUCHONG)
235/35R19
Achilles ATR SPRORT@RM 438 Incl-GST+A+B+V+Nit.Gas+Rotation (FIVE S STAR PUCHONG)
Achilles ATR SPRORT 2@RM 451 Incl-GST+A+B+V+Nit.Gas+Rotation (FIVE S STAR PUCHONG)
MICHELIN PS CUP+@ RM 1587 Incl-GST+A+B+V+Nit.Gas+Rotation (FIVE S STAR PUCHONG)
MICHELIN PS CUP 2@RM 1562 Incl-GST+A+B+V+Nit.Gas+Rotation (FIVE S STAR PUCHONG)
MICHELIN PS2@RM 1402 Incl-GST+A+B+V+Nit.Gas+Rotation (FIVE S STAR PUCHONG)
MICHELIN PSS@RM 1416 Incl-GST+A+B+V+Nit.Gas+Rotation (FIVE S STAR PUCHONG)
235/40R19
MICHELIN PS CUP 2@RM 1599 Incl-GST+A+B+V+Nit.Gas+Rotation (FIVE S STAR PUCHONG)
MICHELIN PSS@RM 1242 Incl-GST+A+B+V+Nit.Gas+Rotation (FIVE S STAR PUCHONG)
235/55R19
HANKOOK K115 VENTUS PRIME 2@RM 584 Incl-GST+A+B+V+Nit.Gas+Rotation (FIVE S STAR PUCHONG)
MICHELIN LATITUDE TOUR HP@RM 1304 Incl-GST+A+B+V+Nit.Gas+Rotation (FIVE S STAR PUCHONG)
245/35R19
Achilles ATR Sport-RM430 Weng Heng Bukit Kemuning (Feb-16)
Achilles ATR Sport-RM534.24 (GST+V+B+A incl) mytayar.com@Klang Valley (Feb 16)
Achilles ATR SPRORT@RM 499 Incl-GST+A+B+V+Nit.Gas+Rotation (FIVE S STAR PUCHONG)
Achilles ATR SPRORT 2@RM 526 Incl-GST+A+B+V+Nit.Gas+Rotation (FIVE S STAR PUCHONG)
MICHELIN PS CUP 2@RM 1626 Incl-GST+A+B+V+Nit.Gas+Rotation (FIVE S STAR PUCHONG)
MICHELIN PSS@RM 1418 Incl-GST+A+B+V+Nit.Gas+Rotation (FIVE S STAR PUCHONG)
245/40R19
Achilles ATR SPRORT@RM 508 Incl-GST+A+B+V+Nit.Gas+Rotation (FIVE S STAR PUCHONG)
Achilles ATR SPRORT 2@RM 524 Incl-GST+A+B+V+Nit.Gas+Rotation (FIVE S STAR PUCHONG)
Michelin Pilot Sport 3-RM1130 (GST+V+B+A incl) mytayar.com@Klang Valley (Feb 16)
Michelin Pilot Sport 3-RM950 weng Heng Bukit Kemuning (Feb 16)
MICHELIN PS3@RM 1065 Incl-GST+A+B+V+Nit.Gas+Rotation (FIVE S STAR PUCHONG)
MICHELIN PSS@RM 1210 Incl-GST+A+B+V+Nit.Gas+Rotation (FIVE S STAR PUCHONG)
Nexen N8000-RM595 Weng Heng Bukit Kemuning (May-15)
245/45R19
MICHELIN PRIMACY 3ST@RM 1323 Incl-GST+A+B+V+Nit.Gas+Rotation (FIVE S STAR PUCHONG)
MICHELIN PRIMACY 3ST@RM 875 Incl-GST+A+B+V+Nit.Gas+Rotation (FIVE S STAR PUCHONG)
255/35R19
MICHELIN PS CUP 2@RM 1647 Incl-GST+A+B+V+Nit.Gas+Rotation (FIVE S STAR PUCHONG)
MICHELIN PSS@RM 1554 Incl-GST+A+B+V+Nit.Gas+Rotation (FIVE S STAR PUCHONG)
255/40R19
MICHELIN PSS@RM 1567 Incl-GST+A+B+V+Nit.Gas+Rotation (FIVE S STAR PUCHONG)
