Hattech-V does...but not with Spoon Clap, but its with Avantech 6 pots...:_:Anyone use (15x6.5inch +35mm) rims
Regamaster
with Spoon Calipers?
Does he use any spacer?Hattech-V does...but not with Spoon Clap, but its with Avantech 6 pots...:_:
When u say "at least" 38mm offset - does that more than 38mm i.e 15 x 6.5 +40mmat least offset 38
yeah...avantech 6 pot is the bestest....even his rear caliper is 4 pot also....
wow everyone change to spoon caliper, so rich. but i still prefer avantech 6 pot :_:
Better check fitment. U can use a spacer but with Big rims and the slammed look u may get fender rub = solution : New Rims..Err... you bought spoon calipers ?? How much ?
I'm getting one also...but i didn't check the fitment for my RIMS......
So....if mine is 17" x7 offset +43 ok ar ???
Sorry tumpang sikit ar !
Thanks...will check it out once the shipment arrived ~Better check fitment. U can use a spacer but with Big rims and the slammed look u may get fender rub = solution : New Rims..
where did u bought it from? not locally?Thanks...will check it out once the shipment arrived ~
Will do.....IF i can't fit it in ~ :_:well bro if you cant find the rim to fit with your caliper you can always sell it to me.
