newbies with satria 1.3 acceleration problem
john_unai
371
80
528
mtkb
when I use gear 3 for my satria 1.3, the car like no power n its acceleration remain constant even when i press the accelerate pedal more. at one stage the car will suddenly speeds up. at 1st, i tot that was because of the clutch plate have worn out.however after i change the clutch plate, the problm stil occur. is it because of gearbox?anyone can pls help.
marvick
13
1,503
MALAYSIA
usually if for efi car common troubleshouting would be cleaning u throttle body, check for u fuel injector if got clog, change u fuel filter, change spark plug, or just check engine setting.
Mine last time got the same lagging respond because clog fuel injector..
Hey guys,
im not sure if i can fit a bi-xenon light to my w212..
and also how mch do they cost??
last question, any1 noe how to change the fog lamp to the led 1's? cause at mercedes benz show room it's a lot expensive
a picture to help out u guys to see if can fit bi-xenon