255/45R19
MICHELIN PSS@RM 1580 Incl-GST+A+B+V+Nit.Gas+Rotation (FIVE S STAR PUCHONG)
255/50R19
Achilles Desert Hawk H/T@RM 515 Incl-GST+A+B+V+Nit.Gas+Rotation (FIVE S STAR PUCHONG)
Achilles Desert Hawk UHP@RM 516 Incl-GST+A+B+V+Nit.Gas+Rotation (FIVE S STAR PUCHONG)
MICHELIN LATITUDE SPORT 3@RM 1511 Incl-GST+A+B+V+Nit.Gas+Rotation (FIVE S STAR PUCHONG)
255/55R19
MICHELIN LATITUDE TOUR HP@RM 1256 Incl-GST+A+B+V+Nit.Gas+Rotation (FIVE S STAR PUCHONG)
265/30R19
Achilles ATR SPRORT@RM 539 Incl-GST+A+B+V+Nit.Gas+Rotation (FIVE S STAR PUCHONG)
Achilles ATR SPRORT 2@RM 549 Incl-GST+A+B+V+Nit.Gas+Rotation (FIVE S STAR PUCHONG)
Nexen N8000-RM565 Weng Heng Bukit Kemuning (May-15)
265/35R19
MICHELIN PS CUP 2@RM 1663 Incl-GST+A+B+V+Nit.Gas+Rotation (FIVE S STAR PUCHONG)
MICHELIN PSS@RM 1647 Incl-GST+A+B+V+Nit.Gas+Rotation (FIVE S STAR PUCHONG)
265/50R19
MICHELIN LATITUDE SPORT 3@RM 1624 Incl-GST+A+B+V+Nit.Gas+Rotation (FIVE S STAR PUCHONG)
275/30R19
Achilles ATR SPRORT@RM 554 Incl-GST+A+B+V+Nit.Gas+Rotation (FIVE S STAR PUCHONG)
Achilles ATR SPRORT 2@RM 572 Incl-GST+A+B+V+Nit.Gas+Rotation (FIVE S STAR PUCHONG)
MICHELIN PSS@RM 1641 Incl-GST+A+B+V+Nit.Gas+Rotation (FIVE S STAR PUCHONG)
Nexen N8000-RM585 Weng Heng Bukit Kemuning (May-15)
275/35R19
Achilles ATR SPRORT 2@RM 581 Incl-GST+A+B+V+Nit.Gas+Rotation (FIVE S STAR PUCHONG)
MICHELIN PS CUP 2@RM 1716 Incl-GST+A+B+V+Nit.Gas+Rotation (FIVE S STAR PUCHONG)
MICHELIN PSS@RM 1803 Incl-GST+A+B+V+Nit.Gas+Rotation (FIVE S STAR PUCHONG)
275/40R19
MICHELIN PRIMACY 3ST@RM 1359 Incl-GST+A+B+V+Nit.Gas+Rotation (FIVE S STAR PUCHONG)
275/45R19
Achilles Desert Hawk UHP@RM 719 Incl-GST+A+B+V+Nit.Gas+Rotation (FIVE S STAR PUCHONG)
MICHELIN LATITUDE SPORT 3@RM 1614 Incl-GST+A+B+V+Nit.Gas+Rotation (FIVE S STAR PUCHONG)
MICHELIN LATITUDE TOUR HP@RM 1581 Incl-GST+A+B+V+Nit.Gas+Rotation (FIVE S STAR PUCHONG)
285/35R19
MICHELIN PS CUP 2@RM 1728 Incl-GST+A+B+V+Nit.Gas+Rotation (FIVE S STAR PUCHONG)
MICHELIN PSS@RM 1832 Incl-GST+A+B+V+Nit.Gas+Rotation (FIVE S STAR PUCHONG)
285/40R19
MICHELIN PSS@RM 1592 Incl-GST+A+B+V+Nit.Gas+Rotation (FIVE S STAR PUCHONG)
285/45R19
MICHELIN LATITUDE SPORT 3@RM 1618 Incl-GST+A+B+V+Nit.Gas+Rotation (FIVE S STAR PUCHONG)
295/30R19
MICHELIN PS2@RM 1958 Incl-GST+A+B+V+Nit.Gas+Rotation (FIVE S STAR PUCHONG)
