Normality78, normally, the price is around RM 2500.00, depend on the dealer or agent, and off couse, the workmen ship, the tune equitment they use ( at least, A/F Meter, norrow band kah or wide band kah )
Erictoh, for Hoda civic 2004, you better stay with the original ecu due to high tech auto gear management, E-throttle (drive by wire ). You can try on MOTEC 8000, for myself, i thing will be E-......
140db, what system or ecu you are running on, you need 1.5 bar map sensor.
This map sensor is built for on board, 6 pins, yes, is 5volt when max boost. Off couse, you can put it on the small box , almost look like ext. map sensor..By the way, what car you are driving?
