Be mindful of what you're going to say, Kagerosan. No racist remarks here, please and thank you.
Hi, i owned a neo cps(m), lightly mod(fuel regulator, cam gear, lighted cam pulley, drop-in k&n, 421 header, EMS1.Fuel pump ? I suggest not. Some cases where people bought Walbro be it genuine or non genuine, have problems such as fuel surging. Due to the nature of the pump not seated properly and moves inside the pump housing.
I suggest you add a piggyback to fine tune your ignition timing and fuel. Rim size is not an issue, if you like it on 16, be it that way :)
Its better to work on a basis of what you have at the moment and not spend unnecessarily.
Suggestions :
- good adjustable cam gears,
- good adjustable fuel pressure regulator,
- maintain OEM plug cables,
- Works Pro Neo / EMS1 piggyback,
- camshaft dialing,
- maintain CPS OEM intake manifold ( yes, the VIM is a good thing bro ); get a good drop in air cleaner,
I'd be happy to assist you in any means.
Can PM me if u have any doubts or questions :)
Cheerio
I suspect its the lighted crank pulley also, i'll try to change it to stock, seen i change to lcp, going uphill also a problem for me.my neo cps used to be A/T but i change to mivec ck manual gearbox..180kmh @ 5.5k rpm..cannot go further? as far as i know, campro dont hv speed limiter. maybe becoz of lightened crank pulley.. it dropped your top speed. or it maybe bcoz of the tuning of your cam pulley. and from my experience too.. try pump v-power racing..this fuel is for high rpm power. when i use v-power..can go till 200kmh only and if using v-power racing can reach 210kmh.
The best mod to increase performance is upgrade your engine displacement, use higher camshaft spec, ported head cylinder, use high compression piston. these mod are expensive.
If your cheaper one.. bore the throttle body.. change spark plug & plug cable...this light mod wont increae your hp as much as heavy mod
Try to work on the cam settings 1st. No point if the settings are incorrect / not precise but you go change the crank pulley..additional time and money spend.Hi, i owned a neo cps(m), lightly mod(fuel regulator, cam gear, lighted cam pulley, drop-in k&n, 421 header, EMS1.
The problem is my car cannot go more than 180kmh. Other gears can go to 6.5-7rpm but when in 5th gear rpm drop to 5.5 when speed is 180kmh. Any other cps experience this?
My question is, does neo cps have speed limiter? Can i remove it? And what is the best next mod to increase performance?
Bro, i tried few difference settings. Not much different on top speed. Which setting works best for u? U dont think it is the lcp that cause this? How about the lack of power going up hill?Try to work on the cam settings 1st. No point if the settings are incorrect / not precise but you go change the crank pulley..additional time and money spend.
Perhaps..
due to the nature of the gearbox, limiting the top speed to just 200-215 kph..
Thank u in advance bro
Aiseyman.. .. Can recommend me any tuner..Oh. no wonder lah..
i tthink may be the lighted cam la.....mine stock cam can go up to 200km....no ems no piggyback...just metal drop in filter, iridium plug, volt stabilizer and cold air intakeHi, i owned a neo cps(m), lightly mod(fuel regulator, cam gear, lighted cam pulley, drop-in k&n, 421 header, EMS1.
Just curious about changing to a bigger size piston or high compression type. Can CPS crankshaft able to hold it?? Any bro tried before? Actually what is the actual size of the original cps piston?? How big can it change to?