MICHELIN PSS@RM 1754 Incl-GST+A+B+V+Nit.Gas+Rotation (FIVE S STAR PUCHONG)
305/30R19
MICHELIN PS CUP 2@RM 2075 Incl-GST+A+B+V+Nit.Gas+Rotation (FIVE S STAR PUCHONG)
MICHELIN PS2@RM 2038 Incl-GST+A+B+V+Nit.Gas+Rotation (FIVE S STAR PUCHONG)
325/30R19
MICHELIN PS CUP 2@RM 2086 Incl-GST+A+B+V+Nit.Gas+Rotation (FIVE S STAR PUCHONG)
225/30R20
Achilles ATR SPRORT@RM 496 Incl-GST+A+B+V+Nit.Gas+Rotation (FIVE S STAR PUCHONG)
225/35R20
Achilles ATR SPRORT@RM 519 Incl-GST+A+B+V+Nit.Gas+Rotation (FIVE S STAR PUCHONG)
Achilles ATR SPRORT 2@RM 534 Incl-GST+A+B+V+Nit.Gas+Rotation (FIVE S STAR PUCHONG)
235/30R20
Achilles ATR SPRORT@RM 557 Incl-GST+A+B+V+Nit.Gas+Rotation (FIVE S STAR PUCHONG)
235/35R20
MICHELIN PSS@RM 1486 Incl-GST+A+B+V+Nit.Gas+Rotation (FIVE S STAR PUCHONG)
245/30R20
Achilles ATR SPRORT@RM 568 Incl-GST+A+B+V+Nit.Gas+Rotation (FIVE S STAR PUCHONG)
Achilles ATR SPRORT 2@RM 584 Incl-GST+A+B+V+Nit.Gas+Rotation (FIVE S STAR PUCHONG)
245/35R20
Achilles ATR SPRORT@RM 638 Incl-GST+A+B+V+Nit.Gas+Rotation (FIVE S STAR PUCHONG)
Achilles ATR SPRORT 2@RM 659 Incl-GST+A+B+V+Nit.Gas+Rotation (FIVE S STAR PUCHONG)
MICHELIN PS CUP 2@RM 1695 Incl-GST+A+B+V+Nit.Gas+Rotation (FIVE S STAR PUCHONG)
Nexen N8000-RM610 Weng Heng Bukit Kemuning (May-15)
245/40R20
Achilles Desert Hawk UHP@RM 652 Incl-GST+A+B+V+Nit.Gas+Rotation (FIVE S STAR PUCHONG)
MICHELIN PILOT PRIMACY@RM 1772 Incl-GST+A+B+V+Nit.Gas+Rotation (FIVE S STAR PUCHONG)
245/45R20
Achilles Desert Hawk UHP@RM 655 Incl-GST+A+B+V+Nit.Gas+Rotation (FIVE S STAR PUCHONG)
MICHELIN LATITUDE SPORT@RM 1656 Incl-GST+A+B+V+Nit.Gas+Rotation (FIVE S STAR PUCHONG)
255/30R20
Achilles ATR SPRORT 2@RM 660 Incl-GST+A+B+V+Nit.Gas+Rotation (FIVE S STAR PUCHONG)
255/35R20
Achilles ATR SPRORT@RM 643 Incl-GST+A+B+V+Nit.Gas+Rotation (FIVE S STAR PUCHONG)
Nexen N8000-RM725 Weng Heng Bukit Kemuning (May-15)
255/40R20
MICHELIN PSS@RM 1618 Incl-GST+A+B+V+Nit.Gas+Rotation (FIVE S STAR PUCHONG)
255/45R20
Achilles Desert Hawk UHP@RM 631 Incl-GST+A+B+V+Nit.Gas+Rotation (FIVE S STAR PUCHONG)
255/50R20
MICHELIN LATITUDE TOUR HP@RM 1676 Incl-GST+A+B+V+Nit.Gas+Rotation (FIVE S STAR PUCHONG)
265/35R20
MICHELIN PS CUP 2@RM 1703 Incl-GST+A+B+V+Nit.Gas+Rotation (FIVE S STAR PUCHONG)
265/45R20
