piston with "bowl" shaped head
upontheriversky
275
82
my mech told me about this. upgrade standard kelisa piston to this piston, the head is curved inward like a mangkuk shape so creating more space for extra air and fuel than our curved outward standard piston so every stroke got more power
this way is more economical for small budget engine mod coz no need to rebore, the diameter and size exactly the same. for standard car this mod will be good enough for most daily drivers.
anyone tried this?
Veloc
3,235
991
Sabah
I think what you are referring to are low compression piston. It doesn't suck more air-fuel into the engine. It just lowers the compression. The way to increase the effective displacement of an NA engine is to either bore it out or stroke it out with a stroker kit which usually involves the replacement of the crankshaft.
Those low compression piston are used for forced induction cars when they need to lower their compression ration for safety. If you use in on your normal engine, your power and torque will suffer significantly due to lower compression.
Should get a second opinion from another mech man...
hachiroku clan
633
73
if u need power, it should be the other way around.. compress more air/fuel into a tight space, giving it a bigger force during combustion.. not by giving air/fuel more space, then the combustion force will be lower than your current set up..
C99D-MMC5537
287
78
why ur mech want to decrease your compression ratio? r u plan to install bolt-on turbo on your ride? if not, it will only make ur compression pressure worse/lower than stock which mean less power + more fuel consumption.
7,514
totally agree with all veloc,hachi,c99d
:adore: :biggrin:
upontheriversky
275
82
blacklist that mechanic ! LOL
fortunately you asked around bro.
oh my goodness, luckily i did haha
thanks for the useful info bro, what should i do to get more compression?
D7zul
2,697
848
Shah Alam
get a bolt on turbo/supercharger..
trust me, it will satisfy your hunger for power
:driver:
hachiroku clan
633
73
to get more comp, u can either get a high compression piston or change your head gasket to a thinner one.. or like cherry-tree mechs say "potong head" which is cheaper than changing pistons..
C99D-MMC5537
287
78
what to do to increase compression for N/A? hahhahaa.. i like this topic. first, piston shape, head gasket thickness, and combustion chamber shape is determine your compression ratio (CR). higher CR, but small amount of air/fuel mixture go in, u still got lower compression pressure inside combustion chamber. so, 2nd step is increase your volumetric efficiency (VE). less restricted air-box, bigger throttle body, intake manifold, port n polish and last one is your extractor. all this setting must be ngam to get the best volumetric efficiency (bigger not always better). good tuner must know all this. when u already got best VE and u also have higher CR, then you already have higher compression pressure and your N/A must be more powerful and no more RON95 for u after that. :biggrin:
7,514
u ready to pour every single drop of your money to fill your tank with ron97 petrol only after increase compression???? :biggrin:
if u want to install that "kawah"/"bowl" piston be ready with bolt on turbo kit next on the list.... thats where the real power came from the piston change :biggrin:
i just had my battery relocated to the trunk and i could not be sure whether this had caused me electrical unstablity because im noticing small bouncing rpm when signal light is on during idle, the vacuum meter dims when headlight and signal is switched on
my car is not super audio equipped, only brighter PIAA headlamp, and the meter. i have 2 stabilizers and problem still persists
i just talked to a friend who told me i need to get a grounding wire from alternator all the way to...
