RACING PARTS (Picture file 1)
________________________________________
ELECTRONIC
1. HKS FCD BOOST CUT FOR MIT (RM 150)
2. HKS FCD BOOST CUT & RPM CUT FOR MIT VR4 EVO 123 (RM 200)
3. HKS SLD SPEED CUT FOR MIT (RM 150)
4. HKS BOOST CONTROLLER (RM 400)
5. HKS PFC. F-CON COMPUTER BOX FOR MIT VR4 4G63 [wiring & map sensor full set] (RM 850)
6. HKS AIR FILTER BOX FOR MIT VR4 4G63 (RM 150)
7. KNIGHT SPORTS FUEL CUT & BOOST CUT FOR MAZDA FC (13B) (RM 150)
8. EVO 123 ENGINE WIRING & AIR FLOW SENSOR 609 & TURBO EXHAUST
SENSOR & THROTTLE BODY SENSOR & INJECTOR 510CC (RM 1100)
9. VR4 RS WIRING & AIR FLOW SENSOR (RM 600)
10. TOYOTA STARLET TURBO EP71 COMPUTER BOX (RM 300)
11.Wira 1.8 DOHC INTERNAL FULL SET wiring (RM 150)
FUEL PUMP
1. SARD RACING FUEL PUMP 280 L USE TO 1 MONTH 90% [NEW] (RM 450)
2. BOSCH RACING FUEL PUMP 044, 280L, 10 BAR (RM 250)
3. NISSAN BIT FUEL PUMP (RM 100)
4. KNECHT RACING FUEL FILTER, GERMANY [NEW] (RM 50)
INJECTOR
1. DENSO INJECTOR EVO & VR4 550cc (RM 350)
RACING CLUTCH & FLYWHEEL
1. CUSCO RACING CLUTCH & PLATE FOR MIT EVO123 & VR4 & 4G93 [NEW] (RM 1400)
2. OS RACING FLYWHEEL FOR MIT VR4 [NEW] (RM 500)
3. CLUTCH FOR MIT MIVEC & PERDANA & 1.8 WIRA japan ( o ) (RM 60)
SARD SILICONE HOSES
1. 6mm, 2 meters [NEW] (RM 60)
2. 6mm, 1.5 meters [NEW] (RM 45)
3. SARD THERMO WRAP 50mm, 10meters [NEW] (RM 300)
SPORTS RIM SUPER LIGHT WEIGHT
1. WEDS SPORT OFF43 15†X 6â€1/2 114,3 HOSE GOOD GOOD CONDITIONS MADE IN JAPAN(RM1800)
EXHAUST
1. APEXI DUNK STAINLESS STEEL FOR NA (RM 450)
2. TRUST JASMA STAINLESS STEEL 3†FOR EVO 90% NEW (RM 350)
3. STAINLESS STEEL 2†FOR NA (RM 200)
4. VR4 EVO123 TURBO OUTLET V DOWN PIPE (RM 80)
5. DASH TURBO TCO5 TURBO ADAPTOR (RM 50)
6. STAINLESS STEEL CENTER MUFFTER 2 ½†(RM100)
7. HKS CENTER MUFFTER 3†FOR EVO 7.8.9 90% NEW (RM300)
SPARK PLUG & CABLE
1. NGK PLUG CABLE FOR WIRA 1.3 or 1.5 (RM 100)
2. VR4 RS PLUG CABLE (Original) (RM 100)
3. NGK PLUG 7EA FOR VR4 (RM 50)
4. SPLIT FIRE TRIPLE PLATINUM PLUG FOR VR4 (RM 80)
5. HKS F40RE PLUG FOR MAZDA FC & FD ROTARY ENGINE (RM 100)
6.WIRA PLUG CABLE 1.3 1.5 (O) (RM50)
7.VR4 PLUG COVER (O) (RM30)
8.VR4 RS IGNITION COIL (RM150)
9.EVO 123 DISTRIBUTOR (RM100)
10.SUPER TOURING DASH TURBO RACING PLUG CABLE (RM50)
SUSPENSION
1. TEIN HA ADJUSTABLE SOFT HARD & PILLOW BALL UPPER MOUNT FOR TOYOTA JZX 100 (F) (RM450)
2. TEIN ADJUSTABLE FOR NISSAN SKYLINE R32 (F) (RM 400)
3. EVO 7 ABSORBER FULL SET (F&R) [Original] (RM 1000)
4. BLITZ V,IS SOFT HARD ABSORBER MAZDA RX7 FC & (R) (RM 250)
5. VR4 PILLOW BOLL UPPER MOUNT (R) (RM 400)
6. JAPAN ADJUSTABLE PILLOW BOLL UPPER MOUNT FOR SUPER TOURING & ISWARA (F) (RM 250)
7. WIRA 1.31.5 SPORTS RACING SPRING (F) (RM 100)
8. EVO 3 (Original) spring (F) (RM 100)
9. FTO (Original) spring (F) (RM 100)
10. VR4 RS LOWER ARM & ANTI ROLL BAR (F) (RM 150)
11. SUPER TOURING RACING LOWER ARM & ANTI ROLL BAR (F) (RM 100)
12. AROSPEED ROOM BAR UNIVERSE [NEW] (RM 150)
13. R1 RACING ANTI ROLL BAR Bush [NEW] (RM 30)
14.GAB SUPER ABSORBER FOR WIRA (R) made in japan (RM200)
15.MITSUBISHI GALANT VR4 CUSCO (F) STRUT BAR (RM120)
BRAKE SYSTEM
1. SUMITOMO BRAKE PADS FOR CIVIC EG (F) [NEW] MADE IN JAPAN (RM100
