Nano Energizer Nano Maxx
boeytan
736
What is NanoEnergizer?
NanoEnergizer uses Nano Technology which is technology at the nanometre scale. NanoEnergizer is made from 20nm(1nm=0.001micron) platinum coated ceramic nano powder and is developed by Korea Institute of Nanotechnology.
NanoEnergizer creates a long lasting protective and effective engine restoration. These results in 5 to 20% fuel consumption saving and 3 to 9 times reduced carbon emissions with more benefits such has significantly enhanced engine performance and up to 5 times lowered noise levels.
What sets NanoEnergizer apart from other engine based lubricants is that we are the only ones using platinum coated nano ceramic compared to the regular oil based lubricants. The ceramic based element gives it an edge compared to regular Metalization products. The platinum in the compound promotes combustion and the ceramic is able to withstand high temperatures (up to 2750 celcius).
It is 20 times stronger than steel and has a higher heat resistance thus giving it a longer life span of up to 30,000 to 50,000km per use. The NanoEnergizer comes in packs of 30ml, which is simply poured into the engine block, allowing science to take its course in enhancing and restoring engines.Due to the constant abrasive motion between the piston and the cylinder walls, the engine block suffers from wear and deterioration. NanoEnergizer is able to protect and restore the engine block to peak condition
In short, by applying Nano Energizer you are giving the engine a ceramic platinum coating. With this coating the efficiency of an Internal Combustion Engine can be increased. Higher efficiency of the engine is reflected in improved performance such as:
  1. Reduced fuel consumption
  2. Increased power output
  3. Reduced noise and vibration
  4. Reduced oil burning
  5. Reduced air pollution.
The ceramic material used for the engine coating needs to have a low thermal conductivity and a high temperature stability, matched with thermal expansion which then bonds with the metal of the engine.
Nano Energizer forms a durable bond with engine's metal adding a high wear resistance and also corrosion resistance.
Benefits of using Nano Energizer:
  1. A Smoother, Quieter Engine with more Power & Better Economy
  2. Fuel savings up to 8-21% (up to 40% in idle mode)
  3. 5 times lowered noise and vibration levels
  4. Restores friction surfaces and protects against wear
  5. Lasts up to 50,000 kms and can be repeated time after time
  6. Increase Equipment/Engine Life.
  7. Protects & Restore Critical Mechanical Parts
  8. 100 times reduction of the friction coefficient
  9. Increased oil pressure & greater combustibility
  10. Brings engine power up to 100%
  11. 3-9 times reduction in CO and CH in the exhaust.
  12. Safe for the environment.
  13. 100% Performance Guaranteed!
Price: RM80/sachet
What is NanoMaxx?
NanoMaxx is a Revolutionary & Patented nano based natural mineral that acts as a coolant radiator additives which generates far infrared(FIR) electromagnetism. This FIR electromagnetism helps to break or atomize large fuel molecules into single fuel molecule for better combustion.
NanoMaxx will circulate permanently through the vehicle entire cooling system by adding directly to the vehicle radiator. NanoMaxx FIR is able to penetrate through the engine block and cylinder wall to break down the fuel molecules for better combustion.
Typical Engine combustion only produce around 70-75% efficiency and the balance 20-35% fuel is released as harmful emission (hydrocarbons,Nitrogen Oxides,Carbon & Carbon Monoxide) . With NanoMaxx almost 100% complete combustion is possible. Complete combustion only produce water(H2O) and carbon dioxide(CO2). Complete combustion will increase the power of your vehicle and improve your vehicle fuel efficiency from 5-20%!
What are the benefits of NanoMaxx ?
- With complete combustion harmful Emission can be reduced by (30-35%), Fuel Savings of (5- 25%),Power Improvement of (10-30%) and Noise Reduction from 5-20%.
How Do I Apply NanoMaxx?
Step 1:- Turn Off Engine and Open Radiator Cap.
Step 2:- Ensure Radiator Water is not 100% Full. If 100% full, please remove around 50ml of water from the radiator using the given syringe.
Step 3:- Shake NanoMaxx vigorously for 1 minute to ensure the nano mineral is evenly dispersed in the sachet.
Step 4:- Pour whole 30ml of NanoMaxx into the Radiator.
Step 5:- Start your engine and keep it running for 5 minutes and drive for at least 50km as soon as possible.
*For best performance & effectiveness, we recommend to change new water and radiator coolant for vehicles with more than 50,000km mileage. (Rust in Radiator and Water will reduce the effectiveness of NanoMaxx). NanoMaxx will start taking effect between 50-300km. You will notice your vehicle is more powerful and the fuel consumption improve after this using NanoMaxx.
How Fast will NanoMaxx takes Effect?
- NanoMaxx will takes into effect within 50-300km. For older vehicles, significant reduction of “black smoke” will be visible. All types of vehicle, will enjoy better power, fuel savings and noise reduction after 50-300km.
Is NanoMaxx Guaranteed to perform as what it claims?
- Yes.Nano Maxx has been extensively tested by various testing facilities, car manufactures and individuals.To date, all of results are positive and proven effective. Do read the testimonials here or visit www.facebook.com/nanoenergizermalaysia or https://www.facebook.com/groups/nanenergizerfanclub for more info
How frequent should I reapply NanoMaxx?
- Each sachet of NanoMaxx will last up to 18month and recommended to top up every 12month or after each radiator coolant flush or cleaning whichever earlier.
Price: RM120/sachet
Hi Sifu,
Please throw some light on me as I don't understand how "ignition coil" convert voltage. Let's say:-
1. Power input is 12vdc, coil ratio is 100:1 but the ignition coil output becomes about 24kv.
2. CDI output of 350vdc is sent to the input of ignition coil with 100:1 ratio but the ignition coil output becomes about 50kv.
Regards.
