[Q]Unit measurement of power
kk9972
242
Hi All master here,
I would like to comparewhat what is the different between HP and BHP, bar and PSI.
It makes me confuse some of the time. Does anyone know?
emechelmi
49
HP is general measurement of power. BHP is measured by applying a resistance (brake) to an engine until it ceases to run. 1 HP is equivalent to 746 W in metric system.
bar and PSI are the unit to measure pressure, not power. One is a metric and the other is imperial. 1 bar refers to 100 kN/m2 or 100kPa. PSI (pound per square inch) comes from Imperial unit system.
kk9972
242
Hi emechemil,
Thanks for the explaination.
So, HP is generate measurement being calculated from engine output (watt)? Is it? BHP is the way by deducting the resistances to get the actual power?
Example, 160 BHP is more power compare to 160 HP?
Bar and PSI, pressure measurement. This thing confuses me a lot with the boost meter with offering PSI or Bar reading. So, in this case, if I boosted at 0.7 bar, what is the reading in boost with offers PSi reading?
Thanks for the help in advance.
zan
2,154
yeah, to make things easier and faster - use wiki!
but the quote above is correct though.
HP is measured at engine's crank pully which is the power supplier like a horse.
BHP is measured at the wheel; where the brake is located - hence the acronym of 'brake horse power.'
kk9972
242
Share with you guys
Thanks for you guys reply. I got the ideal now. cool~:shades_smile:
http://www.citroen.co.uk/conversion/c_converter_rates.asp?pagetype=c_converter_rates
Just found this useful unit conversion table from Net. Quite useful for me.
<p><a href="http://www.zerotohundred.com/?attachment_id=53670" rel="attachment wp-att-53670"><img class="alignnone size-medium wp-image-53670" src="http://www.zerotohundred.com/wp-content/uploads/2013/04/MG_0855-600x400.jpg" alt="" width="600" height="400" /></a></p>
<p>We were at Sepang earlier today for a dual launch of the facelifted MY2013 Gallardo LP560-4, as well as to introduce the new Malaysian team, Team FX Primus Aylezo JH Italia, which will be racing for the Lamborghini Blancpain...