2. WIRA 1.5 DISC ROTOR & BRAKE PADS & CALIPER & KNUCKLE (F) (RM150)
3. NISSAN SR20 BRAKE PUMP (RM 100)
4.MIT VR4 RS BRAKE HOSE (O) (F) (RM50
5.MIT SUPER TOURING DASH TURBO BRAKE HOSE (O) (F) (RM50)
6.WIRA BRAKE HOSE 1 SET (O) (F&R) (RM100)
7.MIT VR4 RACING BRAKE HOSE (F) (RM100)
8.PROTON ISWARA RACING BRAKE HOSE (F) (RM100)
9. EVO 123 & GSR ABS BRAKE SENSOR 1SET 4PIS (RM150)
10.WIRA 1.8 & SATRIA GTI ABS BRAKE SENSOR 1SET 4PIS (RM150)
11. EVO 123 DISC & BRAKE (R) 1 SET 114.3 HOSE FOR WIRA N SATRIA(RM500)
GEAR BOX & LSD
1. LSD FOR EVO123 VR4 4G93 GSR TURBO (JAPAN OPTION PARTS) (RM 600)
2. EVO123 4G93 [4WD] LONG SHAFT (RM 100)
3. VR4 & 4G93 & EVO DRIVE SHAFT & CENTER BREARING SHAFT (RM 150)
4. VR4 RS GEAR BOX LOCK 2WD GOOD CONDITION (RM 600)
COOLING SYSTEM
1. VR4 RS RADIATOR FOR WIRA & SATRIA (RM 100)
2. RACING OIL COOLER 17 ROW 12†X 11†(RM 200)
3. OIL COOLER 6 ROW 25†x 4†& 2†(RM 100)
4. VR4 RS A/C COOLING COIL (RM 50)
5. VR4 RS A/C COMPRESSOR (RM 100)
6. VR4 RS A/C SWITCH 1SET (RM50)
RACING PART & ACCESSORIES
1 .PERSONAL GEAR KNOB (RM80)
2. VEIL SIDE GEAR KNOB (RM 50)
3. AROSPEED CABON KEYLOCK [NEW] (RM 100)
4.WIRA 1.8 MANUAL METER (RM 350)
5. WIRA SIDE MIRROR [1 SET] (RM 80)
6. WIRA 1.6 1.8 ALTERNATOR (RM 100)
7. VR4 & EVO123 ALTERNATOR 75AMP (RM 100)
8. VR4 RS VIPER MOTOR (RM 50)
9. VR4 RS METER CABLE (RM 30)
10. HOT BIT RACING COIL [MADE IN JAPAN] (RM 100)
11. VR4 RS STEERING SHAFT & COLUMN SWITCH & COVER (RM 100)
12. CUSCO BONNET PIN 1 SET NEW (RM 150)
13. EVO 8 RS2 TITANIUM TURBO (RM 1700)
14. MITSUBISHI GALANT VR4 SPEED METER AND RS SPEED METER (RM100)
15. BATTERY RACING ALUMINIUM BRACKET (RM60)
16. HONDA CIVIC SH3 SH4 CARBURETOR K&N FILTER (RM60)
17.CARBING ALUMINUM OIL CATCH TANK 90% NEW (15mm) (RM280)
18. DAIHATSU MIRA L200 INTERNAL MIRROR FOR KANCIL (RM50)
19. VR4 RS BLOW OFF VALVE & PIPING (O) (RM50)
20. VR4 RS TURBO INTAKE HOSE (O) (RM50)
21. EVO 123 TURBO INTAKE HOSE (O) (RM50)
22. EVO 7 HOLOW CAM (O) (RM1000)
23. DAIHATSU MIRA L200 STEERING (O) (RM120)
SOUND SYSTEM
1. SONY XR7190 [MADE IN JAPAN] (RM 100)
2. ALPHASONIK EQUALIZER (RM 50)
3. MANEX HI POWER STEREO GRAPHIC EQUALIZER 100W+100w(RM100)
4. HONDA CIVIC 2WAY MID RANGE & TWEETER 1SET (O) (RM30)
5. CAR TRAFFIC BIT SOUND SIREN MADE IN USA 5â€-6†90% NEW(RM120)
ORIGINAL LAMP
1. HONDA CIVIC SH4 TURN SIGNAL LAMP (O) (F) (R&L) (RM100)
2. HONDA CIVIC SH4 BUMPER LAMP (O) (F) (R&L) (RM100)
3. HONDA CIVIC SH3&SH4 REAR CENTER FRAME (RM30)
4. HONDA PERLUDE REAR CENTER REVERSE LAMP (O) (RM80)
5.WIRA REAR LID LAMP (R) (R&L) (RM80)
6.WIRA REAR TURN SIGNAL LAMP (O) (R) (R&L) (RM100
7.WIRA REAR NUMBER PLATE FRAME (O) (R) (RM40)
8.CAR SUNROOF COVER UNIVESE 7â€-36†(RM30)
9.CAR WIND GUIDE SUNROOF COVER 6.5â€-38â€(RM50)
WIRA 1.8 DOHC RECARO DOOR TRIM & P. WINDOW SWITCH (RM450)
PRO TORNADO SAVE FUEL & MORE POWER FO WIRA 1.6 & 1.8 (RM50)
ALL ITEM’S CAN SEND BY COURIER WITHIN MALAYSIA
For any INFORMATION, TECHNIQUE SUPPORT or PRICES kindly contact H/P: 016-4514155
ELECTRONIC
FUEL PUMP
INJECTOR
SARD SILICONE HOSES
EXHAUST
SPARK PLUG & CABLE
SUSPENSION
BRAKE SYSTEM
GEAR BOX & LSD
COOLING SYSTEM
SOUND SYSTEM
ORIGINAL LAMP
