my first post
Seraph
2,712
firstly, with rm1000 i suggest you do security plating for your car and grounding cable.
security plating - add some metal to your doors so people cannot pry open ur door and steal your car. there is a point near the bottom that when using a screw driver can open the door without triggering the alarm.
grounding - well, don't expect miracles, just good measure. better electricity flow, your cabin lights won't dim/flicker when on/off aircond, your headlamps abit stronger (mebbe kenot notice), if you using std player without amp and pump up the volume your player lights won't flicker when its booming the bass :P
Seraph
2,712
heheh no lah....
good ones for both rm500+-
you might be able to squeeze in the heat sheild sponge for your bonnet and boot too :P
Seraph
2,712
grounding cable - RM100-400
security metal plate for wira - RM80-250
heat/noise sheild sponge - RM60-120
aprox. :P
Seraph
2,712
branded ones mah :P
comes wif a sticker if u wanna stick on ur bonnet or door 2F2F style
forgot which brand liao but its one of the brands in NFS:Underground :P
The Marketplace Top Posts
Most modern engines are now electronically fuel injected and have plastic engine covers, this makes engine cleaning much easier compared to older engines with carburetors. I will show you how you can easily clean and shine a modern car's engine bay using only 2 Over-the-Counter (OTC) products.
This is a quick guide showing you how to quickly get your engine bay looking like new again. This guide is more suited towards modern cars' engine bays.
So here have have an engine bay that has never...
