Temperature rise after changing fan motor.
kher
1,533
Klang, Selangor
Water temperature rise after changing fan motor.
2 days ago mechanic said 1 of the fan spoil so change fan motor. Then after tat whenever aircon on during traffic jam or car not moving temperature rise more than normal...
B4 changing also diden experience this....Duno got spoil or not also actually... My mum duno got kena con by him or not....
Then when he check both fans r moving now...
Izit fan motor not strong enuff or not compatible???
acbc
4,615
8
KD
Maybe the fella wired the fans 'terbalik'? Some mech damn stupid one... maybe colour blind...
kher
1,533
Klang, Selangor
Tis 1 check alr.
N Yes.....he's blind...yesterday he change back to correct wires...Then juz now go subang jam i notice it rises again...
The 1st time is worst....In the middle of a hot traffic jam in KL i kena this...
N when car not moving air cond not cold 1...
mohdmohd
22
radiator clodged....or ur radiator fan oso not strong liao...
new or used? get biger one la
flush radiator....
or u wan simnple..take out ur thermostat
kher
1,533
Klang, Selangor
Radiator jus changed few months back la..
bigger 1??? dun need la.... NA car oni...
but when i off aircond everything will go back normal...
mohdmohd
22
ur radiator inside clean o not oh?
ur FAN is new or used? wat ur mech said?
TypicalGuy
1,111
u changed the fan motor but ur symptom looks like ur fan gonna kong.
is it new motor?
probably ur air cond fan gonna kong also.
ask ur mech to make both fan spin when u start the car lar...
take out the thermostat also...
ehaab
964
Malaysia
hey man..i have the same prob sometimes only..when the car is left parked in the sun for a longtime.
..well i also had to change the motor for the fan...well its working ok now...
have u checked the coolant reservoir...sometimes it just evaporates in my car...then i realised that it was not closed properly.
..well i have no idea other than this why galants show high temperatures...maybe it is the temp sensor...
kher
1,533
Klang, Selangor
Hmm....Looks like motor faulty. Chop shop stuff.
Tmr i check the coolant resevoir also.....
Thanks for everyone's suggestions...
TypicalGuy
1,111
how much u bought the old stuff?
new one rm 150 with labour can last few years....
old stuff cant last long wan lar...
get a new one lar..
denso
bobkidi
214
bro, this 1 might be a cause also
check the direction of air, if u have two fan make sure both also sucking same direction, if i'm not mistaken it should sucking from outside to inside, (hold a light cotton infront of fan and see which side it swing)
its happen to me also, the motor fan i replace is wrong side, it suppose right replace with right but then the chopshop fellow give me the left side, so 1 fan sucking outside another 1 sucking inside, its cause overheating,
when u see a motor there is no marking left or side, what u do, check your working fan n note from which direction its spinning (clock wise or not) then go to chopshop, make sure its spinning in same manner ...
The Marketplace Top Posts
As per title. Any one knows where to get VOLTRONIC engine oil and gearbox oil at Johor Bahru area ???
Search the net, but no result, no VOLTRONIC website for malaysia too.
Only know the distributor is by Voltronic West Malaysia, same no website too.
Any one have idea ?? Thanks.
