SuperPro Polyurethane Bushings set for Mitsubishi Triton 2006 onwards
G221
Over 10,000 RPM!
13,344
61
1. Steering Rack & Pinion Mount Bush - Power Steering (5Bush/2Tubes)= RM330
2. Front Control Arm Upper - Inner Bushing (4Bush/4Tubes) - Do not remove original shell as it must be re-use = RM600
3.Front Control Arm Lower - Inner Bushing (4Bush/4Tubes/4Washers) - Remove original shell before fitment = RM650
4. Front Sway Bar Mount Bushing (2Bush) - Measure bar diameter 25.4mm = RM150
5. Rear Leaf Spring Bush (12Bush/2Tubes) - SPF0192Kx1, SPF0187Kx1, SPF1983Kx1 = RM400
012-2047338
Postage RM20
Hi guys,
Need your advise here. My satria 1.3, has a issue with Check Engine light comes on suddenly then the car jerks and i had to pull over. I brought it to local mechanic, change spark plug, spark plug cable. the problem comes back weeks later. After fed up with local mechanic i brought it to Proton centre to check. They service the body throttle, prob came back again..then told me it could be the body throttle, so i chg it. It was good for 2 months then same problem came again.
Then...
