RB Engine Cylinder Head Oil Drain Kit:
This kit designed to help reduce excessive oil build up in the cylinder head of Nissan RB Twin Cam series engines. This is a common problem experienced on the drag strip and occasionally on the street.
This kit helps drain the oil back to the sump instead of building up in the head where it often ends up being forced out of tappet cover breathers and catch cans.
Price: RM280
(An Fitting sell separately)
Suitable for:
RB20, RB25, RB26, RB30.
Genuine OEM Nissan N1 Water Pump for RB25 & RB26 motors RM1300
-The N1 provides high flow for better cooling during racing and competitions. Should be replaced when possible or during an engine rebuild.
- N1 water pump has anti cavitation plate with 6 larger blades compared to the factory 8 blade.
Genuine Nissan N1 oil pump for RB25/26DETT RM1500
N1 oil pump drives higher oil pressure than conventional OEM oil pump for improved oil flow and higher performance use.
Stock Ready.
Pls contact JACK 012.312.7113.
Price: RM280
Suitable for:
Stock Ready.
