Slip light keep blinking ( r34 GTT)
atermizi
123
29
shah alam
hi all,
i have a r34 gtt converted to manual...sometimes on the highway after say 120kmh like that the slip lights start blinking and its seems to be like fuel cut (loss in power0 what's up with that?
Innocente
254
4
TCS going haywire. As far as I know, after conversion, the TCS will not work properly anymore. The TCS/ABS control on autos has different wiring connections compared to the manual. Disable the TCS altogether.
reintel
732
30
3,028
Definitely TCS issue. When the system detects slip it will give signal to TCS to work. check the wirings.
Innocente
254
4
Checking wiring connections would be a good place to start. Auto/Manual ECU wiring are different.
JaHaX
1,859
8
my friend converted from auto to manual earlier. he told me that his traction control does not work anymore. but then again, he does not use the oem compbox anumore
atermizi
123
29
shah alam
yeah probably the TCS...so need to recheck ECU wiring i guess...any workshop recommendation?
JaHaX
1,859
8
bro atermizi ...
another possibility is ur clutch is in bad bad shape
was the tcs light blinking when u are on a sudden accelerating/decelerating? ... then u feel that there is no power say for few seconds and the power start to kick in again after that? ... if yes, ur clutch is slipping
atermizi
123
29
shah alam
ok guys i sending the car to the workshop..shit man the previous conversion was an rb20 gearbox!
wai88
317
248
1,543
seremban
the blinking of slip light mean the tyre are on slip, then the TCS system will work something like spark system down or fuel cut to prevent lost control, can try to check the TCS sensor..
the rb20 gearbox cant match with rb25 la, power will be lost due to rb20 gearbox ratio, better change it.
atermizi
123
29
shah alam
yeah im change it, actually acceleration is up due to closer ratios hehe. bt F/C goes like crazy..120 kmh already 3.5k rpm.