MICHELIN LATITUDE SPORT 3@RM 1679 Incl-GST+A+B+V+Nit.Gas+Rotation (FIVE S STAR PUCHONG)
265/50R20
Achilles Desert Hawk UHP@RM 743 Incl-GST+A+B+V+Nit.Gas+Rotation (FIVE S STAR PUCHONG)
275/30R20
Achilles ATR SPRORT@RM 653 Incl-GST+A+B+V+Nit.Gas+Rotation (FIVE S STAR PUCHONG)
Achilles ATR SPRORT 2@RM 673 Incl-GST+A+B+V+Nit.Gas+Rotation (FIVE S STAR PUCHONG)
275/40R20
Achilles Desert Hawk UHP@RM 810 Incl-GST+A+B+V+Nit.Gas+Rotation (FIVE S STAR PUCHONG)
MICHELIN LATITUDE TOUR HP@RM 1859 Incl-GST+A+B+V+Nit.Gas+Rotation (FIVE S STAR PUCHONG)
275/45R20
Achilles Desert Hawk UHP@RM 799 Incl-GST+A+B+V+Nit.Gas+Rotation (FIVE S STAR PUCHONG)
MICHELIN LATITUDE SPORT@RM 1888 Incl-GST+A+B+V+Nit.Gas+Rotation (FIVE S STAR PUCHONG)
MICHELIN PS2@RM 1655 Incl-GST+A+B+V+Nit.Gas+Rotation (FIVE S STAR PUCHONG)
275/55R20
Achilles Desert Hawk UHP@RM 821 Incl-GST+A+B+V+Nit.Gas+Rotation (FIVE S STAR PUCHONG)
285/25R20
MICHELIN PSS@RM 1953 Incl-GST+A+B+V+Nit.Gas+Rotation (FIVE S STAR PUCHONG)
285/50R20
Achilles Desert Hawk UHP@RM 837 Incl-GST+A+B+V+Nit.Gas+Rotation (FIVE S STAR PUCHONG)
295/25R20
MICHELIN PSS@RM 2192 Incl-GST+A+B+V+Nit.Gas+Rotation (FIVE S STAR PUCHONG)
295/30R20
MICHELIN PS CUP 2@RM 2107 Incl-GST+A+B+V+Nit.Gas+Rotation (FIVE S STAR PUCHONG)
MICHELIN PSS@RM 2019 Incl-GST+A+B+V+Nit.Gas+Rotation (FIVE S STAR PUCHONG)
295/35R20
MICHELIN PSS@RM 2113 Incl-GST+A+B+V+Nit.Gas+Rotation (FIVE S STAR PUCHONG)
295/40R20
MICHELIN LATITUDE SPORT 3@RM 2090 Incl-GST+A+B+V+Nit.Gas+Rotation (FIVE S STAR PUCHONG)
305/30R20
MICHELIN PS CUP 2@RM 2146 Incl-GST+A+B+V+Nit.Gas+Rotation (FIVE S STAR PUCHONG)
315/35R20
Achilles Desert Hawk UHP@RM 931 Incl-GST+A+B+V+Nit.Gas+Rotation (FIVE S STAR PUCHONG)
MICHELIN LATITUDE SPORT 3@RM 1852 Incl-GST+A+B+V+Nit.Gas+Rotation (FIVE S STAR PUCHONG)
325/25R20
MICHELIN PSS@RM 2217 Incl-GST+A+B+V+Nit.Gas+Rotation (FIVE S STAR PUCHONG)
325/30R20
MICHELIN PS CUP 2@RM 2161 Incl-GST+A+B+V+Nit.Gas+Rotation (FIVE S STAR PUCHONG)
245/30R21
Achilles ATR SPRORT 2@RM 776 Incl-GST+A+B+V+Nit.Gas+Rotation (FIVE S STAR PUCHONG)
245/35R21
Achilles ATR SPRORT 2@RM 759 Incl-GST+A+B+V+Nit.Gas+Rotation (FIVE S STAR PUCHONG)
265/40R21
MICHELIN LATITUDE SPORT 3@RM 2153 Incl-GST+A+B+V+Nit.Gas+Rotation (FIVE S STAR PUCHONG)
295/35R21
