Project Kancil Moderno with EJ1000 TD04L
FzL2sHybrid
83
30
18
41
Well, base on the negative reviews for the AVS Spark Plugs, i manage to changed it with NGK Iridium 4 . Luckily, FCR JB ( shop ) allow me to changed it. Thanks for all of your advice. I just want to play safe.
brokenjars
229
16
Kedah
Well that is good to hear! Ngk and denso spark plugs are proven reliable so i think u made the right choice
FzL2sHybrid
83
30
18
41
Managed to bought this L2S fuel tank. This is internal pump type not like normal kancil tank the pump is external. Just to make sure fuel flow to the regulator and engine always consistent and sufficient.
Wow that is quite a big budget for your project car. How much hp are you aiming at or what kind of performance are you hoping for? Zerotohundred in 5 seconds?
Yes bro, like Piggy ECU is around 1.2k not plus tuning. Engine and gearbox it self already 2800+400. Clutch 800, Turbine 700, banana 1100, and many more..i have the list for all the expenses as for now. Even bolt and nut cost me 180..and so on. 25k is to fully rebuild not only engine, but whole car. Paint cost 2k for inside out Anti Rust and Candy Red. Well, 'jajan' for Mira is not cheap nowadays. Even spoiler moderno limited cost around 700-800. It's ok, i already plan for this project since few years back. It's so called passion. haha.
Target horsepower should be more than 150hp. Standard L2S,L5,6,7&9 are 64hp. I will know it when doing the dyno tuning at RMD Garage, JB soon.
Holy mother jesus batman. 150hp on a Kancil? Dude you'd be cracking sub 5 seconds with that kinda power and that ultralight chassis. Hope you have plans for tyres and brakes too
FzL2sHybrid
83
30
18
41
bro. search in youtube, theres many kancil monster dragster win for open kategory. Even with Vtec turbo, Evos and skyline. Power to weight ratio.
150 hp is a small amount bro, most of the dragster has 200 above and 1 that i saw in JB has 420hp! Please don't underestimate a small car like kancil. Already proven on track.
For brakes i will using All 4 disc brakes from L5. Tyres either Falken or Yokohama. Same as absorber wi be upgrade too.
  • Like
Reactions: ^pomen_GTR^
sanekit
Dec 9, 2015
1,616
157
663
but you're gonna daily that monster. 420hp for sure got very aggressive cams and high boost which gonna be a bitch to drive daily. :driver:
  • Like
Reactions: FzL2sHybrid
I never underestimate small turbo charged cars man. I'm not sure you read me correctly, I was saying 150 is a lot, not mocking the number. 150 on a small lightweight chassis is a lot.
  • Like
FzL2sHybrid
83
30
18
41
Ok i got it. Well, i think 150 is just my target for this kind of setup. We just wait until the dyno run settle. Maybe more and maybe less. Thanks iszo.
leinnz
333
57
3,028
bro izso plan for a writeup on this lil monster?
YellowFlash
308
34
Jb
Nice... Hp sounds about right which is about what your 3 injectors can support at duty cycle below 80%. With 150hp on a 650kg car, its going to be very quick. For comparison sake, the new swift sport turbo is only 140hp on 970kg with a sub 7s 0-100 timing. Will easily cucuk the 2.0L to 2.4L family sedans.
Wonder how much torque will it be pushing and how will the dyno graph look like? with the td04 housing and a 660cc engine, i am guessing turbo will hit full boost upwards of 4k? Will you be doing it on a inertia or load dyno? Interested to look at your dyno chart once done.
dear ZTH members...
What should i do for my v6 6a10 engine to up the power ???? what type of piston should i use if i want to bolt on turbo for my v6 6A10 ???? the original size of my v6 is 73mm... its too small.... any idea to power up my v6 6a10 ???? plzz help me.... urgent !!!! :idea: :itsme:
