Need Some Help
faisal_figo
I have a problem with my car..When i on the air-con,the timing of the car will become very low.I've adjust the timing and now the problem is the opposite where the timing will be very high when i off the air-con..is it because of the car voltage??does fixing volt stabilizer will help??btw,do mounting problem cause this prob??
i need some assistance...thanks in advance.....
depends on wat car u r driving. Carburetor engines actually have 2 screws (1 for when air cond is off and 1 for when air con is on) to adjust the timing whereas for EFI cars, there is only one. For EFI, there is no way to adjust both timings independently coz also ECU controlled.
If ure car is Fuel-Injected ..have a computer box tuning to stablise the timing. Avoid using unbranded air filters ... tat could help u ..
cheers!
A thread every 60 seconds
