Seeking help on turbo boost
mojo1ne
34
7
Yes sensor issues shd light up cel but who knows.. Better to get it checked
Sent from my SM-N9208 using Tapatalk
kurt_629
872
54
528
johor
If O2 sensor CEL should light up.....:smokin:
CEL stand for check engine light?
Nope, I don't have this problem with the air flow sensor.
If I remove the air flow sensor, I will then have the CEL.
Formally the car already comes with CEL, the previous owner don't use air flow sensor at all..
but he has a SAFC 2 which I already sold it away.
mojo1ne
34
7
Hmm... Is ur airflow sensor compatible? Previous owner changed anything inside?
kurt_629
872
54
528
johor
current using standard evo 3 air flow sensor.
previously, don't have.
he was using safc 2, engine was heavily mod.
tried using my friend's evo 3 air flow sensor, still the same.
He must have done something to the air flow..........:smokin:
DanzEterna
15,910
3,371
www.primeperdanaclub.com
your car had safc right? maybe require proper tuning...
im still around bro.....
your NSK coil pack is suitable for evo3?
He using back evo 3 air flow....previous safc2, so afraid some tuning or adjustment needed.
I thought he contacted you already....:driver:
kurt_629
872
54
528
johor
Nope. . Safc already sold and use the money for other maintenance.
I was told safc don't serve much of a purpose in turbo cars..
kurt_629
872
54
528
johor
you found the problem bro? i think u need to install sfac gua...
kurt,
u should have not sold the safc2 as its very useful
did u manage to solve the issue?
nope..
kinda busy lately..
I was told SAFC2 serve no purpose to the turbo, hence sold it away.
even the time with safc, the problem was already present.
I consulted 4 mechanic on the safc before I sold it away.
anyway, the safc2 is at my friend's place.. haha, I can just return his money.
DanzEterna
15,910
3,371
in that case leave out the safc at the moment, have you check your routing of you boost vacuum hoses?
trying using "tulang ikan" can buy at aquarium shop, use youtube to install, quite simple, just a few meters of silicon hoses & some T plastic adapters.
kurt_629
872
54
528
johor
Yeah.. been there, done that.
Also cannot..
My friend helping me to bring the car to kulai. . See what does the mechanic got to say
hi people,
i have satria 1.3
i have eibach 1.6 spring
what parts do i need to put it all together?
i have a feeling the springs are of different diameter, probably, spring seats/abs, absorber mounting have to change?
i was thinking of kyb abs.....do they have adjustables for stock 1.6 springs?
tia,
140dB
