If O2 sensor CEL should light up.....does evo 3 actually has a 02 sensor? might be this if true..
how do I know if its faulty? via reading?
Why I mention air flow sensor, is because you remove can boost.....hmmmmmm?:hmmmm:hey hey, checked.
with another air flow sensor, also the same.
with air flow.. 0.5
no air flow, 1.0
CEL stand for check engine light?If O2 sensor CEL should light up.....
current using standard evo 3 air flow sensor.Hmm... Is ur airflow sensor compatible? Previous owner changed anything inside?
Sent from my SM-N9208 using Tapatalk
He must have done something to the air flow..........current using standard evo 3 air flow sensor.
previously, don't have.
he was using safc 2, engine was heavily mod.
tried using my friend's evo 3 air flow sensor, still the same.
your car had safc right? maybe require proper tuning...current using standard evo 3 air flow sensor.
He using back evo 3 air flow....previous safc2, so afraid some tuning or adjustment needed.your car had safc right? maybe require proper tuning...
im still around bro.....
your NSK coil pack is suitable for evo3?
Nope. . Safc already sold and use the money for other maintenance.your car had safc right? maybe require proper tuning...
you found the problem bro? i think u need to install sfac gua...
nope..kurt,
u should have not sold the safc2 as its very useful
did u manage to solve the issue?
He wants to de-mod to original status......lolkurt,
yeah.. an issue since day 1, until now, I still can't resolve..That is some tricky issue you got there
Yeah.. been there, done that.in that case leave out the safc at the moment, have you check your routing of you boost vacuum hoses?
trying using "tulang ikan" can buy at aquarium shop, use youtube to install, quite simple, just a few meters of silicon hoses & some T plastic adapters.
cant think of any other solutions for you bro, kinda rusty now....anyways do update once the issue managed to be solved.Yeah.. been there, done that.
Also cannot..
My friend helping me to bring the car to kulai. . See what does the mechanic got to say
