Please Help~!!
moobycore
242
Please help me what im goin to do.. i use L200 turbo .. last few days suddenly cant start.. check at coil dont have any power.. so change the coil include distrbtur.. still cannot start.. how to do~?! :sad_smile:
g88
3,082
54
cannot start as in no cranking at all ? If yes check ignition switch (key)
Or meter panel have light when ignition been turn ON ? If yes check starter. Alternative can also get a fella pull out each spark plug cable and u in inside try start the car see go spark between cable to the cylinder head or not.
moobycore
242
Bro~! check out the starter done and battery is new, i mean baru charge.. check spark also done.. is it problem from wiring?! can be or not?!
vantageX
103
moobycore, as Fluffy said, need more details.
1. Does the engine turn (crank over)?
2. Turn on your headlights, are they bright? (sometimes a weak battery can turn an engine over but not be able to start it, I know its new but sometimes you might get a duff battery)
3. If you have spark, the engine is turning. Then is your spark strong? Do you have fuel going in?
If you have a cranking engine, you have spark at the spark plugs and its strong then there's only timing and fuel delivery left for a basic non-starting problem. Let us know.
Fluffy
3,870
>>klang<<
ok.if there's no starter sound at all.ur starter is dead.or bad wiring.
of it struggles to start.ur batt got some prob.cont say for sure coz its ur car..althought its new..anything is possible.
that's wat i can think of.
moobycore
242
Bro~! check at oil filter, sure minyak keluar...
turn on the headlight also bright mah.. before all this shit happen, i pasang RPM meter .. dont what acc. shop do..
vantageX
103
What you mean minyak keluar? You mean you're losing oil thru your oil filter? Have you checked your engine's oil level?
Starting to look like your RPM meter's wiring might be the problem. Good luck!
huakenny
LB Performance
9,126
240
Kota Kinabalu
if after done ur rpm meter n then cannot start...try uninstal ur rpm meter n see can start o not....may 'terbalik' the wire connection...
if ur car can crank but cant start...check fuel pump....see fuel pump in working condition o not...
HELP HKS 60MM Boost Meter Diagram
i'm looking for this wiring diagram .. anyone who has it .. please .. i need your help ..
or maybe knows how to wiring it .. maybe can discuss the payment
