- Dec 12, 2007
- 9
- 0
- 1,501
Hi guys, we are doing some stuff clearance!
Item(s):
Components :
German Maestro CS6508iv
Especially designed for hidden installations behind the cars' original interior faceplates we offer the made in Germany CS 6508 IV without woofer grills and -rings and providing an extra small x-over housing for best ease of installation. Shorten installation time in cars' original mounting areas as well as a reduction of the mounting accessories not needed for hidden installations will reduce expenses, but keep your 100% MegaSphere™ Experience
Technical Data:
Diameter T/W: 1.2" (30 mm) / 6.5" (16 cm)
Power Handling: 50 W RMS / 150 W Max.
Frequency Response: 38 – 28.000 Hz
Impedance: 4 Ω
Crossover Frequency: 4.400 Hz
Sensitivity: 90 dB (1W/1m)
- Tweeters based on exclusive MegaSphere™-Technology with inverted one-piece titanium dome and powerful neodymium magnet system
- Woofers with two-piece plastic chassis, polypropylene cone and edge wound voice coils
- Extra small x-over housing for best ease of installation
- Surface mounting rings, grilles and additional mounting accessories included
Price : RM888 + Installation
Technical Data:
Power Handling: 50 W RMS / 165 W Max.
Frequency Response: 35 – 28.000 Hz
Impedance: 4 Ω
Crossover Frequency: 5.500 Hz
Sensitivity: 87 dB (1W/1m)
- CONCEPT crossovers with new and unique MultiMOUNT system for limitless mounting possibilities. Two-level tweeter output
- Tweeter mounting rings, -consoles and other additional mounting accessories included
Price : RM980 + Installation
Amplifiers :
HPN-270
Product Detail:
RMS power 70W x 2 @ 4 Ohm
RMS power 125W x 2 @ 2 Ohm
RMS power 250W x 1 @ 4 Ohm Mono
Signal-to-noise ratio: 85 dB
Frequency response: 10 Hz - 100 kHz
Total harmonic distortion: 0.05%
Continuously variable 0-18 dB Bass boost
Built-in continuously variable 24 dB per octave crossover
Continuously variable 0-180O phase control
Variable remote bass level control included
Input signal sensitivity: 85 mV - 5 V
Fuse rating: 30 A x 1
Sleek blue design with blue LED light strips
Gold connectors
Dimensions (W x D x H): 6.9" x 11" x 1.9"
Weight: 5.1 lbs.
Price : RM800 + Installation
HPN-480
Product Detail:
Power: 80W x 4 @ 4 Ohm
Power: 120W x 4 @ 2 Ohm
Power: 220W x 2 @ 4 Ohm Mono x 2
Signal-to-noise ratio: 95 dB
Frequency response: 10Hz - 80kHz
Independent Front and Rear 12 dB per octave crossover
Selectable High-pass or Low-pass, variable from 50 - 250Hz
Subsonic filter adjustable from 10 - 45Hz
Selectable 0 or 180° phase control
Input signal sensitivity: 170mV - 8V
Fuse rating: 25A x 2
Sleek design with blue LED light strips
Gold connectors
Dimensions (W x H x D): 13.6” x 6.9” x 1.9”
Weight: 9 lbs
Price : RM950 + Installation
HPN-2120
Product Detail:
Power: 120W x 2 @ 4 Ohm
Power: 220W x 2 @ 2 Ohm
Power: 450W x 1 @ 4 Ohm MONO
Continuously variable 0 - 18 dB BASS boost @ 45Hz
Built-in continuously variable 18 dB per octave crossover
Gold connectors
Weight: 9 lbs
Price : RM1100 + Installation
HPN-1500
Product Detail:
Power: 600W x 1 @ 4 Ohm
Power: 900W x 1 @ 2 Ohm
Power: 1500W x 1 @ 1 Ohm
Frequency response: 10 - 230Hz
Continuously variable 0 - 12 dB BASS boost @ 45Hz
Adjustable from 50 - 250Hz
Subsonic filter adjustable from 15 - 45Hz
Continuously variable 0 - 180° phase control
Input signal sensitivity: 320mV - 7V
Fuse rating: 40A x 3
Gold connectors
Dimensions (W x H x D): 16.625” x 6.9” x 1.9”
Weight: 11 lbs
Price : RM1200 + Installation
Subwoofer :
HPX-12
Product Detail:
- Peak power handling: 700 Watts
- Continuous power handling: 400 Watts
- Dual coil 4 Ohm (2x4 Ohm) impedance
- A.S.V. voice former with four layers E.I. wire and S.P.U.N. L.A.C.E. protection
- 80 oz magnet structure
- Progressive polyester and cotton spider for maximum excursion
- Double stamped steel frame
- Ultra rigid polypropylene cone
- Foam-toughen isolated high current copper lead wire
- Driver diameter: 12-1/2"
- Sensitivity: 82dB SPL
- Frequency response: 35Hz-1.7kHz
- Mounting depth: 6-1/2"
- Optimized for small sealed and ported enclosure
Price : RM600 (without enclosure)
Package includes:
All items are new in box.
Warranty:
- 6 Months of warranty will be given to customer if they choose to install by himself or by other installer.
- 1 year warranty will be given if installation done by our shop.
Dealing method:
- Self collect at our shop.
- For postage, buyer will pay for the postage fee.
Location of seller:
Sound Project & H&S Auto Accessories
No 57, Jalan PJS 11/9,
Bandar Sunway, 46150
Petaling Jaya, Selangor,
Malaysia.
GPS : N 03° 03.995′ E 101° 36.189′
Contact method/details:
Naz - 0125122003
Edzuan - 016-6520546
Reason for sale: Trader
Item(s):
Components :
Technical Data:
Impedance: 4 Ω
Technical Data:
Impedance: 4 Ω
Amplifiers :
HPN-270
Product Detail:
Gold connectors
Weight: 5.1 lbs.
HPN-480
Product Detail:
Gold connectors
Weight: 9 lbs
HPN-2120
Product Detail:
Gold connectors
Weight: 9 lbs
HPN-1500
Product Detail:
Gold connectors
Weight: 11 lbs
Subwoofer :
HPX-12
Product Detail:
Package includes:
Warranty:
Dealing method:
Location of seller:
Malaysia.
Naz - 0125122003