Achilles ATR SPRORT 2@RM 877 Incl-GST+A+B+V+Nit.Gas+Rotation (FIVE S STAR PUCHONG)
MICHELIN LATITUDE SPORT 3@RM 2176 Incl-GST+A+B+V+Nit.Gas+Rotation (FIVE S STAR PUCHONG)
325/30R21
MICHELIN PS CUP 2@RM 2240 Incl-GST+A+B+V+Nit.Gas+Rotation (FIVE S STAR PUCHONG)
245/30R22
Achilles ATR SPRORT 2@RM 817 Incl-GST+A+B+V+Nit.Gas+Rotation (FIVE S STAR PUCHONG)
Achilles Desert Hawk UHP@RM 818 Incl-GST+A+B+V+Nit.Gas+Rotation (FIVE S STAR PUCHONG)
265/35R22
Achilles Desert Hawk UHP@RM 853 Incl-GST+A+B+V+Nit.Gas+Rotation (FIVE S STAR PUCHONG)
285/35R22
Achilles Desert Hawk UHP@RM 892 Incl-GST+A+B+V+Nit.Gas+Rotation (FIVE S STAR PUCHONG)
285/40R22
Achilles Desert Hawk UHP@RM 911 Incl-GST+A+B+V+Nit.Gas+Rotation (FIVE S STAR PUCHONG)
285/45R22
Achilles Desert Hawk UHP@RM 916 Incl-GST+A+B+V+Nit.Gas+Rotation (FIVE S STAR PUCHONG)
305/40R22
Achilles Desert Hawk UHP@RM 1257 Incl-GST+A+B+V+Nit.Gas+Rotation (FIVE S STAR PUCHONG)
305/45R22
Achilles Desert Hawk UHP@RM 1248 Incl-GST+A+B+V+Nit.Gas+Rotation (FIVE S STAR PUCHONG)
305/35R24
Achilles Desert Hawk UHP@RM 1308 Incl-GST+A+B+V+Nit.Gas+Rotation (FIVE S STAR PUCHONG)
cschin83
Feb 5, 2013
25
16
503
Tyre Dealer Contacts
Puchong
Five S Star Service Centre
Lot 14257,
(Shell Bandar Kinrara 2),
Jalan 4, Bandar Kinrara,
47100 Puchong,
Selangor.
Tel : +603 - 8070 0602
Fax : +603 - 8070 0602
H/P : +6016 - 206 8880
Email : [email protected]
GPS Code: N03.049749' E101.640728
Business Hours
Tue - Sat (8:30a.m to 7:00p.m)
Sun (9:00a.m to 6:00p.m)
AutoBenz Tyre & Battery Car Care Centre (002476738-U)
Company Address:
No. 1, Kompleks Letak Kereta,
Persiaran Puteri 1,
Bandar Puteri Puchong,
47100 Puchong,
Selangor.
Tel : +603 - 5879 9630
Fax : +603 - 5879 9630
Business Hours
Mon - Sat (9:00a.m to 7:00p.m)
Sun (9:00a.m to 4:00p.m)
Sunway/USJ
3S Auto Car Care Sdn Bhd (1068148-T)
GST No. : 000964706304
Company Address:
29-1 & 29-2,
Jalan USJ 9/5M,
USJ 9, 47620 Subang,
Selangor.
Tel : +603 - 8081 7850
Fax : +603 - 8021 7850
Business Hours
Mon - Sat (8:30a.m to 7:00p.m)
Sun (9a.m to 6p.m)
iTyre Autocare Sdn. Bhd.
Company Address:
16, Jalan PJS 7/13,
Bandar Sunway,
46150 Petaling Jaya,
Selangor.
Tel : +603 - 5633 3290
Fax : +603 - 5633 3290
H/P : +6012 - 508 5835
Business Hours
Hup Shun Tyres Auto Car Care Sdn. Bhd.
