Kerabuperut:
Thanks for your comment & support.
nobodies:
Kelisa, yes I have done 2 Kelisas before. If you read carefully on the earlier replies, look for comments from tks.
General Info:
Quickshifts normally will feel solid and slightly heavy to shift if you are not used to it. Simply because the swing radius of the lower fulcrum is wider. So in order to make the upper section fulcrum swings shorter the bottom part will have to do extra work - so the feel is heavy. Gear engagement remains the same- if it is okay before this it will be okay after modded into Quickshift too. If you love comfort and soft shifting, I do not recommend to use Quickshift, specially those rods type. Factory standard shifter are made to travel longer for comfort.
nobodies:
General Info:
