nissan silvia spec-r 450whp
s14sellingnow
326
13
YEAR 02/08
Silvia S15 Spec R 02/08
Engine
Stroke up to 2.1cc
Tomei procams (intake and exhaust)
Tomei rocker arm stopper
Tomei 1.2 metal head gasket
Tomei Type A valve spring
Tomei short shifter
Sard 850cc injector
Sard fuel regulator
CP Piston 87mm
Eagle Conrods
ACL Race bearings
Skyline R34 radiator fan
Tomei exhaust manifold
Garrett GT3037s
Tial 44mm Wastegate
JUN intake manifold
Spitfire coilpacks
SARD fuel surge tank
Greddy intercooler
Greddy oil cooler
Greddy radiator
Greddy type r blow off valve
Aluminum intercooler piping
Samco hoses
Turbotech blanket
Pitworks heatshield
Apex'i N1 exhaust
Z32 airflow
Nismo oil filter relocation kit(steel braided hose)
ORC 409D super single
80mm throttle body
ATi Super Damper
Works aluminum pulleys
Jasma engine Damper
ARC oil sump pan
Billion power steering pump reservoir
Twin Walbro 255 lph fuel pump
Suspension
HardRace engine mount
Uras front suspension arm
URAS transmission mount
Cusco front torsion bar
URAS tension rods
Ultra racing front 29mm sway bar
Ultra racing rear 25mm sway bar
Ultra racing underbody 4 point brace
Ultra racing underbody side rail bracing
Cusco front strut bar
Cusco rear strut bar
Cusco Rear adjustable camber arm
Short-stroke tein HE drift master with swift spring
Hard Race PU sub-frame bushings
Hard Race Differential Support bushing
Hard Race rear toe arm
Hard Race front lower arm
Hard Race front tie rod
Hard Race front caster rod
Hard Race front RCA
Customised rebound and spring rates
Ultraracing lower brace
Nismo GT pro 2 way LSD
4.1 Final drive
Cusco brake stopper
Exterior body
Voltex type 5 wing with custom mount
Pitworks widebody kit 50mm widen each side
Voltex front diffuser
Dmax carbon fiber bonnet
Aerocatch bonnet pin
ganador side mirror
Interior
Genuine Bride Stradia II seats
6 point seat harness
Momo steering wheel
NRG quick release
Kenwood touch screen dvd player
Apex'i turbo timer
Apex'i Power FC and commander
Defi link meters (Oil temp , oil pressure , water temp , boost )
HKS EVC V boost controller
Wheels & Brakes
Rota 18x9.5jj and 18x10jj
Ksport 8pot BBK front
Ksport 4 pot BBK rear
Castrol Racing brake fluid
BFGoodridge stainless steel braided hose
Custom widebody kit made by Pitworks Puchong with proven aerodynamic upgrades
for picture pls click this link
Nissan Silvia S15 sper R(M) - Cars for sale in Damansara, Kuala Lumpur
only minimum loan will be granted to new buyer.
rick 012 4178555
  • Like
Reactions: william1216
Veloc
3,234
991
Sabah
What a super monster :adore:
Proton Gen 2 Front Position Headlight Bulb Replacement
Tool:
1.Multimeter - 1 unit (for testing)
2.Replacement bulb- 1 unit
Duration: 15-20 minute
Procedure
1. Open up the front hood of your car.
2. Reach your hand to the back of the head light.
3. The low beam head light is at the lower part.
4. Twist the bulb socket...
