Raising the ride height...
stutzedward
3,416
561
I just let my RX8 buttom up all the time... couldn't care too much. Haha...
dream.tent
976
24
www.cardomain.com
If the spring was old and sagging - then of course these spring rubber buffers would improve handling la! I would never put these in a perfectly good set of springs. What it essentially does is prevent the spring for compressing too much. But since it doesn't cover the whole length of the spring it will allow some of the spring to compress and the rest held in place. Do it long enough it'll deform the spring.
Woah.. that's some hardcore driving to lose spring buffers that are supposed to fit to the shape of your springs! (It has a drain that wraps around your springs supposedly) So either they weren't installed properly or you did a lot of off-road terrain driving which lengthened the springs and dropped the buffers!
And ARB > buffers anyday!
Took the mech hours to fit the rubber on to the springs..the groove needs to be WD40 too! slow and painful installation.
But now, i think better just get new sets of coil and i've bought the original chassis bumper that looks like a block of rubber sit beside the coil to stop the chassis from slamming on to the arms.
My Hyundai springs are old and sagging and I did fit one set in. Only thing I felt is, it absorb some vibration but the springs are still soft and saggy.....:banghead:
It doesn't cover the entire length of the spring so you can't expect it to make it feel like brand new or whatever. It's just a buffer - meaning it'll just stop it probably from bottoming out only la.
My original battery +ve terminal had corroded and teared off, hence, went to some garage in puchong to buy a new after market terminal (looked damn big).
After that I've DIY replaced the terminal. Yesterday on the way back from work, while driving at 70km/h, enverthing in the car (signal light, instrument cluster, radio, etc) all went hair wired and the engine suddenly cut out. Moreover, fire sparks are flying all around on the winscreen....Damn scary !!
Luckily I was at the inner...