11, Jln. PJS11/7, Bandar Sunway
46150 Petaling Jaya
Tel: 03-5632 9926 , 5637 2275
Mps Auto Sdn Bhd
No 1, Jln PJS 7/17, Bandar Sunway,
46150 PJ, Selangor Darul Ehsan.
Tel : 03 56340939, 03 56340749
Quick-Save Auto Boutique
No.2, USJ7/3A, Subang Jaya
47610 Selangor
Tel: 03 5636 0917 Mobile:012 2020817 (Leon)
Business Hour:
Mon - Sat 8.30am - 7.00pm
Tek Ming Auto Service Sdn Bhd
No.1& 3 Jalan PJS11/24,
Bandar Sunway Industrial Park,
46150 Subang Jaya,
Consistence Distinction
No 1 Jalan PJS1/21A
Taman Petaling Utama
46150, PJ
77842836/77831075
HP 019-3897433
Weng Tat Tyre Service
No. 12, Jalan SS14/ 2, Subang Jaya
47500 Selangor, Malaysia
Tel: 03-5634 7753
Five S Star Service Centre (002465379-K)
Lot 1350 & 1351,
(Shell Taman University),
Jalan SS 3/29,
47300 Petaling Jaya,
Selangor.
Tel : +603 - 7865 0559
Fax : +603 - 7865 0559
GPS Code: N03.094556' E101.611239
Business Hours
3S Specialists Autocare Sdn Bhd (1019597-W)
GST No. : 000576610304
Block K-G-1,
Jalan PJU 1A/20C,
Dataran Ara Damansara,
47301 Petaling Jaya,
Selangor.
Tel : +603 - 7840 0208
Fax : +603 - 7843 0208
GPS Code: N03.119305' E101.579021
Business Hours
Sun (9a.m to 6p.m)
Hup Soon
No:6, Jalan SS3/5, Taman University
47300 Petaling Jaya
Tel: 03-7877 3473, 7876 2973
Chuan Ann Auto (Sunwaymas) near Bandar Utama and Aman Suria
No 1 Block P,
Sunwaymas Commercial Centre,
Jalan PJU 1/3G,
47301 PJ.
78030168
Klang
Ban Hooi Tayar Sdn Bhd
2057-2061, Batu 1, Jalan Kapar, Klang
41400 Selangor, Malaysia
Tel: 03-3342 3146
Eng Cheep Tyres
Batu 11, Jalan Kapar
Kapar, Klang
Selangor
Owner Mr Ti
HP: +60192142718
Jooi Seng Car Care Services Sdn Bhd
198, Lorong Sentosa 45, Off Jalan Batu Belah,
41050 Klang, Selangor
Tel: 03-3348 7499
Pusat Perkhidmatan Tayar Hock Li
132, Jalan Kapar, Klang
Tel: 03-3348 8539
Perkhidmatan Tayar Chin Heng Sdn Bhd
508, Batu 2 1/2, Jalan Kapar, Klang
Tel: 03-3341 2633
Hin Leong Tyre Services a.k.a. Kedai Papan
134& 136, Jalan Kapar
41400 Klang, Selangor
Tel: 03-3343 9100
Shah Alam
Subang 2 Car Care Sdn Bhd
No.2, Jalan Apollo U5/191,
Sek.1, Bandar Pinggiran Subang 2,
40150 Shah Alam, Selangor
Tel: 03-7847 1307
Fax: 03-7847 3423
Pusat Tayar Klang
No. 13 Jalan Stering 34/6, Bukit Kemuning Industrial Park,
Seksyen 34, Shah Alam 42450, Selangor.
Tel: 603-58910295 / Fax: 603-58910295.
CSChin : Thanks man.
VR2 : no la. just wanting to know. And dammit. If I had waited a bit longer I could have gotten the V12 for 230+ only.
Hi All,
Just want to hear some opinion from you all out there about my problem..
Need to check where my ApexI water temp stand at 82 degree at under the hot sun and can reach till 95 degree when car is stand still but did not feel the engine bay is hot.
Another thing is when set the aircond temp to the coolest, the temp seem to drop to around 70 to 75 degree during lunch time but will go back up very fast when the car move.
Radiator, fan others no problem since just check..
Is...
