technical question: wierd sound in b16a head.
mrpilot
91
sound come when i start the car after few hours park. especially @ morning. sound stop when the engine oil indicator goes off (about 3-4 seconds). seem like engine oil not fully pumped to all part of engine that need to lubricate. happen since last week.oil change every 3000km. using semisyntetic 15-40 honda lube. help me to solve this prob:joyman:
camshaft
411
10
what kind of sound? is it like nyeett! nyeett! or...kluk! kluk!...usually when turning the ignition key right before start the engine...the engine will make some sound like checking all the sensor 1st...after starting the engine...usually the rpm goes up a bit until the oil is fully lubricate the whole engine...i dont thing there's any problem if the engine check light or engine oil check light show no sign of problem...that is if your sensor are all working...have u send it to foreman for checking?
mrpilot
91
taktaktaktak..that how it sound. b4 this oil indicator will goes off as soon as my engine run. 1 more thing, last week the engine light show up. but go back to normal till now. is it possible to check the error code now? does the ecu still keep the last error code? coz i check it when no CEL warning. it show injector n TPS error. code 7 n 16. my car got no prob when i see foremen. n the prob come when i reach home.
E-Tech
1,115
256
3,183
Johor
Sound from hydrulic lifters (looks like bullet).... it works with oil...
If no/not filled completely oil inside, it will make that noise....
It might need cleaning/servicing/change (16pcs)
This is best case senario.
Worst case- crank bearing "makan" already.
What's you engine set up?
Over rev recently?
If lazy to check all those above...
Try change diff oil first.... go thicker this time....
mrpilot
91
rev limit @ 8000rpm. seldom reach that point. usually max 7000rpm.last time i want to change oil to motul semi. but the shop wrongly pick the motul 10-40 mineral. run with that <1000km only. then switch back to vtec semi oil. so i assume that not the point. is it?? duh.. crank bearing "makan" make me feel dizzy lorh.. bro E-tech, what another simptom when crank bearing kaput??
my setup:
b18c bottom
b16a top.
simota penis
pnp head
h22a injector
chrome tuned ecu.
and........
never tune after:
downgrade to stock b16a cam (previously using aftermarket cam.)
change distributor
ngk R09 plug cable
oilfilter
mdsb3
130
worries about lubrication oil nowaday.
too many clon and no quality at all.
try dismantle ur vtec soleniod 3skru,c inside filter have metalchip or not.
have :thumpdown:metalchip confirm ur bearing out already.:thumpdown:
xtremeleo
3,247
464
3~4secs of tak-tak-tak? i wudnt worry much about it, its a sign of a worn out oil pump / lubrication system. ive had the tak-tak-tak sound problem wit my 4g91 for few months, it was worse den mesin jahit!! the sound doesnt go even when warmed up, hoho.. now dah takde, as i said lubrication issue. the hydraulic lifters tend to do dat after sum years of service, or if not taken care properly. use good oil and they'll be quiet
mrpilot
91
for mitshubishi, i would not worry as this. i also own a 4g93 with mesin jahit sound. but now, 1st time it was from my Vtec. that would be my nightmare...
shah5755
355
31
Pj....kch
bro my car also got taktak sound every morning when start but after a few second will be ok....ask my fren oredi they said normal for vtec engine got knocking sound a bit.....I also use the vtec semi synthetic oil....
mrpilot
91
it never happen to me till this time. b4 this my engine run very quite. only fan sound n ekzos can be hear.
E-Tech
1,115
256
3,183
Johor
Dun use vtec 15/40 oil
Many known to face tis noisy...
Change to 15/50.
I personally use motul 300v.
Try change oil.
Rgds.
Feb 23, 2010
this thing tak tak tak.. sound was happen to me b4,suspect was pivot LMA,change it to type r all of it 8pcs.. setle no more tak tak tak sound.. hepy driving now.. :)
mrpilot
91
LMA changed. checked the selenoid cover/filter. there some metal debris. confirm bearing. car oredy parked for 3 weeks..scare to drive. lol. does the debris flow around block n piston? or just stucked in oil filter n the filter inside that vtec selonoid?? do i need full overhaul or just the change the bearing only??
hello guys...
ok i have searched this forum for BOV topic but sadly no return.so thats y i start this topic
i am using HKS trumpet... but the BOV died on few weeks ago... boost leak make my car damn no power... ok now i want to replace my BOV... the option that i have is greddy type rs, blitz dd, hks ssqz, sard r2d2....
my question to all tailo and sifoo here is... wats the difference between immitation ssqv, greddy rs and so on with their original counter part?? if i use the...
