Photos of engine internals
shiroitenshi
3,676
170
Like DIV suggested..
Here's some photos of piston still in block.. give your comments what those stuff on the piston face means.. :biggrin:
nksc
694
Re: Photoes of engine internals
fuh so much carbon...rite?!?!:hmmmm:
bien335
1,819
48
1,648
Johor Bahru
more carbon = lighter
carbon fibre is lighter than normal steel, so the more carbon you have, the more lighter your engine is, more performance.
Correct Shiro?
:p
D-IV
262
Correct Shiro?
:p
You were really asking to go into my signature hahaha... well you just made it :p
D-IV
262
Were you burning oil on this motor? The one that i had in my previous motor had a different texture on the piston compared to this one and i can say my motor was pretty rich that time :bawling:
I lost the one's where i had the close up on the piston. I'll look it up on my other laptop if i can find it.
crazykatak
776
48
Subang Jaya
erm..piston has alot of carbon.juz polish it will do the trick.
the shape on the face helps to create swirl effect during intake stroke
shiroitenshi
3,676
170
actually more carbon, more compression, because it adds to the piston dome cc, and minus the valve pockets volume. :rofl:
As you can see the pitted edges at the sides.. Those were some signs of light detonation/knock.. lol.
That's why the swirl is different from your motor.
Yeah, it was burning oil. Valve 1 leaked pretty badly, but the carbon went to the other areas as well.
Carbon is normal because I connect the PCV valve at the head to the intake. if don't want it to be that bad, then use a catch can.
D-IV
262
Can't see the pitting but i'm sure when you were burning oil, it can cause some detonation. How bout those flaky white stuffs i see on the piston? Are those sand? or are those just light reflections? coz initially i thought some sand or debris went into your motor coz you weren't running a filter on..
added: I envy this motor, the sleeves on the coolant passage are free of rust and damn clean. Look at mine hahaha... how do you clean it from rust anyway? any quick way?
SePaT
1,073
i must say u must be "injecting" hell of fuel ... sure got api-api at the muffler during shifting time :adore:
jeheyr
834
19
5,018
Ampang Jaya
community.webshots.com
fuhhh... PCT?
dcloo
1,784
17
kl
and how about this guys u think about it :rofl:
hattech-v
Over 10,000 RPM!
12,756
12
Seri Kembangan
www.avantech.com.my
its a b20b block with 86mm wiseco block with arp stud. combine with pro 3 will get 250+ atw with race fuel... :biggrin:
can easily tapau k24 inside EK... :rofl:
evoX2
1,167
KCH
how much compression you get from this? 13:1??
dcloo
1,784
17
kl
No EK.. the EG blue colour from johor lol......
D-IV
262
Yes those were PCT's in my old B16a block. It shouldn't be anywhere around 13.1:1, 11-ish sounds more realistic. I didn't have that api api that you mentioned though hahaha... I just intentionally put it on the RICH side to see how it looks like before i start changing to b20b block and then check out the head and then check condition of the rings for knowledge purposes. I was gonna put it to lean but i don't wanna damage my head in the process hehe...
The Marketplace Top Posts
Help pls
HI everyone..
well , i just have a couple of question bout air compression and the magnetic fuel saver .
air compressor
improve power/pick up ?
save fuel ?
magnetic fuel saver
save fuel ?
thx
